Re: LIFT STRUTS
John A Duncan
Re: LIFT STRUTS
Post by John A Duncan »
'Wicks now advertises that they stock streamlined tubing.
Kindest Regards,
JD
On Sep 18, 2012, at 3:06 PM, "Bob" wrote:
> Jim,
> Give me a call. I am a t 952 followed by 652 then a 3000.
> Bob W.
> Webster, MN
> --- In fairchildclub@yahoogroups.com, james chybicki wrote:
> > HI ALL
> > HELP! FORWARD WING LIFT STRUT NEEDED
> > MY SEARCH STILL GOES ON! I POSSIBLY FOUND A SET IN TEXAS, BUT WILL NOT BE ABLE TO SEE THEM TILL OCTOBER.
> > DOES ANYONE HAVE A SERVICEABLE / FLYABLE SET OF F24 LIFT STRUTS? I HAVE SEEN SOME PICTURES AND SPOKE WITH A FEW FOLKS, BUT NOBODY SEEMS TO HAVE A GOOD SET OR DO NOT WANT TO PART WITH THEM.
> > CAN THESE BE REPAIRED? THEN ORIGINAL 1944 UC-61 MANUAL DOES NOT GIVE ANY REPAIR PARAMETERS.
> > I TRIED SOME LOCAL METAL FABRICATORS HERE IN THE MIDWEST, BUT NONE ARE ABLE TO GET TEH .95 THICK TUBE WITHOUT SPECIAL ORDERING HUNDREDS OF FEET AT A TIME. ECONOMICALLY UNREALISTIC.
> > ANY HELP WOULD BE GREATLY APPRECIATE!
> > JIM CHYBICKI
> > UC-61K 43-14964 / HB-690
Hugh Loewenhardt
Re: LIFT STRUTS
Post by Hugh Loewenhardt »
'Jim,
 You could also try azairframe.com in the event you need to have a new strut fabricated.
Sent: Tuesday, September 11, 2012 12:05 PM
Subject: [fairchildclub] LIFT STRUTS
HI ALL
JIM CHYBICKI
