Re: Engine mounts for non standard engines
David Stroud
Post by David Stroud »
'There's a lad on the list with a Continental or Jake on the nose of his F-24 and
I've forgotten his name. Might be another Russell. My question is for him or anyone
else that may know. When installing a larger radial than the stock Warner 165, I
guess one has to consider the extra weight and extra power and how it may affect
the front of the fuselage. Does anyone know if the fuselage of the 24 gets beefed up
with this type of conversion? Thanks.
David Stroud Ottawa, Canada
C-FDWS Christavia
F-24 C-FDAE in restoration
John Duncan
Post by John Duncan »
'Hello David,
N-81332 has a 220 Continental on its nose. You might look up the owner on the FAA website and contact him. I looked at buying this airplane ten years ago, and still retain a couple of pictures in my files. You will need an appropriate prop also!
Regards, John Duncan
Sent: Sunday, January 01, 2006 2:06 PM
Subject: [fairchildclub] Engine mounts for non standard engines
C-FDWS Christavia
YAHOO! GROUPS LINKS
Post by Jamie S. Treat »
'David,
There is no structural mods other then new engine mount. You will need to
install larger fuel lines, move batt aft. Also be aware that the extra
weight up front will add stress to the landing gear knuckle joints. One
failed on a 220 24W46 in Fla two years ago. They were the light joints. The
heavy joints are rare. The Jake STC is not available anymore, the owner
declines to sell due to liability.
The 220 will give you a legal two place airplane with partial fuel, the Jake
will give you a single seat with full food. The 220 and the Jake is not the
way to go by any means.
Go with the Ranger 200 or Warner 185.
Aircraft Restoration & Repair
Kelly Airpark
HM/Shop 303-648-0130
JamieTreat@direcway.com
Sent: Sunday, January 01, 2006 2:33 PM
Subject: Re: [fairchildclub] Engine mounts for non standard engines
> Hello David,
> From: david stroud
> F-24 and
> or anyone
> 165, I
> affect
> gets beefed up
> C-FDWS Christavia
> YAHOO! GROUPS LINKS
> Service.
Chief Russell
Re: [Fairchild club] Engine mounts for non standard engines
Post by Chief Russell »
'Negative on additional "beef up"; our F24 has 30# in the tail but am going
to check the weight and balance as another owner in OK has a Continental 220
as ours and does NOT have the extra weight in the tail...
Dick (81229)
[mailto:fairchildclub@yahoogroups.com]On Behalf Of david stroud
Sent: Sunday, January 01, 2006 3:06 PM
F-24 and
or anyone
165, I
affect
beefed up
C-FDWS Christavia
YAHOO! GROUPS LINKS
Service.
David Stroud
'Thanks for the quick replies on the non standard engine questions. We have an option
here in Canada to build an "amateur built" class plane from the parts of others if one
can prove that over 51% of the work has been done by the new owner. It's an interesting
opportunity and is the one I will be building under. I'll use a radial engine but it won't be
a Warner. That's why you got to buy mine, Jamie. My engine will be of Russian/ Romanian
decent and that's what I had planned from the get go. George Coy of Gesoco.com sells
a direct drive derivative of something similar to the M14P. It was a Kamov helicopter engine
which apparently is famous for it's high torque cam and is now available with a direct drive
nose case replacing the geared versions such as the M14P. New engines are available new,
for about $12,500 US in Vermont. On the other hand, those wealthy buggers with their Nanchang
Cj 6's have too much cash in their pockets and routinely remove the Housai 285 hp geared
radial and replace it with the M14P 360 hp radial. Nicely enough, the direct drive
nose case fits the Housai too. Those Housai engines can be picked up for well under $8K
with only a few hundred hours on them. So, dump the gearbox, sell the prop that comes with
them for $2K, mount a wooden prop on a direct drive nose case. The overall weight should be very
close to a Warner with a Curtiss Reed prop. In a nutshell, 220 hp for under ten grand
and no need to overhaul, these engines are available anywhere...and a radial to boot. Or, go
nuts and keep the gearbox, save even more money, have a 265 hp engine with a controllable
prop. Your penalty will be about 100 lbs. Rebuilding my 20 lb doors and changing out the
stuff on the panel will cure a lot of that. My goal is to build up a two place cross country
machine in the guise of a Fairchild 24 in Military drag with a radial engine.
I hope I haven't offended anyone by being less than traditional with my approach but it is
just too tempting to get the plane set up the way I would like it to ignore.
C-FDWS Christavia
Sent: Sunday, January 01, 2006 4:41 PM
David,
norbymac20@sbcglobal.net
Post by norbymac20@sbcglobal.net »
'Hi David, I bought a rebuild project, 3 yrs ago, that has a 225 hp Jake on
it. The mount was made by someone in California. (I am not near the plane).
I have not noticed any changes or additions to the firewall or tubing. I
will take a serious look the next time that I get near the project, which
will be next spring, for I am a snowbird, living at Winter Haven, Florida.
Lucky Mc Luckie
> F-24 and
> or anyone
> 165, I
> affect
> beefed up
> C-FDWS Christavia
David Stroud
'Thanks for the note, Lucky. If you're in the mood, please consider attending our
BBQ at Sun n Fun this year. Friday night.
Engine mounts don't faze me one bit. It's what it get attached to that I need to
learn about. Regards..
C-FDWS Christavia
Sent: Sunday, January 01, 2006 8:08 PM
Lucky Mc Luckie
> F-24 and
> or anyone
> 165, I
> affect
> beefed up
> C-FDWS Christavia
YAHOO! GROUPS LINKS
Checked by AVG Free Edition.
Version: 7.1.371 / Virus Database: 267.14.9/216 - Release Date: 12/29/05
Chief Russell
Fairchild club: alternate engines for the F24
'Question: How much does a Warner weigh-?
Dick Russell
Sent: Sunday, January 01, 2006 8:05 PM
attending our
need to
C-FDWS Christavia
Jake on
plane).
I
which
Florida.
Lucky Mc Luckie
his
> F-24 and
him
> or anyone
Warner
> 165, I
may
> affect
gets
> beefed up
> C-FDWS Christavia
reservation
YAHOO! GROUPS LINKS
Service.
YAHOO! GROUPS LINKS
Service.
Chief Russell
Engine mounts for other F24 engines
'Lucky -
where in CA is the airplane located-? I will b out in march and August
certain and maybe in between those months. I would like to take a look see
at your "project"...
Dick Russell (81229)
attending our
need to
C-FDWS Christavia
Jake on
plane).
I
which
Florida.
Lucky Mc Luckie
his
> F-24 and
him
> or anyone
Warner
> 165, I
may
> affect
gets
> beefed up
> C-FDWS Christavia
reservation
YAHOO! GROUPS LINKS
Service.
YAHOO! GROUPS LINKS
Service.
Chief Russell
Engine mounts for Continental engines on F24....
'This F24 with a Continental has been flying that way since 1973...
F-24 and
or anyone
165, I
affect
beefed up
C-FDWS Christavia
YAHOO! GROUPS LINKS
Service.
