ds
On Nov 6, 2017, at 9:59 AM, Steve Link steven_link@msn.com [fairchildclub] wrote:
Dang, I've read and reread the manual.....can't find where it says to replace the plug.
Not that I am doubting you, as it only makes sense to eventually vent the system. Just wondered where they hid it in all the procedures.
I'm going to get a solid plug tonight. Is it 1/2"? I can't remember and the hangar is 30 miles away!!!
Thanks for all the help!!!!!!!!!!!!!!!!!!
From: fairchildclub@yahoogroups.com on behalf of Steve Link steven_link@msn.com [fairchildclub]
Sent: Monday, November 6, 2017 5:47 AM
Subject: RE: [fairchildclub] Re: PT Brakes
Thanks, that is what I thought might be the case…. As stated on my e-mail yesterday I used Rockauto Raybestos MK-190 kits, my Cyl. Are 1”. Thanks so much for the clarification!!!!!!!!!!!!!!!!!!!!!!!!!!!! Steve in OK… From: fairchildclub@yahoogroups.com [fairchildclub@yahoogroups.com]
Sent: Monday, November 06, 2017 5:28 AM
Subject: Re: [fairchildclub] Re: PT Brakes The pressurization is used only to assist bleeding the brakes, it helps especially in getting the air out of the cylinder. After the brakes are bled completely and the bleeder valve is closed, top off the reservoir and replace the pipe plug...this is explained in the Fairchild maintenance manual. The problem I have is finding a rebuild kit....NAPA does not have it or at least could not identify it by the Wagner part number. ds
On Nov 6, 2017, at 6:17 AM, Steve Link steven_link@msn.com [fairchildclub] wrote:
I understand that, like I said the pipe plug is vented so the system cannot be pressurized.
Is that something that is done after pressurization? Swap plugs out? Is it pressurized all the time and I need to put a solid pipe plug in? I could find nothing in the T.O on pressurizing the system AFTER bleeding. From: fairchildclub@yahoogroups.com on behalf of wsknettl@centurytel.net [fairchildclub]
Sent: Monday, November 6, 2017 12:13 AM
Subject: [fairchildclub] Re: PT Brakes The master cylinder reservoir cap should have a pipe plug and a pressure valve stem. Here's a photo: http://willysmjeeps.com/v2/modules/gallery/albums/album535/DSC05645_sm.sized.jpg [url=https://eur03.safelinks..protection.outlook.com/?url=http%3A%2F%2Fwillysmjeeps.com%2Fv2%2Fmodules%2Fgallery%2Falbums%2Falbum535%2FDSC05645_sm.sized.jpg&data=02%7C01%7Csteven_link%40msn.com%7C505ed669e4854495b7ff08d524dd731c%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C636455455895145372&sdata=v76nHIikIeSFJD2u0Yr%2FuxH5NlCFNhTdFU1Bgld%2F7EM%3D&reserved=0][/url] http://willysmjeeps.com/v2/modules/gallery/albums/album5... View on willysmjeeps.com Preview by Yahoo
