'Good Morning !
I am building a test bench to do the initial break in of Ranger Engines I rebuild.. I would like to find an electric starter for this.
Should anyone have something you are willing to part with, please contact me. johne35@att.net or cell number is : 573 450 1676.
Thanks... John Ellis
Re: Stromberg NA-R4B Carburetor
Re: Ranger Engine electric starter
'John,
If you need a eng mounted fuel pump, I have a partial core. You can have.
JST
Fairchild Club CD ROM Editor
IAC 5, Chapter President
http://iac5.org
Kelly Airpark (CO15)
http://www.kellyairpark.com
Hm/Hgr 303-648-0130
Cell 303-304-7937
Quote of the Month: I hope you either take up parachute jumping or stay out
of single motored airplanes at night. - Charles A. Lindbergh, to Wiley Post
1931
On Behalf Of John Ellis
Sent: Friday, December 30, 2011 12:28 PM
Subject: [fairchildclub] Ranger Engine electric starter
Good Morning !
1676.
JST
http://iac5.org
Hm/Hgr 303-648-0130
Cell 303-304-7937
1931
Good Morning !
1676.
Jack Threadgill
'I have a Ranger engine with a Stromberg Carb. I am interested in
information about someone that does overhaul or repair of these carburetors.
Jack
Jack M. Threadgill
1602 Brook Hollow Dr
Bryan, Texas 77802
979-779-7155
threadgl@suddenlink.net
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Jack Threadgill
'Also, I would be interested to know if anyone has access to instructions or
maintenance of the Stromberg NA-R4B Carburetor.
Thanks again,
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
On Behalf Of Jack Threadgill
Sent: Friday, December 30, 2011 1:40 PM
Subject: RE: [fairchildclub] Stromberg NA-R4B Carburetor
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Thanks again,
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
'Jack,
Sent manuals to your home email.
JST
http://iac5.org
Hm/Hgr 303-648-0130
Cell 303-304-7937
1931
Sent: Friday, December 30, 2011 12:44 PM
Thanks again,
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
JST
http://iac5.org
Hm/Hgr 303-648-0130
Cell 303-304-7937
1931
Thanks again,
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Jack Threadgill
'Thanks very much, Jamie.
Jack
Sent from my iPhone, Jack
Jack
'On Dec 30, 2011, at 2:37 PM, "Jamie Treat" wrote:
> Jack,
> JST
> Jamie S. Treat
> http://iac5.org
> Elbert, CO 80106
> Hm/Hgr 303-648-0130
> Cell 303-304-7937
> 1931
> Thanks again,
> Jack
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
> Thanks,
> Jack
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
John Ellis
'Hi Jack,
Been away from shop all afternoon.. What did you find when you opened it
up.
John
up.
John
Sent: Friday, December 30, 2011 1:43 PM
> or
> Thanks again,
> Jack
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
> carburetors.
> Thanks,
> Jack
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
John Ellis
'Hi Jamie,
Thanks for the offer.. I have several pumps..
Can't find a starter.
Have a Happy and Great New Year !
John
John
Sent: Friday, December 30, 2011 1:31 PM
Subject: RE: [fairchildclub] Ranger Engine electric starter
> John,
> JST
> Jamie S. Treat
> http://iac5.org
> Elbert, CO 80106
> Hm/Hgr 303-648-0130
> Cell 303-304-7937
> out
> Post
> 1931
> Good Morning !
> 450
> 1676.
Jack Threadgill
'John, I don?t have much to report, but I may have spoken to soon. After
working on the carb and getting the accelerator pump screwed back in, it
appeared as the pumping action was in the last ¼ inch of movement. So when
I tried to start the engine and had all the trouble I changed my priming
procedure on the throttle action to pumping it only the last third of travel
near full throttle. This was prompted by wanting to put as little stress on
my repaired little fork as possible.
This morning before taking the carb input apart, I decided to try an engine
start using my old procedure. That is pumping the wobble pump to obtain
steady pressure and then rapidly pumping the throttle five full times using
the full throw of the throttle leaver as described in the operation manual.
This time the engine started normally. I cannot say this is due to being
started only one day after a previous run, or if this procedure is required
for the accelerator pump to pick up the fuel and spray it into the throat.
I was also waiting to see if I could get some info on the carb. I rcvd that
from Jamie Treat today.
I am hoping that the accelerator pump is actually working and at first I was
not sure and thought it was not working. At this point, I am going to use
my old priming and starting procedure and see if it continues to work
normally.
I will continue to keep you posted on how it is operating. Also, Mike Kelly
told me that Terry Norris with Aircraft Systems in Rockford. IL overhauls
these carbs. I have used them for years on Mags, Gens, Starters and
Alternators with excellent results. I am glad to know they do carbs as well
because I have faith in them.
Hopefully I got the carb and accelerator pump properly installed and it is
actually working ok after all.
Thanks for your input, patience and help. I will stay in touch and keep you
informed.
You and Dottie have a Happy New Year.
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Sent: Friday, December 30, 2011 8:35 PM
Subject: Re: [fairchildclub] Stromberg NA-R4B Carburetor
Hi Jack,
up.
John
normally.
informed.
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
Hi Jack,
up.
John
> or
> Thanks again,
> Jack
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
> carburetors.
> Thanks,
> Jack
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
