It's time to purchase a new ELT, and am looking at EBC's 406AP and E.L.T's 406 with GPS. I am interested in how folks have mounted the antenna's in a F24. Wanting to keep an original look while adding up-to-date safety, I have heard the antenna can be mounted under the fabric humpback. Has anybody made up a ground plane on the steel tube frame? Your thoughts would be appreciated.
Craig Stone
N81204
F24R46'
Re: ELTs
Re: ELTs
'I installed the E. L. T. Under the seat and the antenna just behind the baggage compartment. If I remember correctly, there is a semi triangular tubing structure just forward the rudder and and tailwheel bell crank assembly. I purchased a piece of hardened aluminum (for stiffness) and cut a matching ground-plane. I drilled the aluminum where it intersected with the tubing and attached those rubber padded clamps so as to go around the tubing. The antenna was preinstalled on to the aluminum before final mounting.
JP
Sent from my iPad
Craig Stone
N81204
F24R46
JP
Sent from my iPad
Craig Stone
N81204
F24R46
Elton Hanneman
Re: ELTs
Mine is on the bottom of the boot cowl. Short antenna leed and is a ground plane.
Sent: Tuesday, August 14, 2018 8:53 PM
Subject: [fairchildclub] ELTs
Craig Stone
N81204
F24R46
Craig Stone
N81204
F24R46
Re: ELTs
'I just finished my install in my 24. I put a ground plane just forward of the rudder cable junction and below the cables. I utilized part of the frame that the rudder idles arms are mounted to as part of the mount and put 2 adel clamps below the ground plane on the diagonal that runs forward and diagonal to the sea plane mounts. The Antenna was in the center of the ground plane. I ran the cable to the right, then up the vertical tube of the frame then diagonally down and forward to the sea plane mount area. I put the ELT directly under the baggage compartment. The Monitor terminal cable ran up the vertical tube at the sea plane mount, behind the rear window frame, then over the frame, past the electrical junction box. Then I put the enunciator terminal just aft of the fuel gauge. I forgot the manufacturer of the ELT and the model. I put it in a safe place, in the glove box in the airplane. If the photos don't come through, send me another Email address.
'On ?Wednesday?, ?August? ?15?, ?2018? ?12?:?53?:?39? ?AM? ?PDT, craig31756@aol.com [fairchildclub] wrote:
Craig Stone
N81204
F24R46
#yiv8521724554 #yiv8521724554 -- #yiv8521724554ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv8521724554 #yiv8521724554ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv8521724554 #yiv8521724554ygrp-mkp #yiv8521724554hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv8521724554 #yiv8521724554ygrp-mkp #yiv8521724554ads {margin-bottom:10px;}#yiv8521724554 #yiv8521724554ygrp-mkp .yiv8521724554ad {padding:0 0;}#yiv8521724554 #yiv8521724554ygrp-mkp .yiv8521724554ad p {margin:0;}#yiv8521724554 #yiv8521724554ygrp-mkp .yiv8521724554ad a {color:#0000ff;text-decoration:none;}#yiv8521724554 #yiv8521724554ygrp-sponsor #yiv8521724554ygrp-lc {font-family:Arial;}#yiv8521724554 #yiv8521724554ygrp-sponsor #yiv8521724554ygrp-lc #yiv8521724554hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv8521724554 #yiv8521724554ygrp-sponsor #yiv8521724554ygrp-lc .yiv8521724554ad {margin-bottom:10px;padding:0 0;}#yiv8521724554 #yiv8521724554actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv8521724554 #yiv8521724554activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv8521724554 #yiv8521724554activity span {font-weight:700;}#yiv8521724554 #yiv8521724554activity span:first-child {text-transform:uppercase;}#yiv8521724554 #yiv8521724554activity span a {color:#5085b6;text-decoration:none;}#yiv8521724554 #yiv8521724554activity span span {color:#ff7900;}#yiv8521724554 #yiv8521724554activity span .yiv8521724554underline {text-decoration:underline;}#yiv8521724554 .yiv8521724554attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv8521724554 .yiv8521724554attach div a {text-decoration:none;}#yiv8521724554 .yiv8521724554attach img {border:none;padding-right:5px;}#yiv8521724554 .yiv8521724554attach label {display:block;margin-bottom:5px;}#yiv8521724554 .yiv8521724554attach label a {text-decoration:none;}#yiv8521724554 blockquote {margin:0 0 0 4px;}#yiv8521724554 .yiv8521724554bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv8521724554 .yiv8521724554bold a {text-decoration:none;}#yiv8521724554 dd.yiv8521724554last p a {font-family:Verdana;font-weight:700;}#yiv8521724554 dd.yiv8521724554last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv8521724554 dd.yiv8521724554last p span.yiv8521724554yshortcuts {margin-right:0;}#yiv8521724554 div.yiv8521724554attach-table div div a {text-decoration:none;}#yiv8521724554 div.yiv8521724554attach-table {width:400px;}#yiv8521724554 div.yiv8521724554file-title a, #yiv8521724554 div.yiv8521724554file-title a:active, #yiv8521724554 div.yiv8521724554file-title a:hover, #yiv8521724554 div.yiv8521724554file-title a:visited {text-decoration:none;}#yiv8521724554 div.yiv8521724554photo-title a, #yiv8521724554 div.yiv8521724554photo-title a:active, #yiv8521724554 div.yiv8521724554photo-title a:hover, #yiv8521724554 div.yiv8521724554photo-title a:visited {text-decoration:none;}#yiv8521724554 div#yiv8521724554ygrp-mlmsg #yiv8521724554ygrp-msg p a span.yiv8521724554yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv8521724554 .yiv8521724554green {color:#628c2a;}#yiv8521724554 .yiv8521724554MsoNormal {margin:0 0 0 0;}#yiv8521724554 o {font-size:0;}#yiv8521724554 #yiv8521724554photos div {float:left;width:72px;}#yiv8521724554 #yiv8521724554photos div div {border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}#yiv8521724554 #yiv8521724554photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv8521724554 #yiv8521724554reco-category {font-size:77%;}#yiv8521724554 #yiv8521724554reco-desc {font-size:77%;}#yiv8521724554 .yiv8521724554replbq {margin:4px;}#yiv8521724554 #yiv8521724554ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv8521724554 #yiv8521724554ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv8521724554 #yiv8521724554ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv8521724554 #yiv8521724554ygrp-mlmsg select, #yiv8521724554 input, #yiv8521724554 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv8521724554 #yiv8521724554ygrp-mlmsg pre, #yiv8521724554 code {font:115% monospace;}#yiv8521724554 #yiv8521724554ygrp-mlmsg * {line-height:1.22em;}#yiv8521724554 #yiv8521724554ygrp-mlmsg #yiv8521724554logo {padding-bottom:10px;}#yiv8521724554 #yiv8521724554ygrp-msg p a {font-family:Verdana;}#yiv8521724554 #yiv8521724554ygrp-msg p#yiv8521724554attach-count span {color:#1E66AE;font-weight:700;}#yiv8521724554 #yiv8521724554ygrp-reco #yiv8521724554reco-head {color:#ff7900;font-weight:700;}#yiv8521724554 #yiv8521724554ygrp-reco {margin-bottom:20px;padding:0px;}#yiv8521724554 #yiv8521724554ygrp-sponsor #yiv8521724554ov li a {font-size:130%;text-decoration:none;}#yiv8521724554 #yiv8521724554ygrp-sponsor #yiv8521724554ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv8521724554 #yiv8521724554ygrp-sponsor #yiv8521724554ov ul {margin:0;padding:0 0 0 8px;}#yiv8521724554 #yiv8521724554ygrp-text {font-family:Georgia;}#yiv8521724554 #yiv8521724554ygrp-text p {margin:0 0 1em 0;}#yiv8521724554 #yiv8521724554ygrp-text tt {font-size:120%;}#yiv8521724554 #yiv8521724554ygrp-vital ul li:last-child {border-right:none !important;}#yiv8521724554
| | Virus-free. www.avast.com |
Re: ELTs
'I haven't heard from you in a long time. How is you landing gear issues coming? I haven't been getting much done one the airplane. Had the tail wheel tube give up the ghost, and went to Dresser and bought a new tire and tube. Love it. The tire was Chinese and the tube was Polish. I thought I had real issues. When I added air to the tube, the stem was pulled inside the wheel opening. My attitude went to hell real quick. Went to the house and got something really cold to drink (Not the good stuff) and thought about it. It worked, cooled my brain down....NAPA to the rescue. Valve stem extensions. Saw the local store was still open, so 5 minutes, and a couple dollars, and I had 2 3/4" extensions. One to extend the stem to the edge of the opening for the valve stem and the other one in series to get it out to where I can put air into the tube. Once I was done, I removed the second extension and put it into the glove box for future use. I have my ELT installed under and behind the baggage compartment and a simple transceiver. I am going to put a GPS up where the old radio once was.
'On ?Wednesday?, ?August? ?15?, ?2018? ?09?:?04?:?31? ?AM? ?PDT, JP jp.lorie@yahoo.com [fairchildclub] wrote:
JP
Sent from my iPad
Craig Stone
N81204
F24R46
#yiv2553117060 #yiv2553117060 -- #yiv2553117060ygrp-mkp {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}#yiv2553117060 #yiv2553117060ygrp-mkp hr {border:1px solid #d8d8d8;}#yiv2553117060 #yiv2553117060ygrp-mkp #yiv2553117060hd {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}#yiv2553117060 #yiv2553117060ygrp-mkp #yiv2553117060ads {margin-bottom:10px;}#yiv2553117060 #yiv2553117060ygrp-mkp .yiv2553117060ad {padding:0 0;}#yiv2553117060 #yiv2553117060ygrp-mkp .yiv2553117060ad p {margin:0;}#yiv2553117060 #yiv2553117060ygrp-mkp .yiv2553117060ad a {color:#0000ff;text-decoration:none;}#yiv2553117060 #yiv2553117060ygrp-sponsor #yiv2553117060ygrp-lc {font-family:Arial;}#yiv2553117060 #yiv2553117060ygrp-sponsor #yiv2553117060ygrp-lc #yiv2553117060hd {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}#yiv2553117060 #yiv2553117060ygrp-sponsor #yiv2553117060ygrp-lc .yiv2553117060ad {margin-bottom:10px;padding:0 0;}#yiv2553117060 #yiv2553117060actions {font-family:Verdana;font-size:11px;padding:10px 0;}#yiv2553117060 #yiv2553117060activity {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}#yiv2553117060 #yiv2553117060activity span {font-weight:700;}#yiv2553117060 #yiv2553117060activity span:first-child {text-transform:uppercase;}#yiv2553117060 #yiv2553117060activity span a {color:#5085b6;text-decoration:none;}#yiv2553117060 #yiv2553117060activity span span {color:#ff7900;}#yiv2553117060 #yiv2553117060activity span .yiv2553117060underline {text-decoration:underline;}#yiv2553117060 .yiv2553117060attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}#yiv2553117060 .yiv2553117060attach div a {text-decoration:none;}#yiv2553117060 .yiv2553117060attach img {border:none;padding-right:5px;}#yiv2553117060 .yiv2553117060attach label {display:block;margin-bottom:5px;}#yiv2553117060 .yiv2553117060attach label a {text-decoration:none;}#yiv2553117060 blockquote {margin:0 0 0 4px;}#yiv2553117060 .yiv2553117060bold {font-family:Arial;font-size:13px;font-weight:700;}#yiv2553117060 .yiv2553117060bold a {text-decoration:none;}#yiv2553117060 dd.yiv2553117060last p a {font-family:Verdana;font-weight:700;}#yiv2553117060 dd.yiv2553117060last p span {margin-right:10px;font-family:Verdana;font-weight:700;}#yiv2553117060 dd.yiv2553117060last p span.yiv2553117060yshortcuts {margin-right:0;}#yiv2553117060 div.yiv2553117060attach-table div div a {text-decoration:none;}#yiv2553117060 div.yiv2553117060attach-table {width:400px;}#yiv2553117060 div.yiv2553117060file-title a, #yiv2553117060 div.yiv2553117060file-title a:active, #yiv2553117060 div.yiv2553117060file-title a:hover, #yiv2553117060 div.yiv2553117060file-title a:visited {text-decoration:none;}#yiv2553117060 div.yiv2553117060photo-title a, #yiv2553117060 div.yiv2553117060photo-title a:active, #yiv2553117060 div.yiv2553117060photo-title a:hover, #yiv2553117060 div.yiv2553117060photo-title a:visited {text-decoration:none;}#yiv2553117060 div#yiv2553117060ygrp-mlmsg #yiv2553117060ygrp-msg p a span.yiv2553117060yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;}#yiv2553117060 .yiv2553117060green {color:#628c2a;}#yiv2553117060 .yiv2553117060MsoNormal {margin:0 0 0 0;}#yiv2553117060 o {font-size:0;}#yiv2553117060 #yiv2553117060photos div {float:left;width:72px;}#yiv2553117060 #yiv2553117060photos div div {border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;}#yiv2553117060 #yiv2553117060photos div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}#yiv2553117060 #yiv2553117060reco-category {font-size:77%;}#yiv2553117060 #yiv2553117060reco-desc {font-size:77%;}#yiv2553117060 .yiv2553117060replbq {margin:4px;}#yiv2553117060 #yiv2553117060ygrp-actbar div a:first-child {margin-right:2px;padding-right:5px;}#yiv2553117060 #yiv2553117060ygrp-mlmsg {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}#yiv2553117060 #yiv2553117060ygrp-mlmsg table {font-size:inherit;font:100%;}#yiv2553117060 #yiv2553117060ygrp-mlmsg select, #yiv2553117060 input, #yiv2553117060 textarea {font:99% Arial, Helvetica, clean, sans-serif;}#yiv2553117060 #yiv2553117060ygrp-mlmsg pre, #yiv2553117060 code {font:115% monospace;}#yiv2553117060 #yiv2553117060ygrp-mlmsg * {line-height:1.22em;}#yiv2553117060 #yiv2553117060ygrp-mlmsg #yiv2553117060logo {padding-bottom:10px;}#yiv2553117060 #yiv2553117060ygrp-msg p a {font-family:Verdana;}#yiv2553117060 #yiv2553117060ygrp-msg p#yiv2553117060attach-count span {color:#1E66AE;font-weight:700;}#yiv2553117060 #yiv2553117060ygrp-reco #yiv2553117060reco-head {color:#ff7900;font-weight:700;}#yiv2553117060 #yiv2553117060ygrp-reco {margin-bottom:20px;padding:0px;}#yiv2553117060 #yiv2553117060ygrp-sponsor #yiv2553117060ov li a {font-size:130%;text-decoration:none;}#yiv2553117060 #yiv2553117060ygrp-sponsor #yiv2553117060ov li {font-size:77%;list-style-type:square;padding:6px 0;}#yiv2553117060 #yiv2553117060ygrp-sponsor #yiv2553117060ov ul {margin:0;padding:0 0 0 8px;}#yiv2553117060 #yiv2553117060ygrp-text {font-family:Georgia;}#yiv2553117060 #yiv2553117060ygrp-text p {margin:0 0 1em 0;}#yiv2553117060 #yiv2553117060ygrp-text tt {font-size:120%;}#yiv2553117060 #yiv2553117060ygrp-vital ul li:last-child {border-right:none !important;}#yiv2553117060
