'Hello Fairchild enthusiasts
I'm new to the group---Just started teaching in a PT-19. Got a little tailwheel shimmy that shows up intermittently on the landing rollout....Any suggestions?
Jeff Whitesell
topfun@fivetogether.com'
Re: tailwheel shimmy
'Hello Jeff
If you search the previous chats on this site your gonna find quite a few previous chats regarding this subject. It's been an issue/topic of conversation for the PT and F24's for years.
There is a lot of wisdom and BS in the conversations, but what works for one may not work for another. For my own I found I needed new keys in my strut and re-shimed the trailing link collar. No more issues.
Good luck
Jim Higham
F24
81207
Good luck
Jim Higham
F24
81207
> Jeff Whitesell
'I concur. Note that many PTs have fully splined shafts vs the 2 keys
mentioned by Jim found in a lot of F-24s.
'On Tue, Aug 16, 2011 at 1:43 PM, Jim wrote:
> Hello Jeff
> Good luck
> Jim Higham
> F24
> 81207
> suggestions?
> > Jeff Whitesell
ptcurt@gmail.com
'Land slower and have the tailwheel centered when lowering. Check to see if
the tailwheel and the rudder are pointing in the same direction.
Cy Galley; Editor - BC-Contact!
Supporting Bellancas every day
www.bellanca-championclub.com
On Behalf Of Jeffrey Whitesell
Sent: Tuesday, August 16, 2011 12:31 PM
Subject: [fairchildclub] tailwheel shimmy
suggestions?
Jeff Whitesell
suggestions?
Jeff Whitesell
Airy Millet
'First, check Tyre wear and pressure....
Then rely to old post of this group dealing with shimmy and tailwheel arrangement end play!
Airy
ex-F-AZCI F24R mechanics.
Date: Tue, 16 Aug 2011 10:30:35 -0700
Jeff Whitesell
Airy
Jeff Whitesell
