'Is anyone using a Curtis Reed propeller on their Ranger 200 hp engine
on the Fairchild 24? I have received some conflicting reports and
comments on the benefits or detractions on using this propeller. Any
comments? Is there a benefit of wood over metal propeller?'
Re: Curtis Reed Propeller
norbymac20@sbcglobal.net
'I am rebuilding a 1939 F;24 that came with a Curtis Reed prop on a 225 hp
Jacobs. I don't have any idea of its merits. This plane may not fly, this
year, so I guess that I can't give any report for awhile, Norb Mc
Luckie
Luckie
Sent: Tuesday, April 12, 2005 11:16 PM
Subject: [fairchildclub] Curtis Reed Propeller
danMichael
'On Tuesday, April 12, 2005, at 11:16 PM, longmere2 wrote:
listed on the type certificate.
you dont have to worry about engine / prop system resonant frequencies
and harmonics as much.
:Dan
:NC81323'
Is the Curtiss Reed an approved installation for the Ranger? Its not> Is anyone using a Curtis Reed propeller on their Ranger 200 hp engine
> comments?
Less weight, less likely to damage the crankshaft on a prop strike, and> Is there a benefit of wood over metal propeller?
:Dan
:NC81323'
'Thanks for your comments. The Curtis Reed is on the plane covered
by a 337 referencing the PT 26 and Widgeon with the 6-440-C5
engine. I am aquiring a wood prop.
engine
and
propeller. Any
> > comments?
not
strike, and
frequencies
> :Dan
> :NC81323
'You are better off with a wood prop. Curtiss Reed's
are known for breaking Ranger crankshafts.
--- longmere2 wrote:
Do you Yahoo!?
Plan great trips with Yahoo! Travel: Now over 17,000 guides!
http://travel.yahoo.com/p-travelguide'
__________________________________>
> plane covered
> 6-440-C5
> Ranger 200 hp
> engine
> conflicting reports
> and
> this
> propeller. Any
> > > comments?
> the Ranger? Its
> not
> on a prop
> strike, and
> resonant
> frequencies
> > :Dan
> > :NC81323
Do you Yahoo!?
'Have you ever seen any old pictures of a Ranger powered Aircraft with a
Curtis Reed Prop? The US Army tried them and broke many crankshafts. There
are plenty
of good wooden props to chose from. The wood props absorb the power pulses
from the crank and so last longer.
Sent: Wednesday, April 13, 2005 12:16 AM
Terms of Service.
are plenty
Terms of Service.
ranger440c5
'I don't know about the breakage history, but couldn't agree more
about the wood absorbing the pulses. I flew in a 24 w/175 and a too
short C-R....it was not a happy marraige. I don't know where or why
but there were strange noises/vibes from the engine house when power
pulled back. It wasn't comforting.
The Ranger has a 4 foot long crank and being a 6 inline has a throw
and thus a power pulse every 120 degrees. It's inherantly smooth and
easy to balance combination, unlike a v6 which will never be a
smoothie regardless of vee angle. It is this long crank that twists
and winds tight/loose with the power pulses. As the furthest journal
from the prop transmits it's power thru 5 more throws infront of
it...well there is a deal of flexing going on. The more resistance to
these torsional stresses(metal prop) the more these stresses have to
be dealt with inside the engine.
It would seem that as these engines become more difficult to obtain
correct parts and service for on a dialy basis, that one would not be
inclined to stack any odds against the engine's durability, imagined
or real.
--- In fairchildclub@yahoogroups.com, "Bob Haas"
or real.
with a> Have you ever seen any old pictures of a Ranger powered Aircraft
crankshafts. There> Curtis Reed Prop? The US Army tried them and broke many
pulses> are plenty
engine> from the crank and so last longer.
> _____
> From: longmere2 [mailto:longmere@a...]
Any> on the Fairchild 24? I have received some conflicting reports and
> _____
> Terms of Service.
