'About once a year I have to remove my E-80 and send it off to have it
de-oiled and the clutch adjusted. It just starts slipping badly.
Anyone here familiar enuf with the starter to point me to a guide for
performing the work myself? My aircraft is experimental so yellow tags
are optional.
Ranger Mike
Experimental Great Lakes 2t-1a'
Re: Champion C26 plugs needed
Re: E-80 Starter
'Is there a seal that needs replacing?
Sent: Thursday, August 28, 2008 3:53 PM
Subject: [fairchildclub] E-80 Starter
are optional.
Ranger Mike
Mike Danielle
Re: E-80 Starter
'The seal was replace last o'haul, 8 mo ago.
MD
MD
Sent: Friday, August 29, 2008 6:27 AM
Subject: Re: [fairchildclub] E-80 Starter
> From: Michael Danielle
> are optional.
> Thanks
> Ranger Mike
David Stroud
'Does anyone on the list have a source for Champion C26 plugs ? They may have been
specified for a Warner engine with unshielded plug wires. Thanks.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
Christavia C-FDWS
'Dave, I have 8 C26 Champion plugs. The electrodes are sharp but
not clean. The nut portions have some rust
The porcelain are clean and the brass knobs fine. Unfortunately the boxes
are not pristine either. I think they will clean up
And would serviceable. If you like I'll send you some pictures. Bob Haas
On Behalf Of DAVID STROUD
Sent: Sunday, August 31, 2008 10:20 AM
Subject: [fairchildclub] Champion C26 plugs needed
been
Christavia C-FDWS
been
Christavia C-FDWS
n244ms@aol.com
'Dave, I have several new C-26 plugs in boxes. How many do you need? I
will check to see how many total I have that I can let go of.
Mike Still
Chandler, AZ
**************It's only a deal if it's where you want to go. Find your travel
deal here.
(http://information.travel.aol.com/deals?ncid=aoltrv00050000000047)
Mike Still
Chandler, AZ
deal here.
David Stroud
'Got an offer from another for a set of four used, but I'd prefer a
set of four new plugs if you can spare them. Pls. say price if they are
available including cost to mail them to zip K0A2T0 in Ontario, canada.
Thanks Mike.
Christavia C-FDWS
Thanks Mike.
Christavia C-FDWS
Sent: Sunday, August 31, 2008 3:34 PM
Subject: Re: [fairchildclub] Champion C26 plugs needed
Mike Still
Chandler, AZ
deal here.
Checked by AVG - http://www.avg.com
Version: 8.0.169 / Virus Database: 270.6.14/1643 - Release Date: 30/08/2008 5:18 PM
David Stroud
'Good morning, Mike. Any chance you found four good plugs ? Thanks.
Christavia C-FDWS
Christavia C-FDWS
Mike Still
Chandler, AZ
deal here.
