Re: UC61K 10 inch Tail Wheel Tire and Tube
'Folks,
I have a a Variety Aircraft VGC 10 tail wheel hub (thanks to Steve Lawlor) and before I part with 'large bucks' was wanting to check specifically which tube I should use with this tire.
10.00 SC 8 PLY AERO CLASSIC CHANNEL TREAD AIRCRAFT TIRE (as stocked by Desser)
Was planning on the 'Channel tread' to try and reduce the tendency to shimmy and I'm not keen on the hub adapters as I am trying to stay close to original.
I am unsure about the 90* valve as it seems too long and does not fit well. Also, as Desser say-
"Do not use if you have a fork. The alternate tube, 10.00 STRAIGHT RUBBER VALVE works in all applications". - but the Variety hub is not, by the look of it, suited to a straight valve - "Catch 22"!
Any/all comments/experiences on which combination of tire and tube work best, polite or otherwise, will be most welcome.
Thanks in advance
Frank'
Thanks in advance
Frank'
The 90 degree metal stem won't work. You have to use the straight rubber stem and live with pushing it over and putting the cover plate over it.
I just replaced mine a month or so back and it seemed a little shorter than the previous tube stem and fit better. On the previous one and on my other PT it would bow the cover plate out.
I recommend having a spare tube handy.
The reason for my last replacement was a failed valve stem. Admittedly well over 10 years old, but I suspect the extra stress of pushing it over can't be good for it.
FYI, Desser took my return of the 90 degree metal stem tube without any issues. A friend ordered it for me when he was ordering one for his Stearman, which uses the 90 degree. Sent via BlackBerry by AT&TFrom: "coxs.gorrel@virgin.net [fairchildclub]"
Date: 08 Jun 2014 04:15:32 -0700To: ReplyTo: fairchildclub@yahoogroups.com
Subject: [fairchildclub] UC61K 10 inch Tail Wheel Tire and Tube
Folks,
"Do not
Thanks in advance
Frank
Folks,
"Do not
Thanks in advance
Frank
'I use a wheelbarrow inter-tube on my standard 10" tire on my 24. Purchased at a local tire store. The stem alignment leaves something to be desired. This could be my installing it! Tried several times to get to line up, but stem rests against one side of the wheel which makes checking pressure and inflating a bit of a challenge. Also, the stem is a bit too long to allow for installing the small section of the dust cover over it.Roger StarrNC77630
FYI, Desser took my return of the 90 degree metal stem tube without any issues. A friend ordered it for me when he was ordering one for his Stearman, which uses the 90 degree. Sent via BlackBerry by AT&TFrom: "coxs.gorrel@virgin.net [fairchildclub]" Sender: fairchildclub@yahoogroups.com Date: 08 Jun 2014 04:15:32 -0700To: ReplyTo: fairchildclub@yahoogroups.com Subject: [fairchildclub] UC61K 10 inch Tail Wheel Tire and Tube
Folks,
I am unsure about the 90* valve as it seems too long and does not fit well. Also, as Desser say- "Do not use if you have a fork. The alternate tube, 10.00 STRAIGHT RUBBER VALVE works in all applications". - but the Variety hub is not, by the look of it, suited to a straight valve - "Catch 22"!
Thanks in advance
Frank #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754 -- #ygrps-yiv-319373597yiv7874842754ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp #ygrps-yiv-319373597yiv7874842754hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp #ygrps-yiv-319373597yiv7874842754ads { margin-bottom:10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp .ygrps-yiv-319373597yiv7874842754ad { padding:0 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp .ygrps-yiv-319373597yiv7874842754ad p { margin:0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mkp .ygrps-yiv-319373597yiv7874842754ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ygrp-lc { font-family:Arial;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ygrp-lc #ygrps-yiv-319373597yiv7874842754hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ygrp-lc .ygrps-yiv-319373597yiv7874842754ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span { font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span:first-child { text-transform:uppercase;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span span { color:#ff7900;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754activity span .ygrps-yiv-319373597yiv7874842754underline { text-decoration:underline;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach div a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach img { border:none;padding-right:5px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach label { display:block;margin-bottom:5px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754attach label a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 blockquote { margin:0 0 0 4px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754bold a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 dd.ygrps-yiv-319373597yiv7874842754last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 dd.ygrps-yiv-319373597yiv7874842754last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 dd.ygrps-yiv-319373597yiv7874842754last p span.ygrps-yiv-319373597yiv7874842754yshortcuts { margin-right:0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754attach-table div div a { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754attach-table { width:400px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a:active, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a:hover, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754file-title a:visited { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a:active, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a:hover, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div.ygrps-yiv-319373597yiv7874842754photo-title a:visited { text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 div#ygrps-yiv-319373597yiv7874842754ygrp-mlmsg #ygrps-yiv-319373597yiv7874842754ygrp-msg p a span.ygrps-yiv-319373597yiv7874842754yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754green { color:#628c2a;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754MsoNormal { margin:0 0 0 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 o { font-size:0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754photos div { float:left;width:72px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754reco-category { font-size:77%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754reco-desc { font-size:77%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 .ygrps-yiv-319373597yiv7874842754replbq { margin:4px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg select, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 input, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg pre, #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 code { font:115% monospace;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-mlmsg #ygrps-yiv-319373597yiv7874842754logo { padding-bottom:10px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-msg p#ygrps-yiv-319373597yiv7874842754attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-reco #ygrps-yiv-319373597yiv7874842754reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-sponsor #ygrps-yiv-319373597yiv7874842754ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-text { font-family:Georgia;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-text tt { font-size:120%;} #ygrps-yiv-319373597 #ygrps-yiv-319373597yiv7874842754 #ygrps-yiv-319373597yiv7874842754ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-319373597
Folks,
Thanks in advance
'Frank,
I use the straight stem tube from Desser in my Variety wheel. It's a little tough to deal with, but I use a valve stem extender of about 3 inches that I screw onto the tube for check and fill. I keep a spare extender in my tool bag for when I'm out flying about. I'm running about 60# nitrogen. It's impossible to get a cap on the stem, but the cover does well to keep the dirt out.
Hope this helps,
Steve Lawlor'
Hope this helps,
Steve Lawlor'
'Thanks to all for your input – The ‘tipped over straight valve’ seems to be the best compromise – I’ll go that way and maybe pass on the wheelbarrow tube – I don’t think the powers that be would be too happy with that one!
Frank
Sent: 08 June 2014 16:23
Subject: Re: [fairchildclub] UC61K 10 inch Tail Wheel Tire and Tube
Folks,
Thanks in advance
Frank
Frank
Folks,
Thanks in advance
Frank
' I just got done installing a 10SC tube & tire on a Variety VG-10 10" hub for my PT-26 project. The tube is the Polish one with the 90 degree metal valve stem. After multiple trials this is what I found.
1. I was able to install the with the stem at the original 90 degree position, with some pluses and minuses. On the minus side I could not install the cover plate as the valve stem sticks out too far, but but on the plus side the tire can easily be filled and pressure checked.
2. The stem angle can be changed by loosening the lock nut.
3. I repositioned the the stem about 30 degrees ccw, and slightly relieved the main part of the hub where the stem passes through to accommodate the angle.
4. Everything assembled easily, with the stem below the level of the cover plate. To fill and check pressure I had to install a valve stem extension, available for a buck everywhere. If you use a plastic extension, I suggest cutting off the unthreaded lead-in portion of the extension, which makes it easier to install & remove. I had to pry the stem back a bit with a small screwdriver to get it on.
QUESTION: What is everyone doing for tailwheel seals? I couldn't find a seal with a 7/8" ID, so I had to make 15/16" spacers to fit the seal I could find with the correct OD and width.
Pete Crawford
On 6/8/2014 12:09 PM, Ellen Starr ellengstarr@yahoo.com [fairchildclub] wrote:
Pete Crawford
I use a wheelbarrow inter-tube on my standard 10" tire on my 24. Purchased at a local tire store. The stem alignment leaves something to be desired. This could be my installing it! Tried several times to get to line up, but stem rests against one side of the wheel which makes checking pressure and inflating a bit of a challenge. Also, the stem is a bit too long to allow for installing the small section of the dust cover over it. Roger Starr NC77630
On Sunday, June 8, 2014 8:23 AM, ptcurt@gmail.com[fairchildclub] fairchildclub@yahoogroups.com wrote:
FYI, Desser took my return of the 90 degree metal stem tube without any issues. A friend ordered it for me when he was ordering one for his Stearman, which uses the 90 degree. Sent via BlackBerry by AT&T From: coxs.gorrel@virgin.net[fairchildclub] fairchildclub@yahoogroups.com Sender: fairchildclub@yahoogroups.com Date: 08 Jun 2014 04:15:32 -0700 To: fairchildclub@yahoogroups.com ReplyTo: fairchildclub@yahoogroups.com Subject: [fairchildclub] UC61K 10 inch Tail Wheel Tire and Tube
Folks,
Thanks in advance
Frank
'Here's what the bent long-stem inner tube from Desser (and ribbed tire) looks like when installed. Guess they fit when one isn't told that they won't fit... ?? Inflated to ~30 psi, with cap.
Bill C.
NC28685
Date: Tue, 10 Jun 2014 11:29:47 +0100
Subject: RE: [fairchildclub] UC61K 10 inch Tail Wheel Tire and Tube
Frank
Folks,
Thanks in advance
Frank
Bill C.
NC28685
Frank
Folks,
Thanks in advance
Frank
'Thanks Bill. I stand corrected, it does look like you can make the metal stem work. It sure didn't appear that way when I tried it on my spare tailwheel, but I must admit I didn't make a lot of effort as I knew the tailwheel on the airplane was different and had the rubber stem tube that I knew would work. Not sure if the spare I tried it on is a variety tailwheel or not. I'll check.
Curt
ptcurt@gmail.com '
Curt
On Thu, Jun 12, 2014 at 6:28 AM, William crei6845@hotmail.com [fairchildclub] wrote:
Bill C.
NC28685
Frank
Folks,
Thanks in advance
Frank
ptcurt@gmail.com '
F-24 Owners:
I have in my hangar a complete tailwheel strut, fork, wheel, and tire assembly. We pulled it off a Waco RNF project. Went back to the Waco setup. I believe it is a 1937 vintage. Tailwheel is a Varitety Aircraft P/N 25272, S/N A925. Wheel width is 4.5 inches outside to outside. Casting on Fork is 61370. The tire is a Flat Rib type. Brand new with tube. Still has the sticker on it. I have some pics of the strut and wheel. I know it it not a 1940 and newer. I have it listed for $450.00 on Barnstormers as a complete unit. Will let it go for a big discount to the FC club members. Send me an email for pics
Fairchild Club CD ROM Editor
IAC 5, Chapter President
http://iac5.org
Hm/Hgr 303-648-0130
Cell 303-304-7937
F-24 Owners:
http://iac5.org
Hm/Hgr 303-648-0130
Cell 303-304-7937
'Hi JamieCan you send me pictures?Our plane has the British knuckle joint full swivel Tail Wheel. We may want to change over to a standard set upthanksJim ChybickiMidwest Aeronautique LLCUC-61K USAAF# 43-14964 / RAF # HB-690RampRatOne@yahoo.com
On Thursday, August 7, 2014 3:19 PM, "jamietreat@q.com [fairchildclub]" wrote:
F-24 Owners: I have in my hangar a complete tailwheel strut, fork, wheel, and tire assembly. We pulled it off a Waco RNF project. Went back to the Waco setup. I believe it is a 1937 vintage. Tailwheel is a Varitety Aircraft P/N 25272, S/N A925. Wheel width is 4.5 inches outside to outside. Casting on Fork is 61370. The tire is a Flat Rib type. Brand new with tube. Still has the sticker on it. I have some pics of the strut and wheel. I know it it not a 1940 and newer. I have it listed for $450.00 on Barnstormers as a complete unit. Will let it go for a big discount to the FC club members. Send me an email for pics Jamie S. Treat A&P/IA
http://iac5.org
Elbert, CO 80106 Hm/Hgr 303-648-0130
Cell 303-304-7937 #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490 -- #ygrps-yiv-1718127037yiv2583879490ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mkp #ygrps-yiv-1718127037yiv2583879490hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mkp #ygrps-yiv-1718127037yiv2583879490ads { margin-bottom:10px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mkp .ygrps-yiv-1718127037yiv2583879490ad { padding:0 0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mkp .ygrps-yiv-1718127037yiv2583879490ad p { margin:0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mkp .ygrps-yiv-1718127037yiv2583879490ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-sponsor #ygrps-yiv-1718127037yiv2583879490ygrp-lc { font-family:Arial;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-sponsor #ygrps-yiv-1718127037yiv2583879490ygrp-lc #ygrps-yiv-1718127037yiv2583879490hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-sponsor #ygrps-yiv-1718127037yiv2583879490ygrp-lc .ygrps-yiv-1718127037yiv2583879490ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490activity span { font-weight:700;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490activity span span { color:#ff7900;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490activity span .ygrps-yiv-1718127037yiv2583879490underline { text-decoration:underline;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490attach div a { text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490attach img { border:none;padding-right:5px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490attach label a { text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490bold a { text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 dd.ygrps-yiv-1718127037yiv2583879490last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 dd.ygrps-yiv-1718127037yiv2583879490last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 dd.ygrps-yiv-1718127037yiv2583879490last p span.ygrps-yiv-1718127037yiv2583879490yshortcuts { margin-right:0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490attach-table div div a { text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490attach-table { width:400px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490file-title a, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490file-title a:active, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490file-title a:hover, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490file-title a:visited { text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490photo-title a, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490photo-title a:active, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490photo-title a:hover, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div.ygrps-yiv-1718127037yiv2583879490photo-title a:visited { text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 div#ygrps-yiv-1718127037yiv2583879490ygrp-mlmsg #ygrps-yiv-1718127037yiv2583879490ygrp-msg p a span.ygrps-yiv-1718127037yiv2583879490yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490green { color:#628c2a;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 o { font-size:0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490photos div { float:left;width:72px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490reco-category { font-size:77%;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490reco-desc { font-size:77%;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 .ygrps-yiv-1718127037yiv2583879490replbq { margin:4px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mlmsg select, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 input, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mlmsg pre, #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 code { font:115% monospace;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-mlmsg #ygrps-yiv-1718127037yiv2583879490logo { padding-bottom:10px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-msg p#ygrps-yiv-1718127037yiv2583879490attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-reco #ygrps-yiv-1718127037yiv2583879490reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-sponsor #ygrps-yiv-1718127037yiv2583879490ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-sponsor #ygrps-yiv-1718127037yiv2583879490ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-sponsor #ygrps-yiv-1718127037yiv2583879490ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-text { font-family:Georgia;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-text tt { font-size:120%;} #ygrps-yiv-1718127037 #ygrps-yiv-1718127037yiv2583879490 #ygrps-yiv-1718127037yiv2583879490ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1718127037
http://iac5.org
