'Jon, contact John Ellis at
johnee35@att.net or give him a call at
 573-450-1676.  I believe he has a set of bearings.
 Does your breather come out of the top of the engine to a drain hose coming
 out the bottom of the cowl?
 Jack
 Jack M. Threadgill
 1602 Brook Hollow Dr
 Bryan, Texas 77802
 979-779-7155
threadgl@suddenlink.net
 On Behalf Of jwm1801
 Sent: Friday, June 03, 2011 6:11 AM
 Subject: [fairchildclub] Ranger Main Bearings Needed
 I am coming to the conclusion that my oil problems are from a sub-par
 overhaul. I have tried everything to control the oil coming out of the
 breather, including taking the cylinders off, sending them out for chroming,
 new rings and pistons. I just installed a new pressure pump and will fly it
 again tomorrow to see if this could make any difference but I am afraid my
 problem may be coming from the main bearings.
 According to the log book new bearings were installed during overhaul but my
 hunch after talking with the Ranger Engine Experts is this is probably my
 problem.
 This being said my newly finished restoration is again in need of work.
 I am looking for a set of new main bearings. Anyone know where I can find a
 set? JON MARTIN 610-476-1702
