Re: PT Brakes
Steve Link
PT Brakes
'Well, I’m getting ready to put my PT-23 Brakes back together….should have taken pix!What I am trying to figure out is which way the Retracting Springs, PN A-21-26, figure 35, are supposed to go into the pads. I’m thinking they went with the tips angled up towards the drum and the center towards the axle? It’s not really clear in the T.O. Also any tricks on getting them all in over the expander tube and frames? Should I use the drum to place them all together?Any help would be appreciated! Thanks, PT-23 N64225'
Steve Link
Re: PT Brakes
' Well, I should have looked in the Maintenance and Erection Manual, Section 5, Para. 4, Fig. 77. The Springs in the drawings are a bit different with lips on them instead of just a straight leaf. Oh well, that's what came out of her!
Date: Thu, 17 Mar 2016 19:49:16 -0500
Subject: [fairchildclub] PT Brakes
Re: PT Brakes
'I think you have the same expander tube brake assembly that the F-24's have. The arched portion is against the pads and the tips are close to the brake ring. I think on the assembly process, don't tighten the nuts and bolts on the two halves until you have all the pieces in place. As you assemble it, snug up the nuts & bolts slightly as you get the pieces on that side of the assembly in place. Is your brake drum nice an smooth? Do you have new pads? If so, you will probably need to get use of a lathe and remove some pad material so you can get to the allowable pad/drum tolerance. The number is in the manual. I would look it up, but my eyes are real tired. I have spent most of the afternoon hand stitching a new 40" zipper into my headliner.Bob
On Thursday, March 17, 2016 5:50 PM, "Steve Link steven_link@msn.com [fairchildclub]" wrote:
Well, I’m getting ready to put my PT-23 Brakes back together….should have taken pix!What I am trying to figure out is which way the Retracting Springs, PN A-21-26, figure 35, are supposed to go into the pads. I’m thinking they went with the tips angled up towards the drum and the center towards the axle? It’s not really clear in the T.O. Also any tricks on getting them all in over the expander tube and frames? Should I use the drum to place them all together?Any help would be appreciated! Thanks, PT-23 N64225 #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563 -- #ygrps-yiv-188074444yiv4789009563ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mkp #ygrps-yiv-188074444yiv4789009563hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mkp #ygrps-yiv-188074444yiv4789009563ads { margin-bottom:10px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mkp .ygrps-yiv-188074444yiv4789009563ad { padding:0 0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mkp .ygrps-yiv-188074444yiv4789009563ad p { margin:0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mkp .ygrps-yiv-188074444yiv4789009563ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-sponsor #ygrps-yiv-188074444yiv4789009563ygrp-lc { font-family:Arial;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-sponsor #ygrps-yiv-188074444yiv4789009563ygrp-lc #ygrps-yiv-188074444yiv4789009563hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-sponsor #ygrps-yiv-188074444yiv4789009563ygrp-lc .ygrps-yiv-188074444yiv4789009563ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563activity span { font-weight:700;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563activity span:first-child { text-transform:uppercase;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563activity span span { color:#ff7900;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563activity span .ygrps-yiv-188074444yiv4789009563underline { text-decoration:underline;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563attach div a { text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563attach img { border:none;padding-right:5px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563attach label { display:block;margin-bottom:5px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563attach label a { text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 blockquote { margin:0 0 0 4px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563bold a { text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 dd.ygrps-yiv-188074444yiv4789009563last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 dd.ygrps-yiv-188074444yiv4789009563last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 dd.ygrps-yiv-188074444yiv4789009563last p span.ygrps-yiv-188074444yiv4789009563yshortcuts { margin-right:0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563attach-table div div a { text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563attach-table { width:400px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563file-title a, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563file-title a:active, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563file-title a:hover, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563file-title a:visited { text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563photo-title a, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563photo-title a:active, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563photo-title a:hover, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div.ygrps-yiv-188074444yiv4789009563photo-title a:visited { text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 div#ygrps-yiv-188074444yiv4789009563ygrp-mlmsg #ygrps-yiv-188074444yiv4789009563ygrp-msg p a span.ygrps-yiv-188074444yiv4789009563yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563green { color:#628c2a;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563MsoNormal { margin:0 0 0 0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 o { font-size:0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563photos div { float:left;width:72px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563reco-category { font-size:77%;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563reco-desc { font-size:77%;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 .ygrps-yiv-188074444yiv4789009563replbq { margin:4px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mlmsg select, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 input, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mlmsg pre, #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 code { font:115% monospace;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-mlmsg #ygrps-yiv-188074444yiv4789009563logo { padding-bottom:10px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-msg p#ygrps-yiv-188074444yiv4789009563attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-reco #ygrps-yiv-188074444yiv4789009563reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-sponsor #ygrps-yiv-188074444yiv4789009563ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-sponsor #ygrps-yiv-188074444yiv4789009563ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-sponsor #ygrps-yiv-188074444yiv4789009563ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-text { font-family:Georgia;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-text tt { font-size:120%;} #ygrps-yiv-188074444 #ygrps-yiv-188074444yiv4789009563 #ygrps-yiv-188074444yiv4789009563ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-188074444
Steve Link
Re: PT Brakes
' Yes, the arched part can either go down with the tips sweeping up away from the tubes like in a smile, or arch up with the tips closer down to the tubes like a frown. In T.O. 01-115GA-2, sec. 5, para. 4, Fig. 77 it looks like the arch is to the bottom of the pad slot close to the tube, and the tips are sweeping up away from the tube, like a smile. As far as turning the pads, I guess that has to be done after assembly? I haven't found the blueprint yet....They sure don't make it simple do they....
"New blocks must be ground, concentric with center hole in brake on suitable machine to a diameter that will give proper clearance for brake in drum as specified on the blueprint of brake assembly."
A "suitable" machine? A lathe?
Date: Fri, 18 Mar 2016 03:02:36 +0000
Subject: Re: [fairchildclub] PT Brakes
Steve Link
Re: PT Brakes
'Not sure if this will come thru.....Pic of the diagram.
Date: Fri, 18 Mar 2016 13:14:32 -0500
Subject: RE: [fairchildclub] PT Brakes
'On Thursday, March 17, 2016 5:50 PM, "Steve Link steven_link@msn.com [fairchildclub]" wrote:
Well, I?m getting ready to put my PT-23 Brakes back together?.should have taken pix!What I am trying to figure out is which way the Retracting Springs, PN A-21-26, figure 35, are supposed to go into the pads. I?m thinking they went with the tips angled up towards the drum and the center towards the axle? It?s not really clear in the T.O. Also any tricks on getting them all in over the expander tube and frames? Should I use the drum to place them all together?Any help would be appreciated! Thanks, PT-23 N64225
Steve Link
Re: PT Brakes
' Nope, it didn't......why do some yahoo groups allow pix postings and other don't?
'> To: fairchildclub@yahoogroups.com
> From: fairchildclub@yahoogroups.com
> Date: Fri, 18 Mar 2016 13:20:02 -0500
> Yahoo Groups Links
> To visit your group on the web, go to:
> http://groups.yahoo.com/group/fairchildclub/
> Your email settings:
> Individual Email | Traditional
> To change settings online go to:
> http://groups.yahoo.com/group/fairchildclub/join
> (Yahoo! ID required)
> To change settings via email:
> fairchildclub-digest@yahoogroups.com
> fairchildclub-fullfeatured@yahoogroups.com
> Your use of Yahoo Groups is subject to:
> https://info.yahoo.com/legal/us/yahoo/utos/terms/
Joe Preston
Re: PT Brakes
' It is up to the administrator. We allow pictures to be sent in all of my other yahoo groups. -- Joe From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Friday, March 18, 2016 2:30 PM
Subject: RE: [fairchildclub] PT Brakes Nope, it didn't......why do some yahoo groups allow pix postings and other don't?
the pad slot close to the tube, and the tips are sweeping up away from the tube, like a smile. As far as turning the pads, I guess that has to be done after assembly? I haven't found the blueprint yet....They sure don't make it simple do they....> To: fairchildclub@yahoogroups.com
all the pieces in place. As you assemble it, snug up the nuts & bolts slightly as you get the pieces on that side of the assembly in place. Is your brake drum nice an smooth? Do you have new pads? If so, you will probably need to get use of a lathe and remove some pad material so you can get to the allowable pad/drum tolerance. The number is in the manual. I would look it up, but my eyes are real tired. I have spent most of the afternoon hand stitching a new 40" zipper into my headliner.Bob> "New blocks must be ground, concentric with center hole in brake on suitable machine to a diameter that will give proper clearance for brake in drum as specified on the blueprint of brake assembly."
steven_link@msn.com [fairchildclub]" wrote:>
towards the drum and the center towards the axle? It’s not really clear in the T.O. Also any tricks on getting them all in over the expander tube and frames? Should I use the drum to place them all together?Any help would be appreciated! Thanks, PT-23 N64225>
> Yahoo Groups Links
Re: PT Brakes
'I guess that there is different variations of the manual. Mine has the expander tube assembly in the same section, but fig 58. Fig 59 has the whole wheel assembly. What is odd, the figure has the input brake line on the top side.Well, sounds like you have it under control.
I only reused 3 pieces of wood that was on the airframe when I bought it in 1969. Bob
'On Friday, March 18, 2016 11:14 AM, "Steve Link steven_link@msn.com [fairchildclub]" wrote:
#yiv1689952808 -- #yiv1689952808ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv1689952808 #yiv1689952808ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv1689952808 #yiv1689952808ygrp-mkp #yiv1689952808hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv1689952808 #yiv1689952808ygrp-mkp #yiv1689952808ads {margin-bottom:10px;}#yiv1689952808 #yiv1689952808ygrp-mkp .yiv1689952808ad {padding:0 0;}#yiv1689952808 #yiv1689952808ygrp-mkp .yiv1689952808ad p {margin:0;}#yiv1689952808 #yiv1689952808ygrp-mkp .yiv1689952808ad a {color:#0000ff;text-decoration:none;}#yiv1689952808 #yiv1689952808ygrp-sponsor #yiv1689952808ygrp-lc {font-family:Arial;}#yiv1689952808 #yiv1689952808ygrp-sponsor #yiv1689952808ygrp-lc #yiv1689952808hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv1689952808 #yiv1689952808ygrp-sponsor #yiv1689952808ygrp-lc .yiv1689952808ad {margin-bottom:10px;padding:0 0;}#yiv1689952808 #yiv1689952808actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv1689952808 #yiv1689952808activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv1689952808 #yiv1689952808activity span {font-weight:700;}#yiv1689952808 #yiv1689952808activity span:first-child {text-transform:uppercase;}#yiv1689952808 #yiv1689952808activity span a {color:#5085b6;text-decoration:none;}#yiv1689952808 #yiv1689952808activity span span {color:#ff7900;}#yiv1689952808 #yiv1689952808activity span .yiv1689952808underline {text-decoration:underline;}#yiv1689952808 .yiv1689952808attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv1689952808 .yiv1689952808attach div a {text-decoration:none;}#yiv1689952808 .yiv1689952808attach img {border:none;padding-right:5px;}#yiv1689952808 .yiv1689952808attach label {display:block;margin-bottom:5px;}#yiv1689952808 .yiv1689952808attach label a {text-decoration:none;}#yiv1689952808 blockquote {margin:0 0 0 4px;}#yiv1689952808 .yiv1689952808bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv1689952808 .yiv1689952808bold a {text-decoration:none;}#yiv1689952808 dd.yiv1689952808last p a {font-family:Verdana;font-weight:700;}#yiv1689952808 dd.yiv1689952808last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv1689952808 dd.yiv1689952808last p span.yiv1689952808yshortcuts {margin-right:0;}#yiv1689952808 div.yiv1689952808attach-table div div a {text-decoration:none;}#yiv1689952808 div.yiv1689952808attach-table {width:400px;}#yiv1689952808 div.yiv1689952808file-title a, #yiv1689952808 div.yiv1689952808file-title a:active, #yiv1689952808 div.yiv1689952808file-title a:hover, #yiv1689952808 div.yiv1689952808file-title a:visited {text-decoration:none;}#yiv1689952808 div.yiv1689952808photo-title a, #yiv1689952808 div.yiv1689952808photo-title a:active, #yiv1689952808 div.yiv1689952808photo-title a:hover, #yiv1689952808 div.yiv1689952808photo-title a:visited {text-decoration:none;}#yiv1689952808 div#yiv1689952808ygrp-mlmsg #yiv1689952808ygrp-msg p a span.yiv1689952808yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv1689952808 .yiv1689952808green {color:#628c2a;}#yiv1689952808 .yiv1689952808MsoNormal {margin:0 0 0 0;}#yiv1689952808 o {font-size:0;}#yiv1689952808 #yiv1689952808photos div {float:left;width:72px;}#yiv1689952808 #yiv1689952808photos div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;}#yiv1689952808 #yiv1689952808photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv1689952808 #yiv1689952808reco-category {font-size:77%;}#yiv1689952808 #yiv1689952808reco-desc {font-size:77%;}#yiv1689952808 .yiv1689952808replbq {margin:4px;}#yiv1689952808 #yiv1689952808ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv1689952808 #yiv1689952808ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv1689952808 #yiv1689952808ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv1689952808 #yiv1689952808ygrp-mlmsg select, #yiv1689952808 input, #yiv1689952808 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv1689952808 #yiv1689952808ygrp-mlmsg pre, #yiv1689952808 code {font:115% monospace;}#yiv1689952808 #yiv1689952808ygrp-mlmsg * {line-height:1.22em;}#yiv1689952808 #yiv1689952808ygrp-mlmsg #yiv1689952808logo {padding-bottom:10px;}#yiv1689952808 #yiv1689952808ygrp-msg p a {font-family:Verdana;}#yiv1689952808 #yiv1689952808ygrp-msg p#yiv1689952808attach-count span {color:#1E66AE;font-weight:700;}#yiv1689952808 #yiv1689952808ygrp-reco #yiv1689952808reco-head {color:#ff7900;font-weight:700;}#yiv1689952808 #yiv1689952808ygrp-reco {margin-bottom:20px;padding:0px;}#yiv1689952808 #yiv1689952808ygrp-sponsor #yiv1689952808ov li a {font-size:130%;text-decoration:none;}#yiv1689952808 #yiv1689952808ygrp-sponsor #yiv1689952808ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv1689952808 #yiv1689952808ygrp-sponsor #yiv1689952808ov ul {margin:0;padding:0 0 0 8px;}#yiv1689952808 #yiv1689952808ygrp-text {font-family:Georgia;}#yiv1689952808 #yiv1689952808ygrp-text p {margin:0 0 1em 0;}#yiv1689952808 #yiv1689952808ygrp-text tt {font-size:120%;}#yiv1689952808 #yiv1689952808ygrp-vital ul li:last-child {border-right:none !important;}#yiv1689952808
Steve Link
PT Brakes
'Just got thru rebuilding my master cylinders…..took all of about 30 minutes after removing them from the plane. Thankfully my cylinders were in excellent shape. Pix to follow if they don’t show on this e-mail.
Not sure why there are two different types. The LH one looks like it has a spot welded saddle for the fitting, and a longer end sweated on with an internal stop, possible a cheaper wartime type. RH has a tag on it with 38776 stamped on it….seems much more solid.
Used Rockauto Raybestos MK-190 kits….
Sent: Sunday, October 29, 2017 8:00 AM
Subject: RE: [fairchildclub] PT-26
There is a rebuild kit for them if all you need is the internals and your cylinder is OK. The last answer I got was the Rockauto Raybestos MK-190 kits and appear to be identical to the parts for the PT-19/23/26 cylinder with the one inch bore.
Sent: Saturday, October 28, 2017 10:36 AM
Subject: Re: [fairchildclub] PT-26
Thank you very much, I will give them a call
Sent from my iPad
Sent from my iPad
'On Oct 28, 2017, at 11:26 AM, Jay Herrin jayherrin@bellsouth.net [fairchildclub] wrote:
David... try White Post Restorations. 540-837-1140
They did the master cylinders on my OTW and I’m am very happy with their work!
Jay
Sent from my iPad
On Oct 28, 2017, at 10:59 AM, David Stout aviator5@bellsouth.net [fairchildclub] wrote:
Finally found a couple of decent expander tubes for this airplane, however was disappointed to find both master cylinders leaking like a sieve.....removed them and took them apart. Bore looks fairly decent but needs new seals, cup style seals...anybody have any idea where I might find these? Thanks for any ideas you may have.
David Stout
Steve Link
Re: PT Brakes
Just loaded the pix under the album PT Brakes.....
From: fairchildclub@yahoogroups.com on behalf of Steve Link steven_link@msn.com [fairchildclub]
Sent: Sunday, November 5, 2017 12:45 PM
Sent from my iPad
Sent from my iPad
Jay
Sent from my iPad
David Stout
