Re: A few parts needed for my PT-23
Steve Link
Post by Steve Link »
' Excellent, thanks Paul!
Date: Mon, 21 Sep 2015 21:04:31 -0500
Subject: Re: [fairchildclub] A few parts needed for my PT-23
  Doug Harkis make all of the placards in metal for the aircraft. His number is 519-335-6091Paul Cousineau
Sent from my iPhone
On Sep 21, 2015, at 09:35, Steve Link steven_link@msn.com [fairchildclub] wrote:
I was wondering if anyone had a couple of the "hub caps" as they are called out in the IPB that go over the nuts on the main gear, Fig. 37, Ind. 6, PN A-32-27. I was needing a couple for my PT-23.
Also looking for a dipstick gauge for the main struts, Fig. 32, Ind. 1, PN 61117.
I'm also trying to fine a set of both data plates for my main struts and a good way to restore them so they are readable, Fig. 38, Ind. 16 & 17, Placard & Spec. Tag....
Thanks for any help, Steve in OK....
JP
Post by JP »
'No, it is not normal.  I also am in need of one if they are to be had.
Sent from my iPad
On Sep 21, 2015, at 7:50 PM, Pattee News patteenews@gmail.com [fairchildclub] wrote:
Or Dust Caps?I don't even have a dust cap.  Just services the wheels for the first time and noticed not dust cap just nut washer and cotter pin with grease squeezing out.  That's not normal is it?David Pattee
stephen bertrand
Post by stephen bertrand »
'These wheel bearing dust caps are readily available at R.V. service centers, where there will be a larger selection than at auto parts stores.  Don't know what type axle or wheels you have, but just take a measurement and you'll be able to get a cap very close to what you need. You can modify the caps with the center rubber boot for a good fit.  It worked for me on a tapered shaft w/ Hayes wheel.
Steve
Sent: Tuesday, September 22, 2015 8:08 AM
Sent from my iPad
Post by robert Etter »
'I think that your wheels are the same as the "24's".  I didn't have an RV place available, but I found that NAPA has a cap that I was able to make it work.  I had to beveled the inner 1/8".  Otherwise, you can't get it started.  The cap that I used was fairly deep.  It was OK for the 24, but is you have full covers on the wheels, it may not work for you.Bob
On Tuesday, September 22, 2015 9:34 AM, "Stephen Bertrand ac500shrike81@yahoo.com [fairchildclub]" wrote:
Steve
Sent from my iPad
#ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300 -- #ygrps-yiv-1613842003yiv1718218300ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mkp #ygrps-yiv-1613842003yiv1718218300hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mkp #ygrps-yiv-1613842003yiv1718218300ads { margin-bottom:10px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mkp .ygrps-yiv-1613842003yiv1718218300ad { padding:0 0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mkp .ygrps-yiv-1613842003yiv1718218300ad p { margin:0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mkp .ygrps-yiv-1613842003yiv1718218300ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-sponsor #ygrps-yiv-1613842003yiv1718218300ygrp-lc { font-family:Arial;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-sponsor #ygrps-yiv-1613842003yiv1718218300ygrp-lc #ygrps-yiv-1613842003yiv1718218300hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-sponsor #ygrps-yiv-1613842003yiv1718218300ygrp-lc .ygrps-yiv-1613842003yiv1718218300ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300activity span { font-weight:700;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300activity span span { color:#ff7900;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300activity span .ygrps-yiv-1613842003yiv1718218300underline { text-decoration:underline;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300attach div a { text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300attach img { border:none;padding-right:5px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300attach label a { text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300bold a { text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 dd.ygrps-yiv-1613842003yiv1718218300last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 dd.ygrps-yiv-1613842003yiv1718218300last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 dd.ygrps-yiv-1613842003yiv1718218300last p span.ygrps-yiv-1613842003yiv1718218300yshortcuts { margin-right:0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300attach-table div div a { text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300attach-table { width:400px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300file-title a, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300file-title a:active, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300file-title a:hover, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300file-title a:visited { text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300photo-title a, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300photo-title a:active, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300photo-title a:hover, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div.ygrps-yiv-1613842003yiv1718218300photo-title a:visited { text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 div#ygrps-yiv-1613842003yiv1718218300ygrp-mlmsg #ygrps-yiv-1613842003yiv1718218300ygrp-msg p a span.ygrps-yiv-1613842003yiv1718218300yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300green { color:#628c2a;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 o { font-size:0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300photos div { float:left;width:72px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300reco-category { font-size:77%;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300reco-desc { font-size:77%;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 .ygrps-yiv-1613842003yiv1718218300replbq { margin:4px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mlmsg select, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 input, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mlmsg pre, #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 code { font:115% monospace;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-mlmsg #ygrps-yiv-1613842003yiv1718218300logo { padding-bottom:10px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-msg p#ygrps-yiv-1613842003yiv1718218300attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-reco #ygrps-yiv-1613842003yiv1718218300reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-sponsor #ygrps-yiv-1613842003yiv1718218300ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-sponsor #ygrps-yiv-1613842003yiv1718218300ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-sponsor #ygrps-yiv-1613842003yiv1718218300ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-text { font-family:Georgia;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-text tt { font-size:120%;} #ygrps-yiv-1613842003 #ygrps-yiv-1613842003yiv1718218300 #ygrps-yiv-1613842003yiv1718218300ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1613842003
Jp Lorie
Post by Jp Lorie »
'Yes I bought that one in NaPa and will have to bevel as you said  if it is to go on. Thanks Sincerely
J.P. Lorie
jp.lorie@yahoo.com
On Thursday, September 24, 2015 2:39 PM, "Robert Etter robertetter@ymail.com [fairchildclub]" wrote:
Steve
Sent from my iPad
#ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656 -- #ygrps-yiv-514919016yiv5356229656ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mkp #ygrps-yiv-514919016yiv5356229656hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mkp #ygrps-yiv-514919016yiv5356229656ads { margin-bottom:10px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mkp .ygrps-yiv-514919016yiv5356229656ad { padding:0 0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mkp .ygrps-yiv-514919016yiv5356229656ad p { margin:0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mkp .ygrps-yiv-514919016yiv5356229656ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-sponsor #ygrps-yiv-514919016yiv5356229656ygrp-lc { font-family:Arial;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-sponsor #ygrps-yiv-514919016yiv5356229656ygrp-lc #ygrps-yiv-514919016yiv5356229656hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-sponsor #ygrps-yiv-514919016yiv5356229656ygrp-lc .ygrps-yiv-514919016yiv5356229656ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656activity span { font-weight:700;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656activity span:first-child { text-transform:uppercase;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656activity span span { color:#ff7900;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656activity span .ygrps-yiv-514919016yiv5356229656underline { text-decoration:underline;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656attach div a { text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656attach img { border:none;padding-right:5px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656attach label { display:block;margin-bottom:5px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656attach label a { text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 blockquote { margin:0 0 0 4px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656bold a { text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 dd.ygrps-yiv-514919016yiv5356229656last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 dd.ygrps-yiv-514919016yiv5356229656last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 dd.ygrps-yiv-514919016yiv5356229656last p span.ygrps-yiv-514919016yiv5356229656yshortcuts { margin-right:0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656attach-table div div a { text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656attach-table { width:400px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656file-title a, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656file-title a:active, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656file-title a:hover, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656file-title a:visited { text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656photo-title a, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656photo-title a:active, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656photo-title a:hover, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div.ygrps-yiv-514919016yiv5356229656photo-title a:visited { text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 div#ygrps-yiv-514919016yiv5356229656ygrp-mlmsg #ygrps-yiv-514919016yiv5356229656ygrp-msg p a span.ygrps-yiv-514919016yiv5356229656yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656green { color:#628c2a;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656MsoNormal { margin:0 0 0 0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 o { font-size:0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656photos div { float:left;width:72px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656reco-category { font-size:77%;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656reco-desc { font-size:77%;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 .ygrps-yiv-514919016yiv5356229656replbq { margin:4px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mlmsg select, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 input, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mlmsg pre, #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 code { font:115% monospace;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-mlmsg #ygrps-yiv-514919016yiv5356229656logo { padding-bottom:10px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-msg p#ygrps-yiv-514919016yiv5356229656attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-reco #ygrps-yiv-514919016yiv5356229656reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-sponsor #ygrps-yiv-514919016yiv5356229656ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-sponsor #ygrps-yiv-514919016yiv5356229656ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-sponsor #ygrps-yiv-514919016yiv5356229656ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-text { font-family:Georgia;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-text tt { font-size:120%;} #ygrps-yiv-514919016 #ygrps-yiv-514919016yiv5356229656 #ygrps-yiv-514919016yiv5356229656ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-514919016
