Good Morning!  I am a new member to this forum.  I purchased PT 19 N60109 in October 2017.  I have tried to remove the propeller to send to Sensenich for balancing and refinishing.  I removed the clevis pin from the large nut and removed the prop nut using a 4' 7/8" breaker bar, (no issues).  However, at this point I am unable to determine my next step.  I have read other comments regarding prop removal but am confused how to proceed.  I have a number of service manuals relating to the PT, but cannot reference any step instructions or tutorials on this subject.  I have read, on this Forum, that by removing the large prop nut the prop should back away and off the prop shaft, is this correct? I removed the large prop nut, the prop hub did not budge.   Any help will be appreciated.
Thanks in advance,
Michael Drebo
gdrebo@yahoo.com
832 691-0911
						Re: PT 19 Propeller Removal
'If the nut didn't pull the prop hub off the shaft that means it doesn't have the snap ring installed that goes in the groove on the nut and in the hub.  Not an issue other than it does help in removal.
My first PT came that way and I ended up, eventually finding and installing a snap ring. But for the first prop removal I recall we just worked the prop off by wiggling each prop end to free the hub on the splines.
Curt
Curt
Thanks in advance,
Michael Drebo
gdrebo@yahoo.com
832 691-0911
				gdrebo@yahoo.com
'Curt,
Thanks for the explanation. It is starting to make sense to me. Do you happen to have a source/AN # for snap ring?
Michael Drebo832 691-0911
'They used to be fairly common at prop shops, but I don't know how many are hanging about.   Maybe check with Air Repair.  I put the hub AN spec in the group files, but don't recall if the snap ring is called out.
						'On Feb 4, 2018 1:55 PM, "gdrebo@yahoo.com [fairchildclub]" wrote:
Curt,
I think I have the specs for all the hubs, cones, spacers, nuts and snap rings on my computer at work. I'll check tonight when I get in and can post the info in the morning when I get home.
Craig Cantwell
AT-21 S/N 42-48053
Craig Cantwell
AT-21 S/N 42-48053
Curt,
Thanks for the explanation.. It is starting to make sense to me. Do you happen to have a source/AN # for snap ring?
Michael Drebo 832 691-0911
				Michael Kelly
'Mike:
If you had a snap rin, that holds the prop nut in the hub. Turning the nut to loosen it then acts like a pully puller and backs the hub off the shaft.
Keep 'Em Flying!
Mike Kelly
________________________________________
Sent: Sunday, February 4, 2018 11:26 AM
Subject: [fairchildclub] PT 19 Propeller Removal
Thanks in advance,
Michael Drebo
gdrebo@yahoo.com
832 691-0911'
Keep 'Em Flying!
Mike Kelly
Thanks in advance,
Michael Drebo
gdrebo@yahoo.com
832 691-0911'
				Terry Gardner
'it is not just the snap ring! the hub may be the kind that does not use one . also the nut must have the groove as well as the hub for the snap ring. look on the hub for a tag " Warner and the number"one type uses the snap ring one doesn't[ I think the 79XX uses the snap; the 85..or 88.. doesn't]. I may have both for the warner that uses the long nut with the snap ring. If you have the short nut I do not have either. the nut without the groove may be used for either snap or no snap but for a snap ring both hub and nut must have the groove use the snap rig . the hub will also have a split front cone that is kept in place by the ring and the one that doesn't have the snap and groove do not use a front cone[talking about warner hubs only]. make sure to put a small amount of shell #5 great on the spline before replacing the prop and lightning.Thread lube ask also.
I think fresno is out of the nuts and rings.
'On Sun, 2/4/18, Curt Kinchen ptcurt@gmail.com [fairchildclub] wrote:
Subject: Re: [fairchildclub] PT 19 Propeller Removal
Date: Sunday, February 4, 2018, 1:37 PM
called out.
"gdrebo@yahoo.com
Curt,
#yiv2170142835 #yiv2170142835 --
#yiv2170142835ygrp-mkp {
border:1px solid #d8d8d8;font-family:Arial;margin:10px
0;padding:0 10px;}
#yiv2170142835 #yiv2170142835ygrp-mkp hr {
border:1px solid #d8d8d8;}
#yiv2170142835 #yiv2170142835ygrp-mkp #yiv2170142835hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px
0;}
#yiv2170142835 #yiv2170142835ygrp-mkp #yiv2170142835ads {
margin-bottom:10px;}
#yiv2170142835 #yiv2170142835ygrp-mkp .yiv2170142835ad {
padding:0 0;}
#yiv2170142835 #yiv2170142835ygrp-mkp .yiv2170142835ad p {
margin:0;}
#yiv2170142835 #yiv2170142835ygrp-mkp .yiv2170142835ad a {
color:#0000ff;text-decoration:none;}
#yiv2170142835 #yiv2170142835ygrp-sponsor
#yiv2170142835ygrp-lc {
font-family:Arial;}
#yiv2170142835ygrp-lc #yiv2170142835hd {
margin:10px
0px;font-weight:700;font-size:78%;line-height:122%;}
#yiv2170142835ygrp-lc .yiv2170142835ad {
margin-bottom:10px;padding:0 0;}
#yiv2170142835 #yiv2170142835actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#yiv2170142835 #yiv2170142835activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#yiv2170142835 #yiv2170142835activity span {
font-weight:700;}
#yiv2170142835 #yiv2170142835activity span:first-child {
text-transform:uppercase;}
#yiv2170142835 #yiv2170142835activity span a {
color:#5085b6;text-decoration:none;}
#yiv2170142835 #yiv2170142835activity span span {
color:#ff7900;}
.yiv2170142835underline {
text-decoration:underline;}
#yiv2170142835 .yiv2170142835attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px
0;width:400px;}
#yiv2170142835 .yiv2170142835attach div a {
#yiv2170142835 .yiv2170142835attach img {
border:none;padding-right:5px;}
#yiv2170142835 .yiv2170142835attach label {
display:block;margin-bottom:5px;}
#yiv2170142835 .yiv2170142835attach label a {
#yiv2170142835 blockquote {
margin:0 0 0 4px;}
#yiv2170142835 .yiv2170142835bold {
font-family:Arial;font-size:13px;font-weight:700;}
#yiv2170142835 .yiv2170142835bold a {
#yiv2170142835 dd.yiv2170142835last p a {
font-family:Verdana;font-weight:700;}
#yiv2170142835 dd.yiv2170142835last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
span.yiv2170142835yshortcuts {
margin-right:0;}
#yiv2170142835 div.yiv2170142835attach-table div div a {
#yiv2170142835 div.yiv2170142835attach-table {
width:400px;}
#yiv2170142835 div.yiv2170142835file-title a, #yiv2170142835
div.yiv2170142835file-title a:active, #yiv2170142835
div.yiv2170142835file-title a:hover, #yiv2170142835
div.yiv2170142835file-title a:visited {
#yiv2170142835 div.yiv2170142835photo-title a,
#yiv2170142835 div.yiv2170142835photo-title a:active,
#yiv2170142835 div.yiv2170142835photo-title a:hover,
#yiv2170142835 div.yiv2170142835photo-title a:visited {
#yiv2170142835 div#yiv2170142835ygrp-mlmsg
#yiv2170142835ygrp-msg p a span.yiv2170142835yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#yiv2170142835 .yiv2170142835green {
color:#628c2a;}
#yiv2170142835 .yiv2170142835MsoNormal {
margin:0 0 0 0;}
#yiv2170142835 o {
font-size:0;}
#yiv2170142835 #yiv2170142835photos div {
float:left;width:72px;}
#yiv2170142835 #yiv2170142835photos div div {
border:1px solid
#666666;min-height:62px;overflow:hidden;width:62px;}
#yiv2170142835 #yiv2170142835photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#yiv2170142835 #yiv2170142835reco-category {
font-size:77%;}
#yiv2170142835 #yiv2170142835reco-desc {
font-size:77%;}
#yiv2170142835 .yiv2170142835replbq {
margin:4px;}
#yiv2170142835 #yiv2170142835ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#yiv2170142835 #yiv2170142835ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean,
sans-serif;}
#yiv2170142835 #yiv2170142835ygrp-mlmsg table {
font-size:inherit;font:100%;}
#yiv2170142835 #yiv2170142835ygrp-mlmsg select,
#yiv2170142835 input, #yiv2170142835 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#yiv2170142835 #yiv2170142835ygrp-mlmsg pre, #yiv2170142835
code {
font:115% monospace;}
#yiv2170142835 #yiv2170142835ygrp-mlmsg * {
line-height:1.22em;}
#yiv2170142835 #yiv2170142835ygrp-mlmsg #yiv2170142835logo {
padding-bottom:10px;}
#yiv2170142835 #yiv2170142835ygrp-msg p a {
font-family:Verdana;}
p#yiv2170142835attach-count span {
color:#1E66AE;font-weight:700;}
#yiv2170142835 #yiv2170142835ygrp-reco
#yiv2170142835reco-head {
color:#ff7900;font-weight:700;}
#yiv2170142835 #yiv2170142835ygrp-reco {
margin-bottom:20px;padding:0px;}
#yiv2170142835 #yiv2170142835ygrp-sponsor #yiv2170142835ov
li a {
font-size:130%;text-decoration:none;}
li {
font-size:77%;list-style-type:square;padding:6px 0;}
ul {
margin:0;padding:0 0 0 8px;}
#yiv2170142835 #yiv2170142835ygrp-text {
font-family:Georgia;}
#yiv2170142835 #yiv2170142835ygrp-text p {
margin:0 0 1em 0;}
#yiv2170142835 #yiv2170142835ygrp-text tt {
font-size:120%;}
#yiv2170142835 #yiv2170142835ygrp-vital ul li:last-child {
border-right:none !important;
#yiv2170142835
				George Michael Drebo
'All,
Thanks for the great information! The prop nut does have the groove to accept the snap ring, but no snap ring is present. I’m going to the airport later this week and will inspect the hub for the matching groove and tag name and number. As Curt explained, I will attempt to wiggle the prop from the spline. I appreciate all the help.
Michael Drebo
832 691-0911
Michael Drebo
832 691-0911
Date: Monday, February 5, 2018, 1:15 PM
lube ask also.
[fairchildclub]
about.
in
is
called out.
"gdrebo@yahoo.com
Curt,
0;padding:0 10px;}
0;}
padding:0 0;}
margin:0;}
font-family:Arial;}
margin:10px
font-weight:700;}
color:#ff7900;}
0;width:400px;}
margin:0 0 0 4px;}
margin-right:0;}
width:400px;}
#yiv2170142835
color:#628c2a;}
margin:0 0 0 0;}
#yiv2170142835 o {
font-size:0;}
border:1px solid
font-size:77%;}
font-size:77%;}
margin:4px;}
sans-serif;}
#yiv2170142835
code {
#yiv2170142835ov
li a {
#yiv2170142835ov
li {
#yiv2170142835ov
ul {
margin:0 0 1em 0;}
font-size:120%;}
#yiv2170142835
#yiv8406848842 #yiv8406848842 --
#yiv8406848842ygrp-mkp {
0;padding:0 10px;}
#yiv8406848842 #yiv8406848842ygrp-mkp hr {
#yiv8406848842 #yiv8406848842ygrp-mkp #yiv8406848842hd {
0;}
#yiv8406848842 #yiv8406848842ygrp-mkp #yiv8406848842ads {
#yiv8406848842 #yiv8406848842ygrp-mkp .yiv8406848842ad {
padding:0 0;}
#yiv8406848842 #yiv8406848842ygrp-mkp .yiv8406848842ad p {
margin:0;}
#yiv8406848842 #yiv8406848842ygrp-mkp .yiv8406848842ad a {
#yiv8406848842 #yiv8406848842ygrp-sponsor
#yiv8406848842ygrp-lc {
font-family:Arial;}
#yiv8406848842ygrp-lc #yiv8406848842hd {
margin:10px
#yiv8406848842ygrp-lc .yiv8406848842ad {
#yiv8406848842 #yiv8406848842actions {
#yiv8406848842 #yiv8406848842activity {
#yiv8406848842 #yiv8406848842activity span {
font-weight:700;}
#yiv8406848842 #yiv8406848842activity span:first-child {
#yiv8406848842 #yiv8406848842activity span a {
#yiv8406848842 #yiv8406848842activity span span {
color:#ff7900;}
.yiv8406848842underline {
#yiv8406848842 .yiv8406848842attach {
0;width:400px;}
#yiv8406848842 .yiv8406848842attach div a {
#yiv8406848842 .yiv8406848842attach img {
#yiv8406848842 .yiv8406848842attach label {
#yiv8406848842 .yiv8406848842attach label a {
#yiv8406848842 blockquote {
margin:0 0 0 4px;}
#yiv8406848842 .yiv8406848842bold {
#yiv8406848842 .yiv8406848842bold a {
#yiv8406848842 dd.yiv8406848842last p a {
#yiv8406848842 dd.yiv8406848842last p span {
span.yiv8406848842yshortcuts {
margin-right:0;}
#yiv8406848842 div.yiv8406848842attach-table div div a {
#yiv8406848842 div.yiv8406848842attach-table {
width:400px;}
#yiv8406848842 div.yiv8406848842file-title a, #yiv8406848842
div.yiv8406848842file-title a:active, #yiv8406848842
div.yiv8406848842file-title a:hover, #yiv8406848842
div.yiv8406848842file-title a:visited {
#yiv8406848842 div.yiv8406848842photo-title a,
#yiv8406848842 div.yiv8406848842photo-title a:active,
#yiv8406848842 div.yiv8406848842photo-title a:hover,
#yiv8406848842 div.yiv8406848842photo-title a:visited {
#yiv8406848842 div#yiv8406848842ygrp-mlmsg
#yiv8406848842ygrp-msg p a span.yiv8406848842yshortcuts {
#yiv8406848842 .yiv8406848842green {
color:#628c2a;}
#yiv8406848842 .yiv8406848842MsoNormal {
margin:0 0 0 0;}
#yiv8406848842 o {
font-size:0;}
#yiv8406848842 #yiv8406848842photos div {
#yiv8406848842 #yiv8406848842photos div div {
border:1px solid
#yiv8406848842 #yiv8406848842photos div label {
#yiv8406848842 #yiv8406848842reco-category {
font-size:77%;}
#yiv8406848842 #yiv8406848842reco-desc {
font-size:77%;}
#yiv8406848842 .yiv8406848842replbq {
margin:4px;}
#yiv8406848842 #yiv8406848842ygrp-actbar div a:first-child {
#yiv8406848842 #yiv8406848842ygrp-mlmsg {
sans-serif;}
#yiv8406848842 #yiv8406848842ygrp-mlmsg table {
#yiv8406848842 #yiv8406848842ygrp-mlmsg select,
#yiv8406848842 input, #yiv8406848842 textarea {
#yiv8406848842 #yiv8406848842ygrp-mlmsg pre, #yiv8406848842
code {
#yiv8406848842 #yiv8406848842ygrp-mlmsg * {
#yiv8406848842 #yiv8406848842ygrp-mlmsg #yiv8406848842logo {
#yiv8406848842 #yiv8406848842ygrp-msg p a {
p#yiv8406848842attach-count span {
#yiv8406848842 #yiv8406848842ygrp-reco
#yiv8406848842reco-head {
#yiv8406848842 #yiv8406848842ygrp-reco {
#yiv8406848842 #yiv8406848842ygrp-sponsor #yiv8406848842ov
li a {
li {
ul {
#yiv8406848842 #yiv8406848842ygrp-text {
#yiv8406848842 #yiv8406848842ygrp-text p {
margin:0 0 1em 0;}
#yiv8406848842 #yiv8406848842ygrp-text tt {
font-size:120%;}
#yiv8406848842 #yiv8406848842ygrp-vital ul li:last-child {
#yiv8406848842
