'Anyone know where I can get oil fittings? I need some AC-851-16 and
 AC-852-16 fittings. These are 3/4 pipe to 1" ID hose 45deg and 90deg
 fittings used in several places in the oil system of the Ranger.
 David'
						Re: Ranger oil fittings
'My 1948 Bellanca used those Air Corp fittings.  However, in a couple of places someone used AN fittings as the Pipe ends are the same.  You just have to use the proper AN to hose.  Now I am aware you are trying to make it historically right; so keep looking for the Grey not the Blue fittings.  I'd check with my Ranger engine parts source.      Cy Galley - Chairman of Emergency Aircraft RepairA service project of EAA Chapter 75      From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, November 19, 2014 8:39 PM
Subject: [fairchildclub] Ranger oil fittings
David'
David'
'You are looking for AN842 and AN844-16 fittings, 90 and 45 respectively.  Letter suffix for material type, brass(none), aluminum(D orW), steel(S).  Bunch of brass 90 degree ones on eBay right now for $10.
Found them at Skygeek, but really pricey. One type at Wicks. Bet Lance Aircraft has them.
Curt
Sent from my iPad
David
Curt
Sent from my iPad
On Nov 19, 2014, at 9:38 PM, Ranchaero Wing Shop david@ranchaerowingshop.com [fairchildclub] wrote:
David
'If you replace the AC with AN  you must replace the line as well. Nut threads are different as well as the sealing angle.  From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com]
Sent: Wednesday, November 19, 2014 9:29 PM
Subject: Re: [fairchildclub] Ranger oil fittings You are looking for AN842 and AN844-16 fittings, 90 and 45 respectively. Letter suffix for material type, brass(none), aluminum(D orW), steel(S). Bunch of brass 90 degree ones on eBay right now for $10. Found them at Skygeek, but really pricey. One type at Wicks. Bet Lance Aircraft has them. Curt
Sent from my iPad
Sent from my iPad
David
				Ranchaero Wing Shop
'                   These are for oil lines to the oil       cooler and rear of engine. Somebody please correct me if I'm       wrong, but I believe I need the "AC" and brass.
David
On 11/20/2014 4:37 AM, 'Cy Galley' cgalley@mchsi.com [fairchildclub] wrote:
						David
If you replace the AC with AN you must replace the line as well. Nut threads are different as well as the sealing angle. From: fairchildclub@yahoogroups.com [fairchildclub@yahoogroups.com]
Sent from my iPad
David
