I am working on a 1946 F24 Fairchild restoration and I need some decorative aluminum 18 gauge sheet metal for the door pan and door step and kick guard on cockpit interior. I cannot find the pattern to match the few original pieces I have. Anyone have a supplier? I would post a picture here if I could. If anyone has an idea I can send the picture of the pattern to you directly.
Thanks for your help!'
Re: Decorative Aluminum sheet metal
Matthew & Patricia Banks
' I found a perfect match for the diamond pattern aluminum ... as I recall I sourced it from McMaster Carr. Unfortunately I don't recall the exact specifics as that was many years ago. It was the smaller pattern they offer. I'm sure if you dig around their catalog you can figure it out.
MattF24 - N4263S
MattF24 - N4263S
On Monday, February 5, 2018, 4:33:28 PM EST, darryln29@gmail.com [fairchildclub] wrote:
jstreat360
'Darryln, The company that manufactured the Diamond Plate Trim is: Rigidzed (Step metal) Rigidized Metals Corporation, 658 Ohio Street Buffalo, NY 14203 Toll Free: (800) 836-2580 Fax: (716) 849-0401 Local: (716) 849-4760 http://www.rigidized.com The Sales Person I worked with was David M Smith. Don’t know if he is still there. Here is the problem. They only sell in larger quantities. You can try and see if they will run one 4 x 8 sheet. 15+ years ago I had 8 sheets run. They pulled the rolling dies out of long term storage (last run was 1940) for us. I sold all the 4 x 4 sheets to FC owners/rebuilders all over the USA. There is most likely one or more of the members that still have some stock left over. I know one owner that has a 4 X 4 Sheet in Fla. A 4 x 4 sheet will do at least two F24s, more most likely. Depending on which factory built your bird (KS, TX, NJ) there are two patterns used. One is the dot pattern (TX), not as common. The other is the raised Diamond. I believe the P/N is RLW-1. The RL stands for Raymond Loewy. https://www.raymondloewy.com Raymond was a designer that Mr. Fairchild used for paint schemes and interior appointments. The diamond plate pattern was used on the inside of 1930/40s Coca Cola Coolers. Mr. Loewy designed them for the Coca Cola Company. Just a little history. JST Jamie S. Treat A&P/IA
Fairchild Club DVD Editor
IAC 5, Chapter President
http://www.iac5.org
Elbert, CO 80106 Hm 303-648-0130
Cell 303-304-7937New Email: JamieTreat397@gmail.com AR&R LLC Drop Box: ARR Dropbox Link Quote of the Month: Never fly anything that doesn't have the paint worn off the Rudder Pedals. - Harry Bill From: jamietreat [jamietreat@Q.com]
Sent: Monday, February 5, 2018 4:34 PM
To: jamietreat397@gmail.com
Subject: Fwd: [fairchildclub] Decorative Aluminum sheet metal Sent via the Samsung Galaxy S7, an AT&T 4G LTE smartphone -------- Original message --------From: "darryln29@gmail.com%20[fairchildclub]" < > Date: 2/5/18 2:30 PM (GMT-07:00) To: fairchildclub@yahoogroups.com Subject: [fairchildclub] Decorative Aluminum sheet metal
http://www.iac5.org
Hugh Loewenhardt
'Thanks Jamie for the good, useful technical information and a Fairchild history lesson.
Hugh L
On Monday, February 5, 2018 7:32 PM, "jamietreat397@gmail.com [fairchildclub]" wrote:
http://www.iac5.org
Subject: Fwd: [fairchildclub] Decorative Aluminum sheet metal Sent via the Samsung Galaxy S7, an AT&T 4G LTE smartphone -------- Original message --------From: "darryln29@gmail.com%20[fairchildclub]" < > Date: 2/5/18 2:30 PM (GMT-07:00) To: fairchildclub@yahoogroups.com Subject: [fairchildclub] Decorative Aluminum sheet metal I am working on a 1946 F24 Fairchild restoration and I need some decorative aluminum 18 gauge sheet metal for the door pan and door step and kick guard on cockpit interior. I cannot find the pattern to match the few original pieces I have. Anyone have a supplier? I would post a picture here if I could. If anyone has an idea I can send the picture of the pattern to you directly. Thanks for your help! #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723 -- #ygrps-yiv-1294487448yiv1115820723ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mkp #ygrps-yiv-1294487448yiv1115820723hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mkp #ygrps-yiv-1294487448yiv1115820723ads { margin-bottom:10px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mkp .ygrps-yiv-1294487448yiv1115820723ad { padding:0 0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mkp .ygrps-yiv-1294487448yiv1115820723ad p { margin:0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mkp .ygrps-yiv-1294487448yiv1115820723ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-sponsor #ygrps-yiv-1294487448yiv1115820723ygrp-lc { font-family:Arial;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-sponsor #ygrps-yiv-1294487448yiv1115820723ygrp-lc #ygrps-yiv-1294487448yiv1115820723hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-sponsor #ygrps-yiv-1294487448yiv1115820723ygrp-lc .ygrps-yiv-1294487448yiv1115820723ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723activity span { font-weight:700;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723activity span span { color:#ff7900;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723activity span .ygrps-yiv-1294487448yiv1115820723underline { text-decoration:underline;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723attach div a { text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723attach img { border:none;padding-right:5px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723attach label a { text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723bold a { text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 dd.ygrps-yiv-1294487448yiv1115820723last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 dd.ygrps-yiv-1294487448yiv1115820723last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 dd.ygrps-yiv-1294487448yiv1115820723last p span.ygrps-yiv-1294487448yiv1115820723yshortcuts { margin-right:0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723attach-table div div a { text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723attach-table { width:400px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723file-title a, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723file-title a:active, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723file-title a:hover, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723file-title a:visited { text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723photo-title a, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723photo-title a:active, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723photo-title a:hover, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div.ygrps-yiv-1294487448yiv1115820723photo-title a:visited { text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 div#ygrps-yiv-1294487448yiv1115820723ygrp-mlmsg #ygrps-yiv-1294487448yiv1115820723ygrp-msg p a span.ygrps-yiv-1294487448yiv1115820723yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723green { color:#628c2a;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 o { font-size:0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723photos div { float:left;width:72px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723photos div div { border:1px solid #666666;min-height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723reco-category { font-size:77%;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723reco-desc { font-size:77%;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 .ygrps-yiv-1294487448yiv1115820723replbq { margin:4px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mlmsg select, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 input, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mlmsg pre, #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 code { font:115% monospace;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-mlmsg #ygrps-yiv-1294487448yiv1115820723logo { padding-bottom:10px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-msg p#ygrps-yiv-1294487448yiv1115820723attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-reco #ygrps-yiv-1294487448yiv1115820723reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-sponsor #ygrps-yiv-1294487448yiv1115820723ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-sponsor #ygrps-yiv-1294487448yiv1115820723ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-sponsor #ygrps-yiv-1294487448yiv1115820723ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-text { font-family:Georgia;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-text tt { font-size:120%;} #ygrps-yiv-1294487448 #ygrps-yiv-1294487448yiv1115820723 #ygrps-yiv-1294487448yiv1115820723ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1294487448
Hugh L
http://www.iac5.org
