Re: Brake Fluid
longmere
Brake Fluid
Post by longmere »
'How do I tell what kind of brake fluid that I have in my system? I
have looked back in the logs, but no help. I heard Jamie say that he
tasted the fluids. How does that work? Thanks.'
Michael Callison
Brake Fluid
Post by Michael Callison »
'I am involved with the Iowa Aviation Heritage Museum in Ankeny, Iowa.
We are restoring a Pt19 to flying condition. We are currently working
on the brake system and I read in the Maintenance Manual that you are
suppose to use Mineral Oil or Lockhead Oil in the Brake system. I see
that someone wrote recently that they use DOT 5 fluid. Is this okay?
Where can I get the correct fluid and where can I purchase new master
cylinder seals and brake expander diaphrams from. We have one that I
would not be afraid to reuse and another that I would rather replace.
You can see some of our progress at our website
www.iowaaviationheritagemuseum.web.com
Thank you for your help.
Michael D. Callison
Never miss a thing. Make Yahoo your homepage.
Re: Brake Fluid
Post by Curt Kinchen »
'I've used DOT 5 with no problems. Others have said the same regarding
5606, but some have noted incompatibility of 5606 with the bladders.
In any case be sure to flush the system completely to insure you don't
have a mix of fluids.
Fresno Airparts has expander tubes.
--- In fairchildclub@yahoogroups.com, Michael Callison
> Michael D. Callison
Buell Powell
Brake Fluid
Post by Buell Powell »
'#ygrps-yiv-1610232778 p {margin:0;} Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines. Thanks.  Buell Powell-1946 F24R
BHP
tonylowe2
Re: Brake Fluid
Post by tonylowe2 »
I use DOT 5 in the brakes of my 24W-41.  Also use the same fluid in my landing gear oleo struts.
---In fairchildclub@yahoogroups.com, wrote:
#ygrps-yiv-1773992194 #ygrps-yiv-1773992194ygrps-yiv-561602780 p {margin:0;} Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines. Thanks.  Buell Powell-1946 F24R
BHP
Jamie Treat
Re: Brake Fluid
Post by Jamie Treat »
'Buell,  Yes you  can use Dot 5. If you do, mark it in the log, highlight in yellow. Mark near the masters, cover is good place. Do the same for the struts. You do not want to mix Dot 3 or 5606. Bad news.  JST      From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of Buell Powell
Sent: Monday, November 25, 2013 1:14 PM
To: Fairchild Club
Subject: [fairchildclub] Brake Fluid                Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines.            Thanks.            Buell Powell-1946 F24R
-- BHP'
Buell Powell
Re: Brake Fluid
'#ygrps-yiv-1478029282 p {margin:0;} Thanks! I will mark it in the log book and master cyl cover.
To: Fairchild Club
-- BHP
BHP
tomatotruck993
Re: Brake Fluid
Post by tomatotruck993 »
Hello Buell,
The three fluids are very different and are not compatible with each other. Their systems are not cleaned and flushed with the same chemicals/fluids. I would suggest you do a little investigating on the traits and properties of each fluid type and make your own educated decision on which to use. Keep in mind that commonality is often the safest choice.
Review these sites before making a final choice:Different Types Of Brake Fluid
Difference Between Dot3 and Dot4 Brake Fluid | Difference Between
Brake_Fluid_Tech.pdf (application/pdf Object)
DOT 3, DOT 4, and DOT 5 « Jim’s Garage
Brake Fluid Facts
Wes KIA in Wisconsin
#ygrps-yiv-329083281 #ygrps-yiv-329083281ygrps-yiv-655394729 p {margin:0;} Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines. Thanks.  Buell Powell-1946 F24R
BHP
Jamie Treat
Re: Brake Fluid
'Flush the entire system with Denatured Alcohol.  JST  From: fairchildclub@yahoogroups.com [mailto:fairchildclub@yahoogroups.com] On Behalf Of wsknettl@centurytel.net
Sent: Monday, November 25, 2013 4:38 PM
Subject: [fairchildclub] RE: Brake Fluid
Hello Buell,
Brake Fluid Facts
Wes K
IA in Wisconsin
---In fairchildclub@yahoogroups.com, wrote:            Finally re-building the master cylinders on my 1946 F24. I believe they are the same as for a 1937 Plymouth. I found a note in my records to use Dot 5 fluid--can someone let me know if this is correct and what would be best to clean the cylinder bore and flush the lines.            Thanks.            Buell Powell-1946 F24R
-- BHP'
james chybicki
Re: Brake Fluid
Post by james chybicki »
'Hi BuellIts been a while!Take Jamie's advice, flush with Denatured Alcohol then use the Dot 5. Did you install Cleveland system or sticking to the Hayes brakes?Jim C.
Subject: [fairchildclub] RE: Brake Fluid    Hello Buell,  The three fluids are very different and are not compatible with each other. Their systems are not cleaned and flushed with the same chemicals/fluids. I would suggest you do a little investigating on the traits and properties of each fluid type and make your own educated decision on which to use. Keep in mind that commonality is often the safest choice.   Review these sites before making a final choice:Different Types Of Brake FluidDifference Between Dot3 and Dot4 Brake Fluid | Difference BetweenBrake_Fluid_Tech.pdf (application/pdf Object)DOT 3, DOT 4, and DOT 5 « Jim’s GarageBrake Fluid Facts  Wes KIA in Wisconsin
-- BHP #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412 -- #ygrps-yiv-333245792yiv1182430412ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp hr { border:1px solid #d8d8d8;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp #ygrps-yiv-333245792yiv1182430412hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp #ygrps-yiv-333245792yiv1182430412ads { margin-bottom:10px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp .ygrps-yiv-333245792yiv1182430412ad { padding:0 0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp .ygrps-yiv-333245792yiv1182430412ad p { margin:0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mkp .ygrps-yiv-333245792yiv1182430412ad a { color:#0000ff;text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ygrp-lc { font-family:Arial;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ygrp-lc #ygrps-yiv-333245792yiv1182430412hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ygrp-lc .ygrps-yiv-333245792yiv1182430412ad { margin-bottom:10px;padding:0 0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412actions { font-family:Verdana;font-size:11px;padding:10px 0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity { background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span { font-weight:700;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span:first-child { text-transform:uppercase;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span a { color:#5085b6;text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span span { color:#ff7900;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412activity span .ygrps-yiv-333245792yiv1182430412underline { text-decoration:underline;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach { clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach div a { text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach img { border:none;padding-right:5px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach label { display:block;margin-bottom:5px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412attach label a { text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 blockquote { margin:0 0 0 4px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412bold { font-family:Arial;font-size:13px;font-weight:700;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412bold a { text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 dd.ygrps-yiv-333245792yiv1182430412last p a { font-family:Verdana;font-weight:700;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 dd.ygrps-yiv-333245792yiv1182430412last p span { margin-right:10px;font-family:Verdana;font-weight:700;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 dd.ygrps-yiv-333245792yiv1182430412last p span.ygrps-yiv-333245792yiv1182430412yshortcuts { margin-right:0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412attach-table div div a { text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412attach-table { width:400px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a:active, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a:hover, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412file-title a:visited { text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a:active, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a:hover, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div.ygrps-yiv-333245792yiv1182430412photo-title a:visited { text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 div#ygrps-yiv-333245792yiv1182430412ygrp-mlmsg #ygrps-yiv-333245792yiv1182430412ygrp-msg p a span.ygrps-yiv-333245792yiv1182430412yshortcuts { font-family:Verdana;font-size:10px;font-weight:normal;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412green { color:#628c2a;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412MsoNormal { margin:0 0 0 0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 o { font-size:0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412photos div { float:left;width:72px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412reco-category { font-size:77%;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412reco-desc { font-size:77%;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 .ygrps-yiv-333245792yiv1182430412replbq { margin:4px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg { font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg table { font-size:inherit;font:100%;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg select, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 input, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 textarea { font:99% Arial, Helvetica, clean, sans-serif;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg pre, #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 code { font:115% monospace;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg * { line-height:1.22em;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-mlmsg #ygrps-yiv-333245792yiv1182430412logo { padding-bottom:10px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-msg p a { font-family:Verdana;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-msg p#ygrps-yiv-333245792yiv1182430412attach-count span { color:#1E66AE;font-weight:700;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-reco #ygrps-yiv-333245792yiv1182430412reco-head { color:#ff7900;font-weight:700;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-reco { margin-bottom:20px;padding:0px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ov li a { font-size:130%;text-decoration:none;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ov li { font-size:77%;list-style-type:square;padding:6px 0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-sponsor #ygrps-yiv-333245792yiv1182430412ov ul { margin:0;padding:0 0 0 8px;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-text { font-family:Georgia;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-text p { margin:0 0 1em 0;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-text tt { font-size:120%;} #ygrps-yiv-333245792 #ygrps-yiv-333245792yiv1182430412 #ygrps-yiv-333245792yiv1182430412ygrp-vital ul li:last-child { border-right:none !important;} #ygrps-yiv-333245792
