Bill McClure
To: fairchildclub
Sent: Wed, Feb 8, 2012 1:32 pm
Subject: Re: [fairchildclub] F24 Wing Struts
Hi Frank
Thank you for your offer to borrow the flywire tension tool
after looking at the Website and confiring with our Inspector, I do not see any way to
attach the tool to the drag wires due to rib placements. I will continue to research
the torque issues and report our findings
thanks
JIM C.
Sent: Tuesday, January 31, 2012 9:50 AM
Jim,
I bought one of these from Holloway Engineering
http://www.radialengine.com/flywire/flywire2.htm
And then graphed out and interpolated for the tensions that are off his 'Tie wire' scale. I have not used it yet as I have not got that far.
Maybe if you graph out his figures we could then compare our results and if there is an appreciable difference take a closer look to see who is right.
If you would like to borrow my tool then just let me know and I will get it to you.
UC61K G-BCBL
Sent: Tuesday, January 31, 2012 3:08 PM
Subject: [fairchildclub] F24 Wing Struts
Hi All
Our UC-61K restoration is humming right along. Wings are rebuilt and ready to cover.
During inspection of the wing struts we found 1 forward and 1 aft strut damaged (dented)
per the manual no damage is allowed. Does anyone have spares avialable for sales or trade?
I am also looking for a tool or method to check tension on the drag and anti-drag wires in the wing bays?
We have some "good old boys" suggestions and want to compare
thanks!
Jim Chybicki
UC-61K 43-14964 / RAF HB-690
