'I have a F-24H with a 200hp Ranger can anyone tell me the correct wood prop for the aircraft?
Neil Baughman
Re: Prop Question
Re: Prop Question
'neil ,i have two references,but is important to know wich engine is .
sensenich 86 rb 60 and hartzell 8613e-54.
francisco molina
francisco molina
> for the aircraft?
> Thanks
> Neil Baughman
Re: Prop Question
'check the sensenich website they have a list of what fits the ranger and F24.
NC28636
Date: Sun, 14 Jun 2009 16:41:45 -0400
Subject: Re: [fairchildclub] Prop Question
francisco molina
NC28636
francisco molina
> for the aircraft?
> Thanks
> Neil Baughman
Windows Live?: Keep your life in sync.
http://windowslive.com/explore?ocid=TXT_TAGLM_WL_BR_life_in_synch_062009
Re: Prop Question
'I don't have much information, but it is an old copy of some stuff that I
found at the FAA office many years ago (1974). It shows a 24R46 only a
175hp using a 86RB60 Sensenich. The C-61 & UC-61K with 200hp as using an
86AB54.
Looking at the numbers leave me with doubts. The prop for the 200hp motor
uses less geometric pitch and a 175 hp motor.
The document that I'm looking is a copy of Sensenich Corp, dated August
1955, No.203.
The civilian manual I have, doesn't show information about post war models
or anything with 200hp motors.
The Military manual doesn't help me when it come to HP numbers, but
according to it, the UC-61K uses a 86AB54 Sensenich prop.
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
86AB54.
1955, No.203.
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
Sent: Sunday, June 14, 2009 3:49 PM
Subject: RE: [fairchildclub] Prop Question
F24.
NC28636
francisco molina
> prop
> for the aircraft?
> Thanks
> Neil Baughman
Windows LiveT: Keep your life in sync.
Re: Prop Question
'neil :
is important to specify the engine,check the maximun rpm,is ideal to have
the type certificate for your airplane and your engine but if this is not
possible,check the maximun
rpm given for the propeller operation.,more or less pitch with the
acceptable rpm from the prop manufacturer
is the main point.
francisco molina
is the main point.
francisco molina
> 86AB54.
> 1955, No.203.
> Robert Etter
> PO Box 974
> Tonopah, NV
> 89049
> Tele. 775.482.6820
> Cell 702.265.6906
> From: "frank gochenauer" >
> F24.
> NC28636
> From: expressform@gmail.com
> francisco molina
> > prop
> > for the aircraft?
> > Thanks
> > Neil Baughman
Re: Prop Question
'Has anyone looked at the aircraft Type Data Sheet? As I re-call that is
the controlling document as far as the FAA is concerned.
In a message dated 6/15/2009 7:13:36 P.M. Eastern Daylight Time,
rletter@citlink.net writes:
86AB54.
1955, No.203.
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
F24.
NC28636
To: _fairchildclub@fairchildclufai_ (mailto:fairchildclub@yahoogroups.com)
From: _expressform@expressfo_ (mailto:expressform@gmail.com)
francisco molina
_http://windowslive.http://windohttp://wihttp://wihttp://windhttp://windo_
(http://windowslive.com/explore?ocid=TXT_TAGLM_WL_BR_life_in_synch_062009)
**************An Excellent Credit Score is 750. See Yours in Just 2 Easy
Steps!
(http://pr.atwola.com/promoclk/100126575x1221322979x1201367215/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072&hmpgID=62&bcd=Jun
eExcfooterNO62)
86AB54.
1955, No.203.
Robert Etter
PO Box 974
Tonopah, NV
89049
Tele. 775.482.6820
Cell 702.265.6906
F24.
NC28636
francisco molina
[Non-text portions of this message have been removed]>
> prop
> for the aircraft?
> Thanks
> Neil Baughman
Steps!
eExcfooterNO62)
Re: Prop Question
'That depends upon which TCDS you look at.. mine says any wood prop that will limit the RPM to ________ .
Re: Prop Question
'Thanks for the info. I'm leaving for vacation today but I'll check the manuals and TCDS when I return.
Neil
Neil
'--- On Tue, 6/16/09, Tom Downey wrote:
Subject: [fairchildclub] Re: Prop Question
Date: Tuesday, June 16, 2009, 1:10 AM
