Re: Spark Plugs
Spark Plugs
'Anyone know of a source to purchase BG 417S spark plugs? It seems the REM 40's are readily available but I'd like the shorter/smaller plugs for the left side for clearance behind the carb. My ranger is -C5 engine.
The previous owner left me som BG4B2s plugs. Are these interchangeable?
Dave'
Dave'
Re: Spark Plugs
'Just curious..is your harness shielded? Are the BG plugs shielded?
Ranger Mike
Ranger Mike
Sent: Thursday, August 26, 2010 8:24 PM
Subject: [fairchildclub] Spark Plugs
> Thanks,
> Dave
Re: Spark Plugs
'This fella might. He's helped me before......
http://www.plugguy.com/
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Christavia C-FDWS
Sent: Thursday, August 26, 2010 11:24 PM
Dave
Checked by AVG - www.avg.com
Version: 8.5.441 / Virus Database: 271.1.1/3093 - Release Date: 08/25/10 06:34:00
Re: Spark Plugs
'The harness is shielded as are the plugs.
> Ranger Mike
> From: "basinaviation"
> > Thanks,
> > Dave
> > Yahoo! Groups Links
Re: Spark Plugs
'The REM37BY plug is 3/8" shorter than the REM40E plug. It has exposed electrodes. Not sure if it has fed blessings for the Ranger though it does fit nicely behind the carb making access a lot easier.
Charles
Charles
> Thanks,
> Dave
Re: Spark Plugs
'Thanks Charles. Mr Joe Denest came through for me and found a few BG 417s plugs for me. Funny thing is while searching around on the internet, I missed an eBay auction for 15 of them by 2 mins. They sold for only $13.50.
> Charles
> > Thanks,
> > Dave
Re: Spark Plugs
My BG manuals call for 417S or 4B2-S for all model Ranger engines. I'm running the BG4B2-S now and have had no real carbon fouling or lead deposits. I'm not running any additives in the fuel or oil to prevent lead deposits. As long as they keep coming out reasonably clean , I don't plan on it. I bought a can of 4B2-S from Fresno Air parts .They were Manufactured and sealed in a vacuum sealed can during the war years. They were like new. There's 30 in a can, I don't remember the price being outrageous. The 4B2-S type also has a little shorter neck (the shield tube on top the plug) which helps with the plug behind the Carb. Hope this helps,
Hanford,Ca'
Dave,>
> Thanks,
> Dave
Hanford,Ca'
Re: Spark Plugs
'Thanks Tom. Where can I get a copy off that BG manual? I've noticed on other engines the two plugs were interchangeable but the FAA certificate for ranger engine only lists the champion plugs and BG 417s. Anyway to convince the Faa to make an update? Might take another 40 yrs but its a start....
> > Thanks,
> > Dave
> Dave,
> Tom
> Hanford,Ca
Spark Plugs
'Hi All!can I get some input on Spark Plugs for a 200 HP with a Fresh "0" hour Overhaul?I pulled the Champion REM40E off. I am flying in the Chicago area, so we will have HOT and COLD days.let me know what your running?thanksJIM CHYBICKIMidwest Aeronautique LLC1943 UC-61K USAAF# 43-14964 / RAF # HB690
Re: Spark Plugs
'Hi AllThis is for the 200HP RANGER engine
#ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173 -- #ygrps-yiv-1339402917yiv3274914173ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp #ygrps-yiv-1339402917yiv3274914173hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp #ygrps-yiv-1339402917yiv3274914173ads { margin-bottom:10px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp .ygrps-yiv-1339402917yiv3274914173ad { padding:0 0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp .ygrps-yiv-1339402917yiv3274914173ad p { margin:0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mkp .ygrps-yiv-1339402917yiv3274914173ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ygrp-lc { font-family:Arial;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ygrp-lc #ygrps-yiv-1339402917yiv3274914173hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ygrp-lc .ygrps-yiv-1339402917yiv3274914173ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span { font-weight:700;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span:first-child { text-transform:uppercase;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span span { color:#ff7900;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173activity span .ygrps-yiv-1339402917yiv3274914173underline { text-decoration:underline;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach div a { text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach img { border:none;padding-right:5px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach label { display:block;margin-bottom:5px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173attach label a { text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 blockquote { margin:0 0 0 4px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173bold a { text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 dd.ygrps-yiv-1339402917yiv3274914173last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 dd.ygrps-yiv-1339402917yiv3274914173last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 dd.ygrps-yiv-1339402917yiv3274914173last p span.ygrps-yiv-1339402917yiv3274914173yshortcuts { margin-right:0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173attach-table div div a { text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173attach-table { width:400px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a:active, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a:hover, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173file-title a:visited { text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a:active, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a:hover, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div.ygrps-yiv-1339402917yiv3274914173photo-title a:visited { text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 div#ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg #ygrps-yiv-1339402917yiv3274914173ygrp-msg p a span.ygrps-yiv-1339402917yiv3274914173yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173green { color:#628c2a;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173MsoNormal { margin:0 0 0 0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 o { font-size:0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173photos div { float:left;width:72px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173reco-category { font-size:77%;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173reco-desc { font-size:77%;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 .ygrps-yiv-1339402917yiv3274914173replbq { margin:4px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg select, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 input, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg pre, #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 code { font:115% monospace;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-mlmsg #ygrps-yiv-1339402917yiv3274914173logo { padding-bottom:10px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-msg p#ygrps-yiv-1339402917yiv3274914173attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-reco #ygrps-yiv-1339402917yiv3274914173reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-sponsor #ygrps-yiv-1339402917yiv3274914173ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-text { font-family:Georgia;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-text tt { font-size:120%;} #ygrps-yiv-1339402917 #ygrps-yiv-1339402917yiv3274914173 #ygrps-yiv-1339402917yiv3274914173ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-1339402917
