Re: Ignition Harness
Thekortas@aol.com
'Hey guys: Would be interested in hearing were anyone has been acquiring, or
what they have been using, for replacement mag to plug ignition leads... or
complete harnesses.... for Rangers? May end up ordering from J&C but understand
he is currently waiting as long as two months for his next shipment of shielded
wire. Sure hate the thought of maybe being down that long and missing out on
half the summer. Won't let that happen but just thought I'd ask the group.
Thanks in advance for any info you may have to offer.
Steve Korta
Steve Korta
'Steve,
I will check my parts today and maybe I can help you out.I will call you
this evening.
John berendt
this evening.
John berendt
Sent: Sunday, May 22, 2005 8:52 PM
Subject: Re: [fairchildclub] Ignition Harness
or
or
understand
shielded
on
group.
> Steve Korta
'Steve,
We have a lot of Ranger experience (50+ engines) and
can help you out on an ignition harness. Call my dad,
Joe Denest at 610-399-7028. If you need a harness,
you'll get it a lot faster than J&C.
Mike Denest
--- Thekortas@aol.com wrote:
Do You Yahoo!?
http://mail.yahoo.com'
Mike Denest
__________________________________________________> Hey guys: Would be interested in hearing were anyone
> offer.
> Steve Korta
> removed]
Do You Yahoo!?
Thekortas@aol.com
'Mike (D), Mike (K) and John (B): Thanks for the replies. I'll follow-up on all of these suggestions. Appreciate the help.
Steve
Sent: Mon, 23 May 2005 04:01:32 -0700 (PDT)
Steve,
Mike Denest
Do You Yahoo!?
Steve
Steve,
Mike Denest
> offer.
> Steve Korta
> removed]
Do You Yahoo!?
Mike Danielle
'I'll defer to the experts about the harness but I want to relate my
experience with the metal shielded harness that's on my Ranger. The
ferrules apparently were not properly swaged onto the shielding and some
were loose. This caused no end to radio noise. I spend weeks tracking down
one loose ferrule only to discover that yet another was loose. If I had it
to do again I'd probably go with the shielded leads that someone like Savage
Magneto makes for the Ranger. They have internal shielding (I guess). FWIW
Mike in Oregon
Mike in Oregon
Sent: Sunday, May 22, 2005 6:52 PM
or
or
understand
shielded
on
group.
> Steve Korta
Thekortas@aol.com
'Thank you, too, Mike in Oregon, for the input. The entire issue started precisely with our chasing radio noise. Everything except the harness has been ruled out. And we seem to have found the bad lead. Thanks.
Steve
Sent: Mon, 23 May 2005 06:36:42 -0700
Mike in Oregon
Steve
Mike in Oregon
or
or
understand
shielded
on
group.
> Steve Korta
John Amundsen
'I had the same problem even with a new harness. I solved the problem by going through and cleanin/replacing all of the grounding connections.
Sent: Monday, May 23, 2005 7:34 AM
Steve
Mike in Oregon
or
or
understand
shielded
on
group.
> Steve Korta
Thekortas@aol.com
'Thanks for the tip. We'll try it all
Steve
Steve
danMichael
'All:
Me, too — I have radio noise that goes away when I turn off the right
mag. Could someone enlighten me as to the procedure for diagnosing the
source of the noise?
Thanks in advance,
:Dan Michael'
Are you referring to P-lead connections or spark wire connections?> I solved the problem by going through and cleanin/replacing all of the
How do you identify a bad lead?> Everything except the harness has been ruled out. And we seem to have
> found the bad lead.
Thanks in advance,
:Dan Michael'
John Amundsen
'After replacing the harness, and still had the radio noise, I traced all
grounding connections back to the battery. I had some bad connections
across the motor mounts, etc. I cleaned every connection and even replaced
a couple of ground straps.
Sent: Monday, May 23, 2005 8:51 PM
All:
> found the bad lead.
Thanks in advance,
:Dan Michael
