'Hi
my tail wheel oleo is leaking a bit, does anyone have a source for
seals etc? or advice?
Cheers
James'
Re: tail wheel strut on F24
danMichael
'James:
figure 3-25 in the F24 manual) and its been pretty dry since. I bought
a bag of 5/32" leather washers at McMaster-Carr and punched a hole in
the center to fit the strut rod. If you want to try this I can search
for the bag and mail you a few. There is probably a more modern
solution, but this worked for me.
Be sure its not leaking out the fill plug first. You will need to
disassemble the tailwheel strut to replace this seal.
Good luck.
:Dan
:NC81323'
Mine was, too. I replaced the leather oil wiper (part 43214, #12 in> my tail wheel oleo is leaking a bit, does anyone have a source for
Good luck.
:Dan
:NC81323'
jameslbryan@btopenworld.com
'Hi Dan
its leaking from the oleo and underneath so will need to do the washer.
My address is James Bryan, 1 waverley gardens, stamford, Lincolnshire, PE91BH.
if you could senr me a couple i would be very gratefull , thanks.
have you any pics of your f24?
danMichael wrote:
James:
Good luck.
:Dan
:NC81323
To visit your group on the web, go to:
Send instant messages to your online friends http://uk.messenger.yahoo.com
danMichael wrote:
James:
Good luck.
:Dan
:NC81323
