Re: Empty Weights of Ranger-powered 24's
Roger Johnson
Post by Roger Johnson »
'Am considering getting another Ranger powered Fairchild 24 (owned, flew and enjoyed a 24R46 from '86 to '94) and would appreciate if someone could furnish the original empty weights of the following models: 24K, 24R9, 24R40 and 24R46A. Thanks very much!
Karl Saenger
Post by Karl Saenger »
'Roger,
Our UC-61K without the military equipment weighs in at approx. 1850
lbs including full oil.
UC-61K and 24R46A are similar.
Karl Saenger UC-61K c/n 891
--- In fairchildclub@yahoogroups.com, Roger Johnson
Roger Johnson
'Karl,
Thanks very much. Seems the 24 empty weights vary considerably; the 24R46 (converted to 200 h.p.) I had owned weighed 1,762 lbs w/o oil. Best wishes with yours.
With regards,
Roger Johnson
Karl Saenger wrote:
Roger,
plsurflyin@aol.com
Post by plsurflyin@aol.com »
'Mine weighs 1877 with full oil
************************************** Get a sneak peek of the all-new AOL at
http://discover.aol.com/memed/aolcom30tour
Roger Johnson
'Thanks. The reason I inquired about original empty weights of pre- and post-WWII models
was to get an idea of the amount of "fat" some have gained since new. If I'm correct, the 24R46A models weighed 1,730 lb w/o oil out of the factory. - Roger J.
danMichael
Post by danMichael »
'Roger:
The original factory weight and balance F24R46 shows 1730 lbs empty
weight (with no oil).
:Dan
:NC81323
Roger Johnson
'Dan,
Thanks very much! Am learning that quite a few 24Rs have gained considerable weight during 60 to 70 years, 10% or more with a couple them.
Roger
danMichael wrote:
Roger:
:Dan
:NC81323
