Re: Should the brakes on a PT-19 move n tandem?
'When you press on the right brake the left brake also moves forward and vice versa making it impossible to differentially turn the aircraft. Both brakes always apply simultaneously. Is there something crossed? Thanks for any help...'
Gene Haines
'Sounds strange to me. On our PT they move separately.
Gene Haines
Sent: Mon, Jan 3, 2011 3:06 pm
Subject: [fairchildclub] Should the brakes on a PT-19 move n tandem?
Gene Haines
'Sounds like the rudder pivots need oiling and freeing.
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of Gene Haines
Sent: Monday, January 03, 2011 2:22 PM
Subject: Re: [fairchildclub] Should the brakes on a PT-19 move n tandem?
Gene Haines
Gene Haines
'Definitely should be independent. Remove the lower boot cowl and see what's
going on when the pedals are actuated. Maybe something in the parking brake
mechanism?
mechanism?
> fairchildclub@yahoogroups.com ] On Behalf
> Of Gene Haines
> Gene Haines
> From: roy25102 >
> To: fairchildclub@yahoogroups.com fairchildclub%40yahoogroups.com >
> any help...
ptcurt@gmail.com
John Ellis
'Has the aircraft been worked on or did this just start to happen..
Sent: Monday, January 03, 2011 2:06 PM
> for any help...
'Not too sure to be honest with you.. I know it has been worked on but it may have been going on prior to that...
