'Folks
I note in TCDS A706 for the F24 which includes the UC61K that the Gross weight is is limited to 2550lbs. but that the performance tables at the back of the 'Pilots Operating Instructions' for the UC61K show figures for 2882lbs.
I cannot find any other reference to this higher military gross weight. Does anyone know where I might find a more definitive statement? The flexibility offered by going beyond 2550lbs could be useful and keep things legal.
Many thanks
(Argus III/UC61K G-BCBL)'
Re: F24 R46/UC61K Gross Weight
Jamie Treat
'Frank,
The TCDS A-706 is for the Civilian version of the F-24. The US Mil did not need it since they deliver by Mil Spec.
Updates to the TCDS included the UC-61 to support the civilianized UC-61s.
In the US, the FAA has repeatedly denied the increase in gross weight to 2882 lbs when the Cont 220 or the Jake 755 has been installed via STC or FAA one time field 377. Most F-24s have the light universal joints. Will it haul the extra weight with the bigger engines? Yes it will. Is it hard on the gear? Yes, especially in rough field operations. I have attached two pics that show the light and heavy joints. Karl Saenger has heavy on the bird in Switzerland. His was a UC-61. I don’t know if all UC-61s had the heavy joints. I have never seen a set of heavy joints in person.
If you notice, the gross weight is allowed for the F-24 on floats. This is for the extra weight of the floats. Also no strain gear since it is removed. The airframe structure will handle the loads.
Your CAA may be more receptive than our FAA on this matter.
Hope this helps.
Note: Pics will not attach to the Yahoo email.
JST
Sent: Saturday, December 12, 2015 3:51 PM
Subject: [fairchildclub] F24 R46/UC61K Gross Weight
Folks
Many thanks
Hope this helps.
JST
Folks
Many thanks
james chybicki
'JamieCan you send the pictures direct to my email, I will check the pictures against mine and see the difference
thanksJim ChybickiUC-61K USAAF # 43-14964 / RAF # HB690
RampRatOne-at- yahoo-dot-com
From: "'Jamie Treat' jamietreat@q.com [fairchildclub]"
Cc: coxs.gorrel@virgin.net
Sent: Saturday, December 12, 2015 8:06 PM
Subject: RE: [fairchildclub] F24 R46/UC61K Gross Weight
Frank,
Hope this helps.
JST
Folks
Many thanks
#ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212 -- #ygrps-yiv-35238091yiv9059394212ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mkp #ygrps-yiv-35238091yiv9059394212hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mkp #ygrps-yiv-35238091yiv9059394212ads { margin-bottom:10px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mkp .ygrps-yiv-35238091yiv9059394212ad { padding:0 0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mkp .ygrps-yiv-35238091yiv9059394212ad p { margin:0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mkp .ygrps-yiv-35238091yiv9059394212ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-sponsor #ygrps-yiv-35238091yiv9059394212ygrp-lc { font-family:Arial;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-sponsor #ygrps-yiv-35238091yiv9059394212ygrp-lc #ygrps-yiv-35238091yiv9059394212hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-sponsor #ygrps-yiv-35238091yiv9059394212ygrp-lc .ygrps-yiv-35238091yiv9059394212ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212activity span { font-weight:700;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212activity span:first-child { text-transform:uppercase;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212activity span span { color:#ff7900;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212activity span .ygrps-yiv-35238091yiv9059394212underline { text-decoration:underline;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212attach div a { text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212attach img { border:none;padding-right:5px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212attach label { display:block;margin-bottom:5px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212attach label a { text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 blockquote { margin:0 0 0 4px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212bold a { text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 dd.ygrps-yiv-35238091yiv9059394212last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 dd.ygrps-yiv-35238091yiv9059394212last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 dd.ygrps-yiv-35238091yiv9059394212last p span.ygrps-yiv-35238091yiv9059394212yshortcuts { margin-right:0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212attach-table div div a { text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212attach-table { width:400px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212file-title a, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212file-title a:active, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212file-title a:hover, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212file-title a:visited { text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212photo-title a, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212photo-title a:active, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212photo-title a:hover, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div.ygrps-yiv-35238091yiv9059394212photo-title a:visited { text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 div#ygrps-yiv-35238091yiv9059394212ygrp-mlmsg #ygrps-yiv-35238091yiv9059394212ygrp-msg p a span.ygrps-yiv-35238091yiv9059394212yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212green { color:#628c2a;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212MsoNormal { margin:0 0 0 0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 o { font-size:0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212photos div { float:left;width:72px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212reco-category { font-size:77%;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212reco-desc { font-size:77%;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 .ygrps-yiv-35238091yiv9059394212replbq { margin:4px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mlmsg select, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 input, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mlmsg pre, #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 code { font:115% monospace;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-mlmsg #ygrps-yiv-35238091yiv9059394212logo { padding-bottom:10px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-msg p#ygrps-yiv-35238091yiv9059394212attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-reco #ygrps-yiv-35238091yiv9059394212reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-sponsor #ygrps-yiv-35238091yiv9059394212ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-sponsor #ygrps-yiv-35238091yiv9059394212ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-sponsor #ygrps-yiv-35238091yiv9059394212ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-text { font-family:Georgia;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-text tt { font-size:120%;} #ygrps-yiv-35238091 #ygrps-yiv-35238091yiv9059394212 #ygrps-yiv-35238091yiv9059394212ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-35238091
Frank,
Hope this helps.
JST
Folks
Many thanks
Jamie Treat
'Jim,
See attached.
JST
thanks
Jim Chybicki
, 2015 8:06 PM
Frank,
Hope this helps.
JST
Folks
Many thanks
See attached.
JST
thanks
Jim Chybicki
, 2015 8:06 PM
Frank,
Hope this helps.
JST
Folks
Many thanks
james chybicki
'Hi JamieNo Joynothing attachedJim
Sent: Monday, December 14, 2015 9:22 AM
Jim,
See attached.
JST
thanks
Jim Chybicki
, 2015 8:06 PM
Frank,
Hope this helps.
JST
Folks
Many thanks
#ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350 -- #ygrps-yiv-899687335yiv3920446350ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mkp #ygrps-yiv-899687335yiv3920446350hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mkp #ygrps-yiv-899687335yiv3920446350ads { margin-bottom:10px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mkp .ygrps-yiv-899687335yiv3920446350ad { padding:0 0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mkp .ygrps-yiv-899687335yiv3920446350ad p { margin:0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mkp .ygrps-yiv-899687335yiv3920446350ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-sponsor #ygrps-yiv-899687335yiv3920446350ygrp-lc { font-family:Arial;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-sponsor #ygrps-yiv-899687335yiv3920446350ygrp-lc #ygrps-yiv-899687335yiv3920446350hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-sponsor #ygrps-yiv-899687335yiv3920446350ygrp-lc .ygrps-yiv-899687335yiv3920446350ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350activity span { font-weight:700;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350activity span:first-child { text-transform:uppercase;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350activity span span { color:#ff7900;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350activity span .ygrps-yiv-899687335yiv3920446350underline { text-decoration:underline;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350attach div a { text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350attach img { border:none;padding-right:5px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350attach label { display:block;margin-bottom:5px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350attach label a { text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 blockquote { margin:0 0 0 4px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350bold a { text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 dd.ygrps-yiv-899687335yiv3920446350last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 dd.ygrps-yiv-899687335yiv3920446350last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 dd.ygrps-yiv-899687335yiv3920446350last p span.ygrps-yiv-899687335yiv3920446350yshortcuts { margin-right:0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350attach-table div div a { text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350attach-table { width:400px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350file-title a, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350file-title a:active, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350file-title a:hover, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350file-title a:visited { text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350photo-title a, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350photo-title a:active, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350photo-title a:hover, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div.ygrps-yiv-899687335yiv3920446350photo-title a:visited { text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 div#ygrps-yiv-899687335yiv3920446350ygrp-mlmsg #ygrps-yiv-899687335yiv3920446350ygrp-msg p a span.ygrps-yiv-899687335yiv3920446350yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350green { color:#628c2a;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350MsoNormal { margin:0 0 0 0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 o { font-size:0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350photos div { float:left;width:72px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350reco-category { font-size:77%;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350reco-desc { font-size:77%;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 .ygrps-yiv-899687335yiv3920446350replbq { margin:4px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mlmsg select, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 input, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mlmsg pre, #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 code { font:115% monospace;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-mlmsg #ygrps-yiv-899687335yiv3920446350logo { padding-bottom:10px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-msg p#ygrps-yiv-899687335yiv3920446350attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-reco #ygrps-yiv-899687335yiv3920446350reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-sponsor #ygrps-yiv-899687335yiv3920446350ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-sponsor #ygrps-yiv-899687335yiv3920446350ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-sponsor #ygrps-yiv-899687335yiv3920446350ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-text { font-family:Georgia;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-text tt { font-size:120%;} #ygrps-yiv-899687335 #ygrps-yiv-899687335yiv3920446350 #ygrps-yiv-899687335yiv3920446350ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-899687335
Jim,
See attached.
JST
thanks
Jim Chybicki
, 2015 8:06 PM
Frank,
Hope this helps.
JST
Folks
Many thanks
