'Folks,My mechanic is having trouble removing the prop, so that we can
send the engine for overhaul. Does anyone have tips/special tool/manual
reference for removal of the prop?
Here are links to some pictures of the prop setup
1. Hub from front
https://www.dropbox.com/s/n1y52ls19omi5ri/20121215_154154.jpg
2. Hub from left of
aircrafthttps://www.dropbox.com/s/lwrr3wk0sa8ek5x/20121215_154206.jpg
3. Hub from right of aircraft
https://www.dropbox.com/s/5qx6abg762gsnfr/20121215_154213.jpg
4. Prop details
https://www.dropbox.com/s/vqrz92z65cgobdr/20121215_154235.jpg
ThanksAnandeep Pannu'
Re: Propellor removal PT-26/19
John Ellis
'Be sure the locking bolt is removed from the big nut on front of crankshaft.
Insert rod through the big holes in nut and loosen.. Snap ring looks to be
in place that will pull the prop forward as nut is removed. When nut runs
out of threads on crankshaft, you should be able to remove nut and taper
halves then slide prop off shaft.
John
John
Sent: Saturday, December 15, 2012 6:59 PM
Subject: [fairchildclub] Propellor removal PT-26/19
> 1. Hub from front
> 2. Hub from left of
> 4. Prop details
'John,
Thanks for the reply. We have removed the bolt, but the big nut is not budging. We used a steel rod, and it bent!
I assume we are going counterclockwise while facing the engine?
Anandeep
Anandeep
> John
> From: "Anandeep"
> > 1. Hub from front
> > 2. Hub from left of
> > 4. Prop details
> > Yahoo! Groups Links
'Yep, counterclockwise facing the engine, it is a standard right hand thread. Get the largest diameter steel rod that will fit into the nut holes, which I can't remember off the top of my head, probably 7/8" ? Smaller rods will bend if a 20-spline nut has been gorilla'ed on.
I use a ladder with a foam pad to brace the propeller with as much contact area as possible on the leading edge so as to apply maximum leverage.
Date: Sun, 16 Dec 2012 04:06:47 +0000
Subject: [fairchildclub] Re: Propellor removal PT-26/19
John,
Anandeep
John,
Anandeep
> John
> From: "Anandeep"
> > 1. Hub from front
> > 2. Hub from left of
> > 4. Prop details
> > Yahoo! Groups Links
Jack Threadgill
'Use lots of penetrating oil, too.
Sent from my iPhone
Sent from my iPhone
> From: anandeep@gmail.com
> John,
> Thanks
> Anandeep
>> John
>> From: "Anandeep"
>> To:
>>> 1. Hub from front
>>> 2. Hub from left of
>>> 4. Prop details
>>> Yahoo! Groups Links
John Ellis
'I use a product "Kroil" to spray on threads.. Let it work it's way into the
threads. Use a long harden steel punch through the holes, then a cheater
bar over the punch.. If still won't turn, hold pressure on nut, use hammer
on end of nut to hopefully loosen corrosion in threads. ( lightly )
Sent: Sunday, December 16, 2012 7:12 AM
Subject: Re: [fairchildclub] Re: Propellor removal PT-26/19
> Sent from my iPhone
>> leverage.
>> John,
>> Thanks
>> Anandeep
>>> crankshaft.
>>> be
>>> runs
>>> John
>>> From: "Anandeep"
>>> To:
>>>> 1. Hub from front
>>>> 2. Hub from left of
>>>> 4. Prop details
>>>> Yahoo! Groups Links
>> Yahoo! Groups Links
Jack Threadgill
'It works. Doesn't it John. Lol
Sent from my iPhone
Sent from my iPhone
> From: "Jack Threadgill"
> > Sent from my iPhone
> >> leverage.
> >> John,
> >> Thanks
> >> Anandeep
> >>> crankshaft.
> >>> be
> >>> runs
> >>> John
> >>> From: "Anandeep"
> >>> To:
> >>>> 1. Hub from front
> >>>> 2. Hub from left of
> >>>> 4. Prop details
> >>>> Yahoo! Groups Links
> >> Yahoo! Groups Links
> > Yahoo! Groups Links
'Ditto the large rod. Then get about a 5 foot pipe that you can slide over
the rod so you can really hang and bounce on it. Might even bend the pipe
during removal.
www.eaa75.com
On Behalf Of Russell Williams
Sent: Saturday, December 15, 2012 11:03 PM
Subject: RE: [fairchildclub] Re: Propellor removal PT-26/19
John,
Anandeep
during removal.
www.eaa75.com
John,
Anandeep
crankshaft.
> John
> From: "Anandeep"
> > 1. Hub from front
> > 2. Hub from left of
> > 4. Prop details
> > Yahoo! Groups Links
Tom_Downey
'I used a 2' piece of flat bar stock that fit snuggly into the castle of the nut. then smacked it with a 2 pound sledge.
> during removal.
> www.eaa75.com
> From: anandeep@...
> John,
> Thanks
> Anandeep
> crankshaft.
> > John
> > From: "Anandeep"
> > To:
> > > 1. Hub from front
> > > 2. Hub from left of
> > > 4. Prop details
> > > Yahoo! Groups Links
