To: Fairchild Yahoo site post
Sent: Wednesday, June 02, 2010 6:51 PM
Subject: FW: [fairchildclub] Re: drawings from NASM
fairchildclub@yahoogroups.com
> From:
shadowll@msn.com
> Date: Wed, 2 Jun 2010 06:23:42 -0700
> Subject: RE: [fairchildclub] Re: drawings from NASM
> Try: nasm.si.edu/research/arch/collections/techdraw/fairchild24.cfm That should do it. Marc
> From:
wmclayman@comcast.net
> Date: Wed, 2 Jun 2010 05:46:12 -0500
> Subject: Re: [fairchildclub] Re: drawings from NASM
> Hugh,
> Yes, they are/were online. I will post the url when I once again have found it.
> Thanks,
> Ed
> From: Hugh Loewenhardt
> Sent: Tuesday, June 01, 2010 9:26 PM
> Hello wclayman, For my project, I use hard copies of the drawing indices obtained from NASM as explained in my reply to Jp.Lorie. If the indices for the various model F-24's are available on the Internet that is(would) be a great thing but at this point I am unaware of it. I will do some research to find out. Regards, Hugh
> --- On Tue, 6/1/10, wclayman wrote:
> > From: wclayman
> > To:
> > Date: Tuesday, June 1, 2010, 4:35 PM
> > Hugh,
> > Your post is timely. The NASM indexes are being turned
> > topsy turby over the next two months. I lost the drawing
> > index url. Please share the "current" url for the
> > index. I spent three hours chasing the rabbit hole on
> > Friday. I found new resources, however I came up empty on
> > the url for the drawing indexes. There are many new avenues
> > in the NASM and Smithsonian web sites and data bases.
> > Thanks in advance for your contributions to this list.
> > Ed
> > From: Jp Lorie
> > To:
> > Sent: Tuesday, June 01, 2010 11:16 AM
> > Subject: [fairchildclub] Re: drawings from NASM
> > Hi Hugh,
> > Can you tell us what NASM is and how to get to it.
> > Thanks,
> > Jp.Lorie
> > Florida
> > ________________________________
> > To:
> > Sent: Fri, May 28, 2010 4:35:13 PM
> > Subject: Re: [fairchildclub] Motor Mounts
> > You may or may not find drawing 48107 in Jamies's CD as
> > it contains certification drawings only(not sure which
> > model) and is not inclusive of all drawings utilized in the
> > manufacturing process. The construction drawing indices for
> > each model(available from NASM) lists all the drawings used
> > to construct the various models. I just checked the drawing
> > index for the G model and drawing 48107 is listed as
> > applicable.
> > --- On Fri, 5/28/10,
burnmcc@aol.com
> > wrote:
> > > From:
burnmcc@aol.com
> > > To:
> > > Date: Friday, May 28, 2010, 1:35 PM
> > > OK, Many thanks. I have the Fairchild CD from Jamie,
> > a
> > > little hard to navigate (at least for me) but I will
> > see if
> > > I can find it with that info.
> > > Thanks again.
> > > Bill McC
> > > -----Original Message-----
> > > To:
> > > Sent: Thu, May 27, 2010 8:58 pm
> > > Bill, The original engine installation washer for
> > the
> > > Warner 145 on Fairchild 24's with integral
> > engine mounts
> > > is: a 1.250"x1.250"x0.1875"thick
> > washer with
> > > an 11/32" center hole. The washer is
> > manufactured from
> > > brake lining material. Dimensions and material are
> > as
> > > specified by Fairchild drawing number 48107.
> > Drawing
> > > applicability is: C8C,C8E,24G,24J, and 24W9. The
> > drawing is
> > > available from NASM or I can send you copy. Your
> > choice.
> > > Hugh Loewenhardt
> > > --- On Thu, 5/27/10,
mcclurebill@rocketmail.com
> > > wrote:
> > > > From:
> > > > Subject: [fairchildclub] Motor Mounts
> > > > To:
> > > > Date: Thursday, May 27, 2010, 12:37 PM
> > > > I'm finally getting close to having an
> > engine
> > > > to install in my 24G. I still haven't got
> > a
> > > definitive
> > > > answer on the proper rubber to put between the
> > engine
> > > and
> > > > the motor mount. These have the mount that is
> > integral
> > > with
> > > > the fuselage frame. Upon removing the failed
> > engine I
> > > found
> > > > the rubber to be pieces cut out of tire
> > sidewall. I
> > > have
> > > > since found out from other sources that this
> > may in
> > > fact be
> > > > the right thing to put there. Can anyone with
> > a
> > > similar 24
> > > > tell me what was used in their aircraft?
> > Thanks.
> > > [Non-text portions of this message have been
> > removed]
> > No virus found in this incoming message.
> > Checked by AVG -
www.avg.com
> > Version: 9.0.819 / Virus Database: 271.1.1/2910 - Release
> > Date: 06/01/10 01:25:00
> Checked by AVG -
www.avg.com
> Version: 9.0.819 / Virus Database: 271.1.1/2910 - Release Date: 06/01/10 01:25:00
> __________________________________________________________
> The New Busy is not the old busy. Search, chat and e-mail from your inbox.
http://www.windowslive.com/campaign/thenewbusy?ocid=PID28326::T:WLMTAGL:ON:WL:en-US:WM_HMP:042010_3
Checked by AVG -
www.avg.com
Version: 9.0.829 / Virus Database: 271.1.1/2913 - Release Date: 06/02/10 04:57:00
