 Sent: Wednesday, November 07, 2007 3:00 PM
 Subject: [fairchildclub] Re: Ranger Mods
 >I concur with Mike Denest.  Besides I've always thought machining and
 > drilling the piston, although making it similar to other aircraft
 > pistons out there, might induce some unknown failure modes.
 > MMO for the sticky rings is the answer, I believe.   I quit using MMO
 > for around 50 hours and sure enough upon disassembly found many
 > carbon fouled/stuck rings.
 > Curt
 > --- In
fairchildclub@yahoogroups.com, "Mike Danielle"
 > wrote:
 >> Hello again Mike.  Not worried about approvals as my aircraft is
 >> experimental.  However, I don't want to go through a lot of
 > gyrations and
 >> money to do the mods and still see the same oil consumption I've
 > been
 >> experiencing.  Based on your comments, I think I'll save the money.
 >> This is the engine your dad set up for me and it's been a good
 > runner.  I
 >> did have the one cylinder leaking at the joint and was looking for
 > the right
 >> time to replace it.  That time came this year when a compression
 > check
 >> showed an exhaust leak on the No 6 jug.  On any other engine I'd
 > just stake
 >> the valve and clean it up.  But if I had to open the cam box I
 > figured, what
 >> the hell, go ahead and replace both offenders.  The engine had been
 > using
 >> 1 - 2 qts/hr tending to the high side on aerobatic flights.  The
 > No. 1 jug
 >> had two aligned rings and they were stuck.  That was also the one
 > leaking at
 >> the joint.  I gather the remedy for this is lots of MMO.  Is that
 > what is
 >> recommended?
 >> What got me started on this thread was hearing more than one person
 > tell me
 >> they were burning only 1pt/hr with the fancy mods.  The one I
 > mentioned at
 >> Hood River showed up with a PT and uncowled it to reveal the
 > leakiest engine
 >> I've ever seen on a flyable aircraft.  I'm sure it was leaking MORE
 > than
 >> 1pt/hr just at the case joints.  But it's never polite to call
 > someone a
 >> liar.
 >> Thanks for the words of wisdom, Mike.
 >> Mike Danielle (Ranger Mike)
 >> From: "Michael Denest"
 >> To:
 >> Sent: Tuesday, November 06, 2007 4:29 PM
 >> Subject: Re: [fairchildclub] Re: Ranger Mods
 >> > Interesting in that this subject occasionally pops up.
 > The "Menasco Mod"
 >> > is not approved for the Ranger engine and constitutes a major
 > alteration,
 >> > requiring supporting engineering and FAA 337 approval to
 > incorporate the
 >> > mod ($$$$$ and a waste of time).  The key to getting low oil
 > consumption
 >> > is proper fit of the rings to the cylinder regardless if it is
 > standard ,
 >> > .010 oversize or .020 oversize.  For this to work, the cylinders
 > should be
 >> > either standard (4.125 inch), ground to .010 over or .020 over.
 > Set the
 >> > ring end gap to .018 to .020 inch then assemble per the manual.
 > Run the
 >> > engine for an initial 25 hours on SAE 60 mineral oil then switch
 > to SAE 60
 >> > AD.  1 to 1.5 quarts/hr is the average consumption.  Anything
 > less is
 >> > either fantasy or pure bull hockey.
 >> > Mike
 >> > Quando omni flunkus moritati
 >> > (If all else fails, play dead)
 >> > - "Red" Green
 >> > From: Curt Kinchen
 >> > To:
 >> > Sent: Tuesday, November 6, 2007 1:22:03 PM
 >> > I suspect he means 1 -1.5 quarts per hour. If you do a search on
 >> > Ranger Oil Consumption in the messages, you'll find several
 >> > discussions on mods, oil use, etc.
 >> > I'm on my 4th Ranger, one had all the mods(drilled pistons with
 >> > chamfered ring groove, sludge plug o-rings, intake valve seals,
 > tight
 >> > bearings, etc), one none, one some, and my latest with none. All
 >> > have used between 1-1.5 quarts depending on how hard they were
 > being
 >> > pushed. I've not heard anyone real happy with anything but
 > standard
 >> > rings.
 >> > I'm don't think much, if anything, is gained with the mods. Resign
 >> > yourself to using over a quart an hour and if you get a bit below
 >> > that be happy. That's just the way Rangers are.
 >> > The lowest reliable consumption I've ever heard of is .75
 > quarts/hour.
 >> > Curt Kinchen
 >> > --- In fairchildclub@ yahoogroups. com, "Mike Danielle"
 >> > wrote:
 >> >> Hmmmm.... Do you mean 1 to 1.5 PINTS per hour?
 >> >> MD
 >> >> From: "Robert Webster"
 >> >> To:
 >> >> Sent: Monday, November 05, 2007 5:54 PM
 >> >> Subject: Re: [fairchildclub] Ranger Mods
 >> >> > It is called the Menasco Mod and is a few holes drilled below
 >> > (above - it
 >> >> > is an inverted engine) the oil ring on the pistons. No changes
 >> > on the
 >> >> > cylinder. John Ferrero did mine (J&C Aircraft Engines) and
 > after
 >> > break in
 >> >> > about 50 hours I am down to 1 to 1.5 quarts per hour. I don't
 >> > know if
 >> >> > John still has new pistons or not.
 >> >> > Bob Webster
 >> >> > From: Jan Servaites
 >> >> > To: fairchildclub@ yahoogroups. com
 >> >> > Sent: Monday, November 05, 2007 5:30 PM
 >> >> > I know nothing about these Ranger mods. Would there be an on-
 > line
 >> >> > article that talks about them?
 >> >> > Thanks in advance,
 >> >> > Jan
 >> >> > james chybicki wrote:
 >> >> > > I believe Ed Wagner in Sheboygan, Wisconsin
 >> >> > > does the Oil Modifications on the Ranger Pistons
 >> >> > [Non-text portions of this message have been removed]
 >> >> > No virus found in this incoming message.
 >> >> > Checked by AVG Free Edition.
 >> >> > Version: 7.5.503 / Virus Database: 269.15.22/1111 - Release
 >> > Date:
 >> >> > 11/5/2007 4:36 AM
 >> >> > Yahoo! Groups Links
 >> > __________________________________________________
 >> > Do You Yahoo!?
 >> > Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
 >> > Yahoo! Groups Links
