Re: NEW MEMBER -- zsblp2002
'Comment from user:
I am in the process of restoring a v1942 Fairchild F24R
*** PLEASE NOTE ***
TO RESPOND TO THE NEW MEMBER, please use the 'reply to group' link at
the end of this message. Directly replying to this message will reach
me, not the new member.
The comments above are from the new member(s), not Dan Casali, the
group moderator. They were made during the new member sign-up and
would otherwise be unavailable to the general membership.
Dan Casali
Group Moderator
*** PLEASE NOTE ***
Dan Casali
Group Moderator
james chybicki
'Is the 1942 fairchild a UC-61 or -68?
'--- On Mon, 9/6/10, Dan Casali wrote:
Subject: [fairchildclub] NEW MEMBER -- zsblp2002
To: "Fairchild List"
Date: Monday, September 6, 2010, 8:24 PM
Comment from user:
*** PLEASE NOTE ***
Dan Casali
Group Moderator
Stuart Burgess
'It is a UC-61
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of james chybicki
Sent: 07 September 2010 04:02 PM
Subject: Re: [fairchildclub] NEW MEMBER -- zsblp2002
Comment from user:
*** PLEASE NOTE ***
Dan Casali
Group Moderator
james chybicki
'Hi Stuart
Where are you located?
can you send me pictures of your plane? rampratone@yahoo.com
What was the US Army Serial number? Do you know if it flew with the RAF?
I assume it is Warner powered?
thanks
Jim C.
UC-61K USAAF 43-19464 / RAF HB-690
thanks
Jim C.
'--- On Wed, 9/8/10, Stuart Burgess wrote:
Subject: RE: [fairchildclub] NEW MEMBER -- zsblp2002
Date: Wednesday, September 8, 2010, 2:23 AM
It is a UC-61
Comment from user:
*** PLEASE NOTE ***
Dan Casali
Group Moderator
Stuart Burgess
'Hi Jim
It is ranger powered and I am not sure of the numbers. As far as I know it was RAF, but in North Africa. I am not even sure if it actually flew, as it is rumoursed that some of those intended for North Africa were not even uncrated. After the war some 50 of these aircraft became the basis for the establishment of a company called Comair which currently operates British Airways under licence on the South African domestic routes.
Sent: 08 September 2010 03:59 PM
Hi Stuart
thanks
Jim C.
Hi Stuart
thanks
Jim C.
It is a UC-61
Comment from user:
*** PLEASE NOTE ***
Dan Casali
Group Moderator
james chybicki
'Stuart
On our plane, there was a US Army s/n stamped into the thick metal tube on the passenger side at the bottom of the door. Look for the tube that goes down on an angle from the rear door post toward the floor. The s/n was on the tube where it is exposed when you open the door.
I I
I I
I I
I I
I I fwd >
I I
I\ II \ here I
I \ |
____\__________________
good luck, let me know
I I
I I
I I
I I
I I fwd >
I I
I\ II \ here I
I \ |
Date: Wednesday, September 8, 2010, 9:31 AM
Hi Jim
Hi Stuart
thanks
Jim C.
It is a UC-61
Comment from user:
*** PLEASE NOTE ***
Dan Casali
Group Moderator
'Hi Dan
It is a 61
It is a 61
> From: Dan Casali
> Â
> Comment from user:
> *** PLEASE NOTE ***
> Thanks
> Dan Casali
> Group Moderator
'Hi Jim
Thanks a lot. I will have a look. My friend from whom I bought the plane thought the serial number was 1118. Now if this is a factory number or a military number I could not tell you.
> Stuart
> Â
> IÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â I
> IÂ Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â I fwd >
> I\                                    II \    here                       I
> IÂ Â Â \Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â |
> Â
> Jim
> From: Stuart Burgess
> Â
> Hi Jim
> Hi Stuart
> can you send me pictures of your plane? rampratone@...
> thanks
> Jim C.
> It is a UC-61
> From: Dan Casali
> Comment from user:
> *** PLEASE NOTE ***
> Thanks
> Dan Casali
> Group Moderator
Hugh Loewenhardt
'Jim, In the engineering world, stamping identification characters into structural members is prohibited because it creates stress risers which are breeding grounds for cracks.
It would be wise to inspect the stampings on the steel member in your project under magnification or by the dye method for hairline cracks. Hopefully, no cracks are present.
Date: Thursday, September 9, 2010, 3:46 PM
Stuart
I I
I I
I I
I I
I I fwd >
I I
I\ II \ here I
I \ |
Hi Jim
Hi Stuart
thanks
Jim C.
It is a UC-61
Comment from user:
*** PLEASE NOTE ***
Dan Casali
Group Moderator
james chybicki
'Hi Hugh
Thanks for the info, as a good A & P that was already accomplished long before the fusealage was primed and painted. Thanks for putting that out to all though. It's the simple things that can kill people!
Date: Thursday, September 9, 2010, 4:30 PM
Stuart
I I
I I
I I
I I
I I fwd >
I I
I\ II \ here I
I \ |
Hi Jim
Hi Stuart
thanks
Jim C.
It is a UC-61
Comment from user:
*** PLEASE NOTE ***
Dan Casali
Group Moderator
