Re: aluminum bronze bushing stock
cagog
Post by cagog »
'One of the fairchild SERVICE BULLITENS states the oilite bushings be
replaced with the ALUMINUM/BRONZE type and grease points added. They
give the FAIRCHILD part # for the items but not the specific material.
Anyone have a source for the raw stock that they have used. Or know a
alloy number for the aluminum/bronze stock?'
Cy Galley
Post by Cy Galley »
'http://www.mcmaster.com/ p3619
Cy Galley
Editor in Chief - BC-Contact!
Supporting Bellancas everyday
www.Bellanca-Championclub.com----- Original Message -----
Sent: Thursday, October 02, 2008 5:20 PM
Subject: [fairchildclub] aluminum bronze bushing stock
Pilot4906@aol.com
Post by Pilot4906@aol.com »
'What part number was given?? Perhaps there is a drawing for the part number in my data base of drawings.
Gene Haines
Sent: Thu, 2 Oct 2008 6:20 pm
cagog
Post by cagog »
'--- In fairchildclub@yahoogroups.com, Pilot4906@... wrote:
Gene,
The bushing part numbers in the bulliten are 61139-1 and 61139-2.
Ryan
> Gene Haines
> From: cagog
be
They
material.
a
Tom Mueller
Post by Tom Mueller »
'I've not seen this Service bulletin. In fact the only one I've ever
seen was the one about checking for cracks at the landing gear
attachment. I do know these bushings have to be made of Bronze
Aluminum material and that an ordinary Bronze sintered bearing will
not hold up to the shear forces involved. Drawing 40462 refers to a
bronze bushing , Fairchild part # S-112-7, and is only referred to as
a Bronze bushing on that drawing. However a service manual for the UC-
61K refers to these bushings as Aluminum Bronze. I believe the latter
and recently had some made. There's no grease fitting on these
bushings, but there is grease alemite fitting on the steel sleeve
the two bushing halves press into. I don't think there's a lot of
choices for Aluminum Bronze bar stock, it's a standard alloy mix, and
very strong. Hope this helps.
Hanford,Ca'
cagog
Post by cagog »
'I should have been more specific. It is for the M-62 (PT-19,23,26)
airplanes. Bulliton No. 42-5-C FEB. 5,1942
will
as
UC-
latter
sleeve
and
> Tom
> Hanford,Ca
