'Does anyone have a PT-26 canopy release cable (p/n 68499) they would be willing to part with? This is the cable that goes between the release handle and the plunger.
Thanks!
Pete Crawford
Re: PT-26 canopy release handle cable
'if you could make a duplicate, I may let you borrow one that I might have on my spare canopy, but I cannot be sure until I will check today, I will need to get it back. Fritz,San Diego From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Monday, July 18, 2016 9:32 AM
Subject: [fairchildclub] PT-26 canopy release handle cable
Thanks!
Pete Crawford
Thanks!
Pete Crawford
'Pete,Do you need the long or short cable?
Ryan'
Ryan'
Pete Crawford
' Hi Ryan,
Actually, I think either will work. My rear canopy had a long cable installed, which per dwg 68499 is for the front canopy, BUT it had a small spacer on the upper end, reducing it's effective length. The Fleet canopy assy dwg. appears to show this spacer, but it's not clear. I now have that cable installed on the front canopy just so I can open it.
I got the lower fairings made and did a test assembly of the whole thing. Now just some painting, installing the glass (ugh) and it's done!
How are you doing?
Pete
How are you doing?
Pete
Pete, Do you need the long or short cable?
Ryan
'Pete,I have short cables, if you think it will work for you,email me youraddress and I will send one to you.
Ryan'
Ryan'
