' Bill: You might try ESSCO Aircraft. They do manuals of all kinds www.esscoaircraft.com 877-318-1555 (toll free) 888-249-4165 (toll free fax)
Mike Kelly Fairchild Club
Oil cooler duct
Ranchaero Wing Shop
Anti chafing material for oil tank (PT-19)
'Hi,
I'm looking for anti-chafing material to be used between the oil tank
and firewall, and under the oil tank straps. I've seen felt used on the
firewall, and cowling chafe cloth tape, but these tend to soak up oil.
Any better ideas?
David
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com'
Any better ideas?
David
Gene Haines
Re: Anti chafing material for oil tank (PT-19)
'We used strips of FAA approved and certified rubber roofing.
From: Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub]
To: fairchildclub
Sent: Tue, Jun 3, 2014 4:46 pm
Subject: [fairchildclub] Anti chafing material for oil tank (PT-19)
Hi,
Any better ideas?
David
To: fairchildclub
Hi,
Any better ideas?
David
Francisco Molina
Cork El 03/06/2014 13:50, "Gene Haines Pilot4906@aol.com [fairchildclub]" escribió:
To: fairchildclub
Hi,
Any better ideas?
David
'I used 'Viton Rubber' - I'm in UK - not sure who has it in the US. It's
available in all thicknesses and widths or get a sheet and cut off strips as
required.
Googling 'Viton Rubbe'r should find a supplier.
Frank
Sent: 03 June 2014 21:37
Hi,
Any better ideas?
David
required.
Frank
Hi,
Any better ideas?
David
Ranchaero Wing Shop
Oil cooler duct
'Thanks for everyone's input on the anti-chafing material. Rubber sounds
good to me.
Another question: I'm fitting up the oil system components, and can't
get the oil cooler duct (the one exiting the cooler) to fit. It rubs
against the oil tank. I see where it has chafed over the years. I'm
tempted to modify the oil cooler brackets to allow me to move the oil
cooler forward an inch or two, but that would require surgery - cut and
weld, which I can do, but there must be something I'm overlooking. The
cooler brackets don't allow much range of position. Any advice will be
much appreciated!
David
good to me.
much appreciated!
David
