'anyone have the weight of a Warner engine-?
Dick Russell'
Re: [Fairchild club] Warner engine weight-?
Re: Warner engine weight-?
'Hello Dick,
W-125 weight dry 293 pounds
W-90 weight dry 237 with no generator starter or stacks
W-145 weight dry 306 pounds
W-165 weight dry 341-348 depending on model
W-185 weight dry 341-351 depending on model
This information is extracted from the Type Certificate Data Sheet.
Regards,
JD
Regards,
JD
Sent: Wednesday, January 04, 2006 5:28 PM
Subject: [fairchildclub] Warner engine weight-?
Dick Russell
YAHOO! GROUPS LINKS
'I wonder how much it weighs in running trim..ie all accessories. My book
says18lbs for the starter, 16 for generator, the metal prop is about 75 lbs,
the exhaust perhaps 15? So maybe we're up to 464 lbs with a few small
things missing. The Gesoco page shows the M14D as 473 dry but with
accessories..no exhaust or prop. If you added a wood prop at 25 lbs and
allow 15 for the exhaust, we'd have 513 lbs. Not bad for a claimed 220 hp
and dirt cheap to exchange instead of overhaul. TBO is sometimes claimed
to be 1,250. This is a new engine.
C-FDWS Christavia
F-24 C-FDAE in restoration
C-FDWS Christavia
Sent: Wednesday, January 04, 2006 8:13 PM
Subject: Re: [fairchildclub] Warner engine weight-?
Hello Dick,
Regards,
JD
Dick Russell
SPONSORED LINKS Private plane Fairchild semiconductor ! ; Plane reservation
YAHOO! GROUPS LINKS
YAHOO! GROUPS LINKS
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.12/220 - Release Date: 1/3/06
'JD -
Thanks much - looks like my Continental is about 70# heavier than the
Warner. What would a Ranger weigh-?
Dick
[mailto:fairchildclub@yahoogroups.com]On Behalf Of John Duncan
Sent: Wednesday, January 04, 2006 7:14 PM
Hello Dick,
Regards,
JD
Dick
Hello Dick,
Regards,
JD
Dick Russell
plane Fairchild
semiconductor Plane
reservation
Fairchild Jet
plane Pedal
plane
YAHOO! GROUPS LINKS
Service.
YAHOO! GROUPS LINKS
Service.
