Re: Curtis Reed Propeller
longmere2
Post by longmere2 »
'Is anyone using a Curtis Reed propeller on their Ranger 200 hp engine
on the Fairchild 24? I have received some conflicting reports and
comments on the benefits or detractions on using this propeller. Any
comments? Is there a benefit of wood over metal propeller?'
norbymac20@sbcglobal.net
Post by norbymac20@sbcglobal.net »
'I am rebuilding a 1939 F;24 that came with a Curtis Reed prop on a 225 hp
Jacobs. I don't have any idea of its merits. This plane may not fly, this
year, so I guess that I can't give any report for awhile, Norb Mc
Luckie
Sent: Tuesday, April 12, 2005 11:16 PM
Subject: [fairchildclub] Curtis Reed Propeller
danMichael
Post by danMichael »
> comments?
Is the Curtiss Reed an approved installation for the Ranger? Its not
listed on the type certificate.
Less weight, less likely to damage the crankshaft on a prop strike, and
you dont have to worry about engine / prop system resonant frequencies
and harmonics as much.
:Dan
:NC81323'
longmere2
Post by longmere2 »
'Thanks for your comments. The Curtis Reed is on the plane covered
by a 337 referencing the PT 26 and Widgeon with the 6-440-C5
engine. I am aquiring a wood prop.
engine
and
propeller. Any
> > comments?
not
strike, and
frequencies
> :Dan
> :NC81323
Michael Denest
Post by Michael Denest »
'You are better off with a wood prop. Curtiss Reed's
are known for breaking Ranger crankshafts.
> plane covered
> 6-440-C5
> Ranger 200 hp
> engine
> conflicting reports
> and
> this
> propeller. Any
> > > comments?
> the Ranger? Its
> not
> on a prop
> strike, and
> resonant
> frequencies
> > :Dan
> > :NC81323
Do you Yahoo!?
Plan great trips with Yahoo! Travel: Now over 17,000 guides!
http://travel.yahoo.com/p-travelguide'
Bob Haas
Post by Bob Haas »
'Have you ever seen any old pictures of a Ranger powered Aircraft with a
Curtis Reed Prop? The US Army tried them and broke many crankshafts. There
are plenty
of good wooden props to chose from. The wood props absorb the power pulses
from the crank and so last longer.
_____
Sent: Wednesday, April 13, 2005 12:16 AM
_____
* To visit your group on the web, go to:
* To unsubscribe from this group, send an email to:
* Your use of Yahoo! Groups is subject to the Yahoo!
Terms of Service.
ranger440c5
Post by ranger440c5 »
'I don't know about the breakage history, but couldn't agree more
about the wood absorbing the pulses. I flew in a 24 w/175 and a too
short C-R....it was not a happy marraige. I don't know where or why
but there were strange noises/vibes from the engine house when power
pulled back. It wasn't comforting.
The Ranger has a 4 foot long crank and being a 6 inline has a throw
and thus a power pulse every 120 degrees. It's inherantly smooth and
easy to balance combination, unlike a v6 which will never be a
smoothie regardless of vee angle. It is this long crank that twists
and winds tight/loose with the power pulses. As the furthest journal
from the prop transmits it's power thru 5 more throws infront of
it...well there is a deal of flexing going on. The more resistance to
these torsional stresses(metal prop) the more these stresses have to
be dealt with inside the engine.
It would seem that as these engines become more difficult to obtain
correct parts and service for on a dialy basis, that one would not be
inclined to stack any odds against the engine's durability, imagined
or real.
--- In fairchildclub@yahoogroups.com, "Bob Haas"
with a
crankshafts. There
> are plenty
pulses
> _____
> From: longmere2 [mailto:longmere@a...]
engine
Any
> _____
> Terms of Service.
