'Good Morning,
I need a wiring diagram for the starter circuit on a PT-26.
I have the diagrams for the generator, lights and so on, but nothing for the starter.
Many thanks for your help.
John Ellis
Re: Wiring diagram for starter for Ranger Engdine
John Ellis
mileslong2k
'Could it be the starter for this aircraft originally came with an inertia starter, hence no wiring diagram? Then years later a inertia/electric starter?
Jim'
Jim'
Gene Haines
'inertia or electric starter. Only one or the other.
Gene
To: fairchildclub
Sent: Wed, Sep 14, 2011 11:08 am
Subject: [fairchildclub] Re: Wiring diagram for starter for Ranger Engdine
Gene
To: fairchildclub
Jack Threadgill
'No inertia starter. The PT-19 had a direct drive hand crank. On the PT-26,
the hand crank was removed and replaced with an electric starter.
John, I am not real sure what you are wanting. I have no wiring diagram.
On mine, there is just a starter switch that activates a starter solenoid
that connects the battery to the starter. The battery and solenoid are
located behind the front pilots seat and between the rear pilots rudder
pedals.
Jack
Jack M. Threadgill
1602 Brook Hollow Dr
Bryan, Texas 77802
979-779-7155
threadgl@suddenlink.net
On Behalf Of mileslong2k
Sent: Wednesday, September 14, 2011 10:08 AM
starter?
pedals.
Jack
Jack M. Threadgill
Bryan, Texas 77802
979-779-7155
starter?
Re: Wiring diagram for starter for Ranger Engine
'Jim, Jack and all,
When I put my chime in on a technical question I usually get shot down - and as a turner/fitter and not aeronautical engineer that is hardly surprising. However, wearing my "historian's" hat I would like to clarify.
To the best of my knowledge all the M-62 series built by Fairchild had the manual starter and that includes the Hagerstown-built PT-26 (Cornell Mk.I). The one exception might be the final PT-19A that Fairchild bought back from the USAAF and upgraded for used by the company's own Flying Club. I seem to recall the modifications included an electric starter - Mike Kelly may be able to comfirm that.
All the PT-26A, PT-26B and Cornell Mk.IIs built by Fleet in Canada were built with electric starters and thus there was no hole in the cowling for the starter handle.
The above represents the situation when the aircraft were built and since then I understand many may have had the manual system replaced by an electric starter.
Hope this helps, Tony
> pedals.
> Jack
> Jack M. Threadgill
> Bryan, Texas 77802
> 979-779-7155
> threadgl@...
> starter?
> Jim
Jack Threadgill
'Charles, I am sure you are correct.
Thanks for the information.
Sent from my iPhone, Jack
'On Sep 15, 2011, at 3:03 PM, "Charles" wrote:
> Jim, Jack and all,
> > pedals.
> > Jack
> > Jack M. Threadgill
> > Bryan, Texas 77802
> > 979-779-7155
> > threadgl@...
> > starter?
> > Jim
'John,
A 337 for a PT-26 Jasco alternator installation is posted in the files section. A schematic for the start circuit is included in the 337.
'--- In fairchildclub@yahoogroups.com, "John Ellis" wrote:
> Good Morning,
> John Ellis
