'Does anyone know if the rubber hose that connects the push-rod tubes to the
engine case can be replaced without pulling the cylinders off.
JP.Lorie
Florida
SV: [fairchildclub] warner 165
'Hi
You have to unscrew the pushrod tube from the
cylinder. On my engine it was very close. The
pushrod tube can be hard to unscrew as the grip is
so thin. It cost me two knuckles.
Paul
UC61A
SE-AWS
Från: fairchildclub@yahoogroups.com
[mailto:fairchildclub@yahoogroups.com] För Jp
Lorie
Skickat: den 9 maj 2011 17:49
Ämne: [fairchildclub] warner 165
cylinders off.
JP.Lorie
Florida
removed]
Paul
UC61A
SE-AWS
Lorie
cylinders off.
JP.Lorie
Florida
removed]
