Re: F24 Wing Struts
Oily belly problem solved, I think
'Yesterday flew 0.5 hours, lost 0.5 gal 120W Aeroshell oil, most of it appeared to be on the belly of my PT-26.
End of breather tube had been left as originally cut with a squared off end that is 5 inch below the belly. Tube slopes aft at angle of the lower firewall.
This morning cut the tube end so the opening is parallel to the belly pan about 8" behind the firewall bottom, still 5" below the belly pan.
Took a short hop (0.3 hr) to see if that made a difference - and came back with a clean belly!
I'll put a photo of the tube in the album N69167.
What a relief.
Charles'
What a relief.
Charles'
F24 Wing Struts
'Hi All
Our UC-61K restoration is humming right along. Wings are rebuilt and ready to cover.
During inspection of the wing struts we found 1 forward and 1 aft strut damaged (dented)
per the manual no damage is allowed. Does anyone have spares avialable for sales or trade?
I am also looking for a tool or method to check tension on the drag and anti-drag wires in the wing bays?
We have some "good old boys" suggestions and want to compare
thanks!
Jim Chybicki
UC-61K 43-14964 / RAF HB-690
thanks!
Jim Chybicki
Re: F24 Wing Struts
'I have also wondered about the -24's wing struts. They seem quite beefy, but thinking of other types that have had AD's coming on the heels of failures, has anyone looked into the prevalence of wing strut problems in this series? Any inspection suggestions, or NDT procedures that would be recommended?
Thanks.
Bill McClure
To: fairchildclub
Sent: Tue, Jan 31, 2012 10:09 am
Subject: [fairchildclub] F24 Wing Struts
Hi All
thanks!
Jim Chybicki
Thanks.
Bill McClure
To: fairchildclub
Hi All
thanks!
Jim Chybicki
Re: F24 Wing Struts
'Jim,
I bought one of these from Holloway Engineering
http://www.radialengine.com/flywire/flywire2.htm
And then graphed out and interpolated for the tensions that are off his 'Tie wire' scale. I have not used it yet as I have not got that far.
Maybe if you graph out his figures we could then compare our results and if there is an appreciable difference take a closer look to see who is right.
If you would like to borrow my tool then just let me know and I will get it to you.
Frank Cox
UC61K G-BCBL
Frank Cox
UC61K G-BCBL
Sent: Tuesday, January 31, 2012 3:08 PM
Hi All
thanks!
Jim Chybicki
Re: F24 Wing Struts
'Whenever I redo wings, I use the thread torque as the primary means of
tensioning the wires. Once you have the correct torque, they should be
tight enough. You would not want to go beyond the torque levels anyway.
These are not flying wires after all.
As for the struts, I have had mine inspected by a local machine shop
that does military work. They have an eddy current machine and a couple
of other means of inspecting metal. I would start aking around there.
They all seem to know each other and what equipment they all have.
Joe
[mailto:fairchildclub@yahoogroups.com] On Behalf Of james chybicki
Sent: Tuesday, January 31, 2012 10:09
Hi All
ready to cover.
damaged (dented)
for sales or trade?
thanks!
Jim Chybicki
Joe
Hi All
ready to cover.
damaged (dented)
for sales or trade?
thanks!
Jim Chybicki
Re: F24 Wing Struts
'Jim
The structural repair manual tells you what the stream line tubing matierial and the thickness is, the 24 blue print 44169 and 44170 shows how to construct them. I dont know if the anyone has the streamline tubing but if you can get it you should be able to construct a set of struts.
Jim Higham
N81207
Sent: Tuesday, January 31, 2012 9:08 AM
Hi All
thanks!
Jim Chybicki
Jim Higham
N81207
Hi All
thanks!
Jim Chybicki
Re: F24 Wing Struts
'What was the price of the flying wire tensiometer?
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of F.J. & D.A. Cox
Sent: Tuesday, January 31, 2012 9:51 AM
Subject: Re: [fairchildclub] F24 Wing Struts
Jim,
Frank Cox
UC61K G-BCBL
Jim,
Frank Cox
UC61K G-BCBL
Hi All
thanks!
Jim Chybicki
Re: F24 Wing Struts
'somewhere around $200 if I remember rightly - It was about 3 years ago when I was 'Getting tools for the job'
Sent: Tuesday, January 31, 2012 4:49 PM
Subject: RE: [fairchildclub] F24 Wing Struts
Jim,
Frank Cox
UC61K G-BCBL
Hi All
thanks!
Jim Chybicki
Re: F24 Wing Struts
'Jim,
I think I might know where a set is located. Contact me. I have some tailwheel questions for you also. 9mo3@ponyexpress.net
Steve Lawlor
Steve Lawlor
'--- In fairchildclub@yahoogroups.com, james chybicki wrote:
> Hi All
> Â
> Â
> thanks!
> Jim Chybicki
> Â
> Â
Re: F24 Wing Struts
'Hi Frank
Thank you for your offer to borrow the flywire tension tool
after looking at the Website and confiring with our Inspector, I do not see any way to
attach the tool to the drag wires due to rib placements. I will continue to research
the torque issues and report our findings
thanks
JIM C.
Sent: Tuesday, January 31, 2012 9:50 AM
Jim,
Frank Cox
UC61K G-BCBL
thanks
JIM C.
Jim,
Frank Cox
UC61K G-BCBL
Hi All
thanks!
Jim Chybicki
