'We just rebuilt the wing outboard trailing edge and unfortunately the most outboard section of the flap is rubbing against the flap well. Does anyone know of a way to adjust the mounts to allow for more clearance. Thank y’all.
Sent from my iPhone'
Re: Flap adjustment?
' If I would make a guess, the thickness(vertically) of the rib that the trailing edge material ties into may be too thick. I believe, if my memory is correct, should be as thick as the of the ribs between the butt rib and the full rib between the end of the flap and the aileron. The other thing that comes to mind is to put a sturdy thread through all 3 flap mount bearings. Check between the tops of all 3, bottom of all 3, and for and aft on all 3. Also, the bottom of all the flap ribs should be the same height above the spar. On this one, I could be wrong. It may be 1/8" or so greater. All my ribs were copies of the OE.Is your wings covered? I only built both of mine 20 years ago. I may still have one of the ribs from the outboard end of the flaps.
Sent from my iPhone
#ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506 -- #ygrps-yiv-569220744yiv5194395506ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mkp #ygrps-yiv-569220744yiv5194395506hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mkp #ygrps-yiv-569220744yiv5194395506ads { margin-bottom:10px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mkp .ygrps-yiv-569220744yiv5194395506ad { padding:0 0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mkp .ygrps-yiv-569220744yiv5194395506ad p { margin:0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mkp .ygrps-yiv-569220744yiv5194395506ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-sponsor #ygrps-yiv-569220744yiv5194395506ygrp-lc { font-family:Arial;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-sponsor #ygrps-yiv-569220744yiv5194395506ygrp-lc #ygrps-yiv-569220744yiv5194395506hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-sponsor #ygrps-yiv-569220744yiv5194395506ygrp-lc .ygrps-yiv-569220744yiv5194395506ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506activity span { font-weight:700;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506activity span:first-child { text-transform:uppercase;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506activity span span { color:#ff7900;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506activity span .ygrps-yiv-569220744yiv5194395506underline { text-decoration:underline;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506attach div a { text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506attach img { border:none;padding-right:5px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506attach label { display:block;margin-bottom:5px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506attach label a { text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 blockquote { margin:0 0 0 4px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506bold a { text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 dd.ygrps-yiv-569220744yiv5194395506last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 dd.ygrps-yiv-569220744yiv5194395506last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 dd.ygrps-yiv-569220744yiv5194395506last p span.ygrps-yiv-569220744yiv5194395506yshortcuts { margin-right:0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506attach-table div div a { text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506attach-table { width:400px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506file-title a, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506file-title a:active, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506file-title a:hover, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506file-title a:visited { text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506photo-title a, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506photo-title a:active, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506photo-title a:hover, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div.ygrps-yiv-569220744yiv5194395506photo-title a:visited { text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 div#ygrps-yiv-569220744yiv5194395506ygrp-mlmsg #ygrps-yiv-569220744yiv5194395506ygrp-msg p a span.ygrps-yiv-569220744yiv5194395506yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506green { color:#628c2a;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506MsoNormal { margin:0 0 0 0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 o { font-size:0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506photos div { float:left;width:72px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506reco-category { font-size:77%;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506reco-desc { font-size:77%;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 .ygrps-yiv-569220744yiv5194395506replbq { margin:4px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mlmsg select, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 input, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mlmsg pre, #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 code { font:115% monospace;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-mlmsg #ygrps-yiv-569220744yiv5194395506logo { padding-bottom:10px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-msg p#ygrps-yiv-569220744yiv5194395506attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-reco #ygrps-yiv-569220744yiv5194395506reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-sponsor #ygrps-yiv-569220744yiv5194395506ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-sponsor #ygrps-yiv-569220744yiv5194395506ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-sponsor #ygrps-yiv-569220744yiv5194395506ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-text { font-family:Georgia;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-text tt { font-size:120%;} #ygrps-yiv-569220744 #ygrps-yiv-569220744yiv5194395506 #ygrps-yiv-569220744yiv5194395506ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-569220744 '
On ?Thursday?, ?February? ?7?, ?2019? ?11?:?50?:?15? ?AM? ?PST, Roy Rucker roy25101@yahoo.com [fairchildclub] wrote:
Sent from my iPhone
Roy Rucker
'Thank you but yes everything is covered, painted, and ready to hang. We are going to have to jump through some hoops on this one.
Sent from my iPhone
If I would make a guess, the thickness(vertically) of the rib that the trailing edge material ties into may be too thick. I believe, if my memory is correct, should be as thick as the of the ribs between the butt rib and the full rib between the end of the flap and the aileron. The other thing that comes to mind is to put a sturdy thread through all 3 flap mount bearings.. Check between the tops of all 3, bottom of all 3, and for and aft on all 3. Also, the bottom of all the flap ribs should be the same height above the spar. On this one, I could be wrong. It may be 1/8" or so greater. All my ribs were copies of the OE.Is your wings covered? I only built both of mine 20 years ago. I may still have one of the ribs from the outboard end of the flaps.
Sent from my iPhone
Sent from my iPhone
On Feb 8, 2019, at 12:45 AM, Robert Etter robertetter@ymail.com [fairchildclub] wrote:
Sent from my iPhone
'Here is a couple more photos of my right wing. (Civil wing pre war) #1, you can see a 1/4" strip of "Wrap-Lock" that I screw down over the fabric (hole counter sunk) into the Pull Up strip that the wrap lock is laying in front of. #3 photo shows it after I screw it down. The fabric was rib stitched through that flap area. I did screw up on that wing. I didn't get the rib tips flat to the flap through the entire area. The pull up strip is larger that OE on the right wing, but it is like that which was on the left wing (UC-61). I counter sunk the holes in the strip and used 3/8" flat head sheet metal screws. I used stainless sheet metal screws because of the longer thread. Photo #4 shows OE markings on the gas tank. "GAS 30 GAL". Not to FAA specs, but it is OE.
'On ?Friday?, ?February? ?8?, ?2019? ?03?:?32?:?55? ?AM? ?PST, Roy Rucker roy25101@yahoo.com [fairchildclub] wrote:
Sent from my iPhone
If I would make a guess, the thickness(vertically) of the rib that the trailing edge material ties into may be too thick. I believe, if my memory is correct, should be as thick as the of the ribs between the butt rib and the full rib between the end of the flap and the aileron. The other thing that comes to mind is to put a sturdy thread through all 3 flap mount bearings... Check between the tops of all 3, bottom of all 3, and for and aft on all 3. Also, the bottom of all the flap ribs should be the same height above the spar. On this one, I could be wrong. It may be 1/8" or so greater. All my ribs were copies of the OE.Is your wings covered? I only built both of mine 20 years ago. I may still have one of the ribs from the outboard end of the flaps.
Sent from my iPhone
#yiv3536486495 #yiv3536486495 -- #yiv3536486495ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv3536486495 #yiv3536486495ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv3536486495 #yiv3536486495ygrp-mkp #yiv3536486495hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv3536486495 #yiv3536486495ygrp-mkp #yiv3536486495ads {margin-bottom:10px;}#yiv3536486495 #yiv3536486495ygrp-mkp .yiv3536486495ad {padding:0 0;}#yiv3536486495 #yiv3536486495ygrp-mkp .yiv3536486495ad p {margin:0;}#yiv3536486495 #yiv3536486495ygrp-mkp .yiv3536486495ad a {color:#0000ff;text-decoration:none;}#yiv3536486495 #yiv3536486495ygrp-sponsor #yiv3536486495ygrp-lc {font-family:Arial;}#yiv3536486495 #yiv3536486495ygrp-sponsor #yiv3536486495ygrp-lc #yiv3536486495hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv3536486495 #yiv3536486495ygrp-sponsor #yiv3536486495ygrp-lc .yiv3536486495ad {margin-bottom:10px;padding:0 0;}#yiv3536486495 #yiv3536486495actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv3536486495 #yiv3536486495activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv3536486495 #yiv3536486495activity span {font-weight:700;}#yiv3536486495 #yiv3536486495activity span:first-child {text-transform:uppercase;}#yiv3536486495 #yiv3536486495activity span a {color:#5085b6;text-decoration:none;}#yiv3536486495 #yiv3536486495activity span span {color:#ff7900;}#yiv3536486495 #yiv3536486495activity span .yiv3536486495underline {text-decoration:underline;}#yiv3536486495 .yiv3536486495attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv3536486495 .yiv3536486495attach div a {text-decoration:none;}#yiv3536486495 .yiv3536486495attach img {border:none;padding-right:5px;}#yiv3536486495 .yiv3536486495attach label {display:block;margin-bottom:5px;}#yiv3536486495 .yiv3536486495attach label a {text-decoration:none;}#yiv3536486495 blockquote {margin:0 0 0 4px;}#yiv3536486495 .yiv3536486495bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv3536486495 .yiv3536486495bold a {text-decoration:none;}#yiv3536486495 dd.yiv3536486495last p a {font-family:Verdana;font-weight:700;}#yiv3536486495 dd.yiv3536486495last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv3536486495 dd.yiv3536486495last p span.yiv3536486495yshortcuts {margin-right:0;}#yiv3536486495 div.yiv3536486495attach-table div div a {text-decoration:none;}#yiv3536486495 div.yiv3536486495attach-table {width:400px;}#yiv3536486495 div.yiv3536486495file-title a, #yiv3536486495 div.yiv3536486495file-title a:active, #yiv3536486495 div.yiv3536486495file-title a:hover, #yiv3536486495 div.yiv3536486495file-title a:visited {text-decoration:none;}#yiv3536486495 div.yiv3536486495photo-title a, #yiv3536486495 div.yiv3536486495photo-title a:active, #yiv3536486495 div.yiv3536486495photo-title a:hover, #yiv3536486495 div.yiv3536486495photo-title a:visited {text-decoration:none;}#yiv3536486495 div#yiv3536486495ygrp-mlmsg #yiv3536486495ygrp-msg p a span.yiv3536486495yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv3536486495 .yiv3536486495green {color:#628c2a;}#yiv3536486495 .yiv3536486495MsoNormal {margin:0 0 0 0;}#yiv3536486495 o {font-size:0;}#yiv3536486495 #yiv3536486495photos div {float:left;width:72px;}#yiv3536486495 #yiv3536486495photos div div {border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}#yiv3536486495 #yiv3536486495photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv3536486495 #yiv3536486495reco-category {font-size:77%;}#yiv3536486495 #yiv3536486495reco-desc {font-size:77%;}#yiv3536486495 .yiv3536486495replbq {margin:4px;}#yiv3536486495 #yiv3536486495ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv3536486495 #yiv3536486495ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv3536486495 #yiv3536486495ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv3536486495 #yiv3536486495ygrp-mlmsg select, #yiv3536486495 input, #yiv3536486495 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv3536486495 #yiv3536486495ygrp-mlmsg pre, #yiv3536486495 code {font:115% monospace;}#yiv3536486495 #yiv3536486495ygrp-mlmsg * {line-height:1.22em;}#yiv3536486495 #yiv3536486495ygrp-mlmsg #yiv3536486495logo {padding-bottom:10px;}#yiv3536486495 #yiv3536486495ygrp-msg p a {font-family:Verdana;}#yiv3536486495 #yiv3536486495ygrp-msg p#yiv3536486495attach-count span {color:#1E66AE;font-weight:700;}#yiv3536486495 #yiv3536486495ygrp-reco #yiv3536486495reco-head {color:#ff7900;font-weight:700;}#yiv3536486495 #yiv3536486495ygrp-reco {margin-bottom:20px;padding:0px;}#yiv3536486495 #yiv3536486495ygrp-sponsor #yiv3536486495ov li a {font-size:130%;text-decoration:none;}#yiv3536486495 #yiv3536486495ygrp-sponsor #yiv3536486495ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv3536486495 #yiv3536486495ygrp-sponsor #yiv3536486495ov ul {margin:0;padding:0 0 0 8px;}#yiv3536486495 #yiv3536486495ygrp-text {font-family:Georgia;}#yiv3536486495 #yiv3536486495ygrp-text p {margin:0 0 1em 0;}#yiv3536486495 #yiv3536486495ygrp-text tt {font-size:120%;}#yiv3536486495 #yiv3536486495ygrp-vital ul li:last-child {border-right:none !important;}#yiv3536486495
'I'm sorry but I am not sure where to view the pictures. They did not come up in the email. '
' I guess that I will need to send them to you via a different address. Something about the fairchildclub address doesn't allow photos. I have photos of my Fairchild from back when it was a bare steel tube frame all the way up to about 99% ready to fly. I think that I had part of the same problem that you have with the fabric in the flap recess area. I sort of guessed that the factory used a 1/4" strip and screws in the top front of the flap recess to hold the fabric up.If you have a different address I can resend it all again.
I'm sorry but I am not sure where to view the pictures. They did not come up in the email. #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737 -- #ygrps-yiv-2015265189yiv4707537737ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mkp #ygrps-yiv-2015265189yiv4707537737hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mkp #ygrps-yiv-2015265189yiv4707537737ads { margin-bottom:10px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mkp .ygrps-yiv-2015265189yiv4707537737ad { padding:0 0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mkp .ygrps-yiv-2015265189yiv4707537737ad p { margin:0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mkp .ygrps-yiv-2015265189yiv4707537737ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-sponsor #ygrps-yiv-2015265189yiv4707537737ygrp-lc { font-family:Arial;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-sponsor #ygrps-yiv-2015265189yiv4707537737ygrp-lc #ygrps-yiv-2015265189yiv4707537737hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-sponsor #ygrps-yiv-2015265189yiv4707537737ygrp-lc .ygrps-yiv-2015265189yiv4707537737ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737activity span { font-weight:700;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737activity span:first-child { text-transform:uppercase;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737activity span span { color:#ff7900;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737activity span .ygrps-yiv-2015265189yiv4707537737underline { text-decoration:underline;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737attach div a { text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737attach img { border:none;padding-right:5px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737attach label { display:block;margin-bottom:5px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737attach label a { text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 blockquote { margin:0 0 0 4px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737bold a { text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 dd.ygrps-yiv-2015265189yiv4707537737last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 dd.ygrps-yiv-2015265189yiv4707537737last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 dd.ygrps-yiv-2015265189yiv4707537737last p span.ygrps-yiv-2015265189yiv4707537737yshortcuts { margin-right:0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737attach-table div div a { text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737attach-table { width:400px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737file-title a, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737file-title a:active, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737file-title a:hover, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737file-title a:visited { text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737photo-title a, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737photo-title a:active, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737photo-title a:hover, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div.ygrps-yiv-2015265189yiv4707537737photo-title a:visited { text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 div#ygrps-yiv-2015265189yiv4707537737ygrp-mlmsg #ygrps-yiv-2015265189yiv4707537737ygrp-msg p a span.ygrps-yiv-2015265189yiv4707537737yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737green { color:#628c2a;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737MsoNormal { margin:0 0 0 0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 o { font-size:0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737photos div { float:left;width:72px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737reco-category { font-size:77%;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737reco-desc { font-size:77%;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 .ygrps-yiv-2015265189yiv4707537737replbq { margin:4px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mlmsg select, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 input, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mlmsg pre, #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 code { font:115% monospace;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-mlmsg #ygrps-yiv-2015265189yiv4707537737logo { padding-bottom:10px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-msg p#ygrps-yiv-2015265189yiv4707537737attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-reco #ygrps-yiv-2015265189yiv4707537737reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-sponsor #ygrps-yiv-2015265189yiv4707537737ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-sponsor #ygrps-yiv-2015265189yiv4707537737ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-sponsor #ygrps-yiv-2015265189yiv4707537737ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-text { font-family:Georgia;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-text tt { font-size:120%;} #ygrps-yiv-2015265189 #ygrps-yiv-2015265189yiv4707537737 #ygrps-yiv-2015265189yiv4707537737ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-2015265189 '
On ?Monday?, ?February? ?11?, ?2019? ?06?:?07?:?35? ?AM? ?PST, roy25101@yahoo.com [fairchildclub] wrote:
