'We have a F-24HS with 20 gallon fuel tanks which we wish to convert to
the larger 30 gallon tanks. Does anyone know of a STC that allows
this ?'
Re: Fairchild wings P-19
OldOOwl@aol.com
Re: F-24 Fuel Tanks
'My 1937 24G was converted to 30 gallon tanks....I'll check the paperwork.
I'll be going to the hangar today.
Richard Hawley
Richard Hawley
harry hayman
Re: F-24 Fuel Tank Fuel Level Sender,s
'Hi F24 People,
I have to replace both fuel tank level sender's.
If anyone had a similar problem I would appreciate any
info such as Mfg. Part #,Source,ect.
Also I would like to convert to 12 Volt instead of 6
Volt.
Thanx
Harry
--- OldOOwl@aol.com wrote:
Phone 904-284-4276
Fax 904-284-3869
Yahoo! Mail - PC Magazine Editors' Choice 2005
http://mail.yahoo.com'
Volt.
Thanx
Harry
Harry Hayman> My 1937 24G was converted to 30 gallon tanks....I'll
> Richard Hawley
> removed]
Phone 904-284-4276
Fax 904-284-3869
Robert Albee
'Thanks so much. Robert
Sent: 11/29/2005 1:24:27 PM
Subject: Re: [fairchildclub] F-24 Fuel Tank Fuel Level Sender,s
Hi F24 People,
Volt.
Thanx
Harry
> Richard Hawley
> removed]
Harry Hayman
Phone 904-284-4276
Fax 904-284-3869
YAHOO! GROUPS LINKS
Visit your group "fairchildclub" on the web.
'Harry
give me a call at (507) 263-2414 in the evening about 9 PM CST. I can give
you the information on the fuel tank senders and gauges.
Fairchild Club
Fairchild Club
Sent: Tuesday, November 29, 2005 3:24 PM
> Hi F24 People,
> Volt.
> Thanx
> Harry
> > Richard Hawley
> > removed]
> Harry Hayman
> Phone 904-284-4276
> Fax 904-284-3869
harry hayman
'Thanx John,will call tonight.
Harry
--- John Berendt wrote:
Phone 904-284-4276
Fax 904-284-3869
Start your day with Yahoo! - Make it your home page!
http://www.yahoo.com/r/hs'
Harry
Harry Hayman> Harry
> gauges.
> John Berendt
> Fairchild Club
> From: "harry hayman"
> Level Sender,s
> > Hi F24 People,
> any
> 6
> > Volt.
> > Thanx
> > Harry
> tanks....I'll
> > > Richard Hawley
> > > removed]
> > Harry Hayman
> > Phone 904-284-4276
> > Fax 904-284-3869
> > Yahoo! Groups Links
Phone 904-284-4276
Fax 904-284-3869
Ron Norman
'We are restoring a PT-19 and are well into the restoration. We have the
fuselage complete with a '0' time engine and all it needs now is covering.
We are looking for a Left Wing to complete the restoration. Does anyone know
of one. Our left wing needs major repair. We hope to find a wing and have
this airplane flyable by late November of this year. Yor help would be
appreciated.
Ron Norman
Spirit of Tulsa Squadron CAF
Tulsa, OK
YAHOO! GROUPS LINKS
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
appreciated.
Ron Norman
Tulsa, OK
SPONSORED LINKS Private plane Fairchild semiconductor Plane reservation> __________________________________
YAHOO! GROUPS LINKS
Service.
windshieldguy2000
Re: F-24 Fuel Tanks
'I have a single 30 gallon tank available if you need it. I think it's
the right tank, but I've slept since then and it's sleeting in Texas,
not a good time to drive 20 miles to the hanger. Let me know if you
need it; I'd like to trade it for other parts I need.
Best Wishes,
Brad Donner
NC77605'
Best Wishes,
Brad Donner
NC77605'
Charles Mueller
'Hello Ron,
I've been looking for wings for my own PT restoration project too, for several years now.
Now I have a two pairs of wings, which I have thought were the best of those available. I've
looked at about a dozen wings over the past several years and all have had de-laminations
in the caps of the built-up box spars. Typically the de-laminations occur right where the
attach strap bolts pass through the spar caps. Apparently the aluminum spacers that the
bolts pass through inside the spar caps (that are there to keep the straps from crushing
the built-up wood caps) have corroded and expanded, helping the de-lamination along.
That along with the slightly water soluble casein glue originally used, and the age of the
original wings, have resulted in the de-laminations. To see the de-laminations the
protective plywood covers over the ends of the spars need to be removed.
After thinking about it awhile I've concluded that I don't want to trust my neck on these
wings. But at least I now have the hardware needed to build new wings!
Charles Mueller
PT-26 project
Chico, CA
Charles Mueller
PT-26 project
Chico, CA
> appreciated.
> Ron Norman
> Tulsa, OK
