'Folks -
Does anyone know a source for AN510 & AN520 Machine screws? -
specifically 510-416-11, 12, & 18 and 520-416-12 & 18. These are for
securing the door frame woodwork on my F24.
I have managed to salvage as many as possible but need some
replacements.
'Jay-Tex' list them on their inventory but despite 3 e-mails, 1 fax and
3 phone calls since 4 August they cannot/will not get back to me, if
even to say that they do not have them. I'm not at all impressed!
Any leads will be very much appreciated
Frank Cox
(UC61K G-BCBL)'
Re: AN510 & 520 Screws
'--- In fairchildclub@yahoogroups.com, "Frank Cox"
Have you tried a companny called "skybolt airmotive" in Leesburg
florida? They specialise in nothing but bolts and fasteners for
aircraft. They supplied all the fasteners for the CAF's b-24.
I can't find a catalog but google should find their #.
PS. my uncle's uncle was named frank cox. He lived in South west
Virginia in the 1920's. any relation ???
Tim in Orlando'
for>
> Folks -
and> securing the door frame woodwork on my F24.
> replacements.
if> 3 phone calls since 4 August they cannot/will not get back to me,
Frank:> even to say that they do not have them. I'm not at all impressed!
> Frank Cox
> (UC61K G-BCBL)
Tim in Orlando'
'I had much the same problem with mine. I was encouraged to replace them with something more common. I found some stainless steel flatheads, with the same coarse threads. I showed the AI what I had found, his replay was that they are still a ton of over kill as compaired to what was necessary.
Another thing, just so that you will have something else to worry about. The flat head bolts that are used on the door hinges have a larger head than what you will be able to locate. I cheated. I reshaped some thin stainless steel washers for use with the flat head bolts (used a counter sink die for flat head hardware, in a rivet squeezer) The off the shelf bolts that you get today, have heads that are too small. They will pull through the holes.
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Sent: Saturday, August 23, 2008 1:29 AM
Subject: [fairchildclub] AN510 & 520 Screws
Folks -
replacements.
Frank Cox
(UC61K G-BCBL)
