Re: Should the brakes on a PT-19 move n tandem?
roy25102
Post by roy25102 »
'When you press on the right brake the left brake also moves forward and vice versa making it impossible to differentially turn the aircraft. Both brakes always apply simultaneously. Is there something crossed? Thanks for any help...'
Gene Haines
Post by Gene Haines »
'Sounds strange to me. On our PT they move separately.
Gene Haines
Sent: Mon, Jan 3, 2011 3:06 pm
Subject: [fairchildclub] Should the brakes on a PT-19 move n tandem?
Cy Galley
Post by Cy Galley »
'Sounds like the rudder pivots need oiling and freeing.
From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of Gene Haines
Sent: Monday, January 03, 2011 2:22 PM
Subject: Re: [fairchildclub] Should the brakes on a PT-19 move n tandem?
Gene Haines
Curt Kinchen
Post by Curt Kinchen »
'Definitely should be independent. Remove the lower boot cowl and see what's
going on when the pedals are actuated. Maybe something in the parking brake
mechanism?
> fairchildclub@yahoogroups.com ] On Behalf
> Of Gene Haines
> Gene Haines
> From: roy25102 >
> To: fairchildclub@yahoogroups.com fairchildclub%40yahoogroups.com >
> any help...
Curt Kinchen
ptcurt@gmail.com
John Ellis
Post by John Ellis »
'Has the aircraft been worked on or did this just start to happen..
Sent: Monday, January 03, 2011 2:06 PM
> for any help...
roy25102
Post by roy25102 »
'Not too sure to be honest with you.. I know it has been worked on but it may have been going on prior to that...
