Re: Cabin Insulation F24
Frank
Post by Frank »
'Folks -
The time has come to install the cabin interior.
The old cabin upholstery (Military UC61K), with no cabin heating, had cotton wadding insulation outside the headlining and sides - This did not look too fire resistant to me.
What do people use these days that is not going to fry the occupants too quickly in the event of a 'Nasty'?
Many thanks
Frank'
paul pinato
SV: [fairchildclub] Cabin Insulation F24
Post by paul pinato »
'Hi folks
My 1943 UC61A had asbestos between the cotton
liners. Military spec.
Paul Pinato
St. Persgatan 128 B
602 30 Norrköping
Sweden
+46 (0)11 181 509
+46 (0)705 411 118
paul.pinato@swipnet.se
Från: fairchildclub@yahoogroups.com
[mailto:fairchildclub@yahoogroups.com] För Frank
Skickat: den 25 januari 2012 12:24
Till: fairchildclub@yahoogroups.com
Ämne: [fairchildclub] Cabin Insulation F24
Folks -
'Nasty'?
Many thanks
Frank
Tom_Downey
Post by Tom_Downey »
'I used the fiberglass from the house insulation, with a light weight cotton backing to hold it in place on the rear bulkhead. On the sides and top it stays OK with the fabric covers.
--- In fairchildclub@yahoogroups.com, "Frank" wrote:
> Folks -
> Many thanks
> Frank
Peter Ramm
Post by Peter Ramm »
'Check out Pegasus Aeromarine. They have good info about insulating GA
aircraft with certified materials that both lower noise and provide
thermal isolation. Not sure if that is your wish.
http://www.pegasus-aeromarine.com/acoustic-ed/index.html
I used a system based on their recommendations in an old twin. Works
well.
Peter
[mailto:fairchildclub@yahoogroups.com] On Behalf Of Tom_Downey
Sent: Wednesday, January 25, 2012 11:18 AM
Subject: [fairchildclub] Re: Cabin Insulation F24
, "Frank"
> Folks -
> Many thanks
> Frank
Post by robert Etter »
'The one thing I found is the fabric that they may have used.  WOOL.  When I took my Post war 24 apart, I found OD green upholstery all through it.  The welt at the base of the wind screen, door panels, and rear arm rests.  I am pretty sure it is wool.  I could do a match test.  If it doesn't burn like crazy, it is probably wool.  Some of the samples that I have are faded and water damages, but most of it hasn't seen sun light for years.
If you want a sample, let me know where to send it.
Sent: Wednesday, January 25, 2012 3:24 AM
Subject: [fairchildclub] Cabin Insulation F24
Folks -
Many thanks
Frank
F.J. & D.A. Cox
Post by F.J. & D.A. Cox »
'Thank you Bob.
At the moment I am working on it with a guy in the car restoration trade - If we can't come up with a suitable modern material I well may come back to you.
Thanks again
Frank
Sent: Friday, January 27, 2012 7:26 PM
Subject: Re: [fairchildclub] Cabin Insulation F24
Folks -
Many thanks
Frank
F.J. & D.A. Cox
'Thanks Peter for the link - If I can't find anything suitable on this side of the Pond I will give them a go.
Frank
Sent: Wednesday, January 25, 2012 4:22 PM
Subject: RE: [fairchildclub] Re: Cabin Insulation F24
well.
Peter
, "Frank"
> Folks -
> Many thanks
> Frank
