'WANTED ? I am looking for a set of steps , Gear legs prefer with tie
down rings "Export" but not required, Rear aluminum lift strut
preferred steel will work or a project with these parts, Send me a
picture of what you have or drop me a call , Wenatchee, WA
Telephone: 509 679-0721
Have a good day'
Re: 24W41 or later parts needed
'Just in case you didn't know. Those case rings that are located on the lower front of the main gear legs, are for towing....only. A gentleman that I know, used them for tie-downs. That was the last time that the airplane flew. I had heard that some one was attempting to repair it. All 4 spars were broken, and the top of the cabin had been crushed about 4 inchs. The metal parts that is.
A high wind hit the front of the airplane causing the main struts to extend fully. This imparted a large increase in the angle of attack to the unmanned airplane. Both rings snapped off in a heart beat, and over she went.
Sent: Sunday, March 09, 2008 9:54 AM
Subject: [fairchildclub] 24W41 or later parts needed
WANTED . I am looking for a set of steps , Gear legs prefer with tie
Have a good day
Alan Macon
the lower front of the main gear legs, are for towing....only. A>
to extend fully. This imparted a large increase in the angle of>
tie> Bob
> From: Alan Macon
a> down rings "Export" but not required, Rear aluminum lift strut
I also think they were also installed on export aircraft.I> picture of what you have or drop me a call , Wenatchee, WA
> Have a good day
> Thanks Bob
Thanks Alan Macon> have a right gear . They can be seen in the photo section.
'> [Non-text portions of this message have been removed]
