'Folks,
I am having great difficulty finding springs close to drawing 42257 - there are masses of manufacturers out there with 1000s of stock springs but finding something that will do the job is proving very frustrating. When I get close to the right one there always seems to be one spec that make it unusable
Has anyone managed to find a source for something that will do the job? I would be very happy to hear about it.
Many thanks
Argus III G-BCBL
Re: F24 (UC61K) Right rudder pedal release springs
' Frank, Unless the factory can supply the springs, just find ones that are close. It may be a trial and error approach, but as long as it works, that is all that matters. Aeronca springs may work. They are available from Wag Aero. Did you try calling the factory? Joe
Sent from my iPad Mini
Folks,
Many thanks
Argus III G-BCBL
On Sep 13, 2015, at 05:29, coxs.gorrel@virgin.net [fairchildclub] wrote:
Folks,
Many thanks
Argus III G-BCBL
'Frank. Many spring manufactures will custom make springs to your specifications and/or replicate an existing spring. Choose a spring manufacturer and make an inquiry. If you have the spring drawing/specifications or a sample spring to replicate tell them and ask for a quote; and do shop around for the best quote. Quotes can vary over a wide range especially for small part runs. Probably best to inquire with the smaller shops for custom made springs.'
' Try www dot centuryspring dot com Tel: 800-237-5225 Tel: 213-749-1466 Tel: 213-749-3802 222 East 16th Street Los Angeles, CA 90015 This company has many styles and types of springs in stock. They also make springs to specifications. John El Paso In a message dated 9/14/2015 7:45:39 A.M. Mountain Daylight Time, fairchildclub@yahoogroups.com writes:
'Thanks to all.
I have finally sourced some that fit the bill very nicely - had to buy seven to make up minimum price and pay way over the odds for shipping! - that's life these days it seems.
I have five spares if any one needs one.'
'I need a set. Do you still have them?Tom Kottre'
'Tom,I don’t believe we have those. We have a Fairchild that sells today, but there are not a lot of extra Fairchild parts. Thank You, Debbie Schnaidt Allen
Apple Tree Auction Center1625 W. Church Street
Newark, OH 43055
740.344.4282
Debbie@AppleTreeAuction.com
www.AppleTreeAuction.com From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, September 30, 2015 7:02 PM
Subject: [fairchildclub] Re: F24 (UC61K) Right rudder pedal release springs
Newark, OH 43055
740.344.4282
