Re: Empty Weight
Empty Weight
'What is the Empty Weight of your F-24 ?'
Re: Empty Weight
'1635 pounds
John Duncan
Date: Fri, 12 Jun 2009 01:40:27 +0000
Subject: [fairchildclub] Empty Weight
John Duncan
Re: Empty Weight
'Thanks John,,,,, Is 16-1700 typical?
'> 1635 pounds
> John Duncan
Re: Empty Weight
'Yes, I think so. Mine is a 1937 model.
John Duncan
Date: Fri, 12 Jun 2009 01:56:19 +0000
Subject: [fairchildclub] Re: Empty Weight
John Duncan
[Non-text portions of this message have been removed]'> 1635 pounds
> John Duncan
Re: Empty Weight
'I finally got mine on a set of scales, actual empty weight was 1643, with a CG of 19.1" aft of datum.
Full fuel weight was 2054 Lbs.. doesn't leave much to work with at 2400lbs gross.
'> Yes, I think so. Mine is a 1937 model.
> John Duncan
Re: Empty Weight
'1735# for a '46 with a 200 Ranger.
N81228 - Bob Webster
Sent: Thursday, June 11, 2009 8:40 PM
Checked by AVG - www.avg.com
Version: 8.5.339 / Virus Database: 270.12.63/2169 - Release Date: 06/11/09 05:53:00
Re: Empty Weight
My 1939 24-K weighs 1756 empty and I think my max gross is 2560. It is the short-nosed Ranger. Since I only have 40 gal capacity, I have a good useful load. Although it will lift a lot more than the paperwork would suggest, I always try to make sure I make a really smooth landings when near gross. I would be happy to give up some of that passenger capacity for an extra twenty gallons of fuel.
Webster, MN
Webster, MN
Re: Empty Weight
'1938 F24-J, no flaps, 40 Gal fuel, 200 HP Ranger, empty weight: 1545 lbs. (I guess I got real lucky).
Steve Kretsinger
NC20615
Eugene, OR
Steve Kretsinger
NC20615
Eugene, OR
Date: Thursday, June 11, 2009, 6:40 PM
Re: Empty Weight
'Lucky and light. Good for you Steve.
Jan
Sent: Mon, Jun 15, 2009 1:31 pm
Subject: Re: [fairchildclub] Empty Weight
Steve Kretsinger
NC20615
Eugene, OR
Jan
Steve Kretsinger
NC20615
Eugene, OR
