'Does anyone have any experience bench testing the Jack & Heinz gyro?
Mine seems locked in the "caged" postion ( little flag up and knob won't
turn) yet application of some suction provides nothing.
Failing this info, how does it work in the plane? Start the engine, the
venturi sucks because of prop wash, then if you shut the engine down
would you hear the gyro spinning down? Thanks.
David Stroud Ottawa, Canada
C-FDWS Christavia
Fairchild 51 early construction
Re: Jack & Heinz attitude gyro
Karl Saenger
'David,
I have several "Sperry" artifical horizons here, they are probably
similar. To uncage, normally you would need to pull and turn. If
nothing happens it might be corroded. The gyro will turn regardless of
caged or not.
Just to run the engine on the ground will not create enough vacuum to
run the gyro properly. It needs flying speed.
You can connect a vacuum cleaner to the instrument for bench testing.
I hope that helps.
Best regards
Karl
caged or not.
I hope that helps.
Best regards
Karl
won't
the
> C-FDWS Christavia
David Stroud
'Thanks for the note, Karl. The vacuum cleaner trick was good enough to spool
things up and the cage knob gear was temporarily locked up where it enters
the case. The device seems to work ok now on the bench but the "caged"
flag won't go away. I'm thinking it should go away on shutdown?
If I sat in a box for 60 years, I'd be a bit stiff too I guess. The little plastic
plugs on the back were brittle as hell and had to get drilled out.
C-FDWS Christavia
C-FDWS Christavia
Sent: Tuesday, February 21, 2006 12:17 PM
Subject: [fairchildclub] Re: Jack & Heinz attitude gyro
David,
caged or not.
I hope that helps.
Best regards
Karl
won't
the
> C-FDWS Christavia
SPONSORED LINKS Private plane Fairchild semiconductor Plane reservation
Fairchild Jet plane Pedal plane
YAHOO! GROUPS LINKS
a.. Visit your group "fairchildclub" on the web.
Checked by AVG Free Edition.
Version: 7.1.375 / Virus Database: 267.15.12/265 - Release Date: 2/20/06
Pilot4906@aol.com
'In a message dated 2/21/2006 7:56:41 P.M. Eastern Standard Time,
dstroud@storm.ca writes:
plastic
C-FDWS Christavia
plastic
C-FDWS Christavia
David,
I have several "Sperry" artificial horizons here, they are probably
similar. To un cage, normally you would need to pull and turn. If
caged or not.
I hope that helps.
Best regards
Karl
> Mine seems locked in the "caged" position ( little flag up and knob
won't
the
> C-FDWS Christavia
YAHOO! GROUPS LINKS
As I remember the flag is mechanical and will only go away when the knob is
turned. Yes the gyro may turn but the horizon will remain stationary unless
the unit is un caged.
