Re: LIFT STRUTS
Fuel valves
'In need of a right fuel valve for F24.'
james chybicki
LIFT STRUTS
'HI ALL
HELP! FORWARD WING LIFT STRUT NEEDED
MY SEARCH STILL GOES ON! I POSSIBLY FOUND A SET IN TEXAS, BUT WILL NOT BE ABLE TO SEE THEM TILL OCTOBER.
DOES ANYONE HAVE A SERVICEABLE / FLYABLE SET OF F24 LIFT STRUTS? I HAVE SEEN SOME PICTURES AND SPOKE WITH A FEW FOLKS, BUT NOBODY SEEMS TO HAVE A GOOD SET OR DO NOT WANT TO PART WITH THEM.
CAN THESE BE REPAIRED? THEN ORIGINAL 1944 UC-61 MANUAL DOES NOT GIVE ANY REPAIR PARAMETERS.
I TRIED SOME LOCAL METAL FABRICATORS HERE IN THE MIDWEST, BUT NONE ARE ABLE TO GET TEH .95 THICK TUBE WITHOUT SPECIAL ORDERING HUNDREDS OF FEET AT A TIME. ECONOMICALLY UNREALISTIC.
ANY HELP WOULD BE GREATLY APPRECIATE!
JIM CHYBICKI
UC-61K 43-14964 / HB-690
JIM CHYBICKI
Re: LIFT STRUTS
'I would try. Pete Plumb
(661) 391-9464
Wood Wing Specialty
H can possibly rebuild your struts using your old ends. He does if for
pre-war Aeroncas so give him a call.
Cy Galley; Aeronca Aviator
Supporting Aeroncas every day
www.aeronca.org
518-731-3131
On Behalf Of james chybicki
Sent: Tuesday, September 11, 2012 11:06 AM
Subject: [fairchildclub] LIFT STRUTS
HI ALL
REPAIR PARAMETERS.
JIM CHYBICKI
(661) 391-9464
Wood Wing Specialty
www.aeronca.org
518-731-3131
HI ALL
REPAIR PARAMETERS.
JIM CHYBICKI
Hugh Loewenhardt
Re: LIFT STRUTS
'Jim,
Suggestion; obtain a copy of Fairchild drawing 44169 for the UC-61 forward wing strut from the well known American museum with Fairchild drawing files, clean up notes as necessary and send a copy to Univair with a Request for Quotation letter. It will be expensive if Univair will make the strut but at least you will have that as an option. Let the group know the results should you get a quoation from Univair for the strut.
Sent: Tuesday, September 11, 2012 12:05 PM
HI ALL
JIM CHYBICKI
HI ALL
JIM CHYBICKI
james chybicki
Re: LIFT STRUTS
'Hi Hugh
Thanks for the lead, I have the prints and will give Univair a shot.
will advise
Jim C
Sent: Tuesday, September 11, 2012 4:47 PM
Subject: Re: [fairchildclub] LIFT STRUTS
Jim,
To: "mailto:fairchildclub%40yahoogroups.com"
HI ALL
JIM CHYBICKI
will advise
Jim C
Jim,
HI ALL
JIM CHYBICKI
Re: LIFT STRUTS
'James: Although these guys are in the UK, it might be worth contacting
them too. They have the ability to roll almost anything the Brits used
from WW1 and on.
http://www.aerovintagespares.com/
Craig C.'
from WW1 and on.
Craig C.'
paul pinato
SV: [fairchildclub] LIFT STRUTS
'http://www.aerovintagespares.com/avspares/copy_of_
copy_of_Streamline_Tubing.html
Hi
This may help you.
Paul Pinato
St. Persgatan 128 B
602 30 Norrköping
Sweden
+46 (0)11 181 509
+46 (0)705 411 118
paul.pinato@swipnet.se
SE-AWS
Från: fairchildclub@yahoogroups.com
[mailto:fairchildclub@yahoogroups.com] För james
chybicki
Skickat: den 11 september 2012 18:06
Ämne: [fairchildclub] LIFT STRUTS
HI ALL
OCTOBER.
JIM CHYBICKI
removed]
Hi
This may help you.
Paul Pinato
St. Persgatan 128 B
602 30 Norrköping
Sweden
+46 (0)11 181 509
+46 (0)705 411 118
SE-AWS
chybicki
HI ALL
OCTOBER.
JIM CHYBICKI
removed]
Re: LIFT STRUTS
'Where are you located?
Webster, MN
Webster, MN
'--- In fairchildclub@yahoogroups.com, james chybicki wrote:
> HI ALL
> JIM CHYBICKI
james chybicki
Re: LIFT STRUTS
'Hi Bob
I am located in the suburbs of Chicago, our plane is at our restoration hangar at CLOW Int'l Airport (1C5)
Sent: Monday, September 17, 2012 8:08 AM
Subject: [fairchildclub] Re: LIFT STRUTS
Webster, MN
Webster, MN
'--- In mailto:fairchildclub%40yahoogroups.com, james chybicki wrote:
> HI ALL
> JIM CHYBICKI
Re: LIFT STRUTS
'Jim,
Give me a call. I am a t 952 followed by 652 then a 3000.
Bob W.
Webster, MN
Bob W.
Webster, MN
> HI ALL
> JIM CHYBICKI
