'Another thing I forgot to mention on our postings yesterday is that
regarding the heater installation, the aircraft has a Ranger
installed. Really need to figure out what kind of heat exchanger
might be used.
Thanks!!
Len Miller - Jet West, Reno, Nv.'
Re: N81271 Heater
Re: N81271 Heater
'Len:
heat arrangement. As far as I can tell, the factory drawing for the
Ranger installation isnt on the Fairchild CD, only the Warner. With
the standard exhaust collectors, a heat exchanger is not feasible since
the exhaust system is outside the cowling. My plane has a small scoop
intake at the #1 (rearmost) cylinder cooling baffling that has SCAT
tubing led to the cabin heat mixer on the firewall. I do not know if
this is stock, but it is similar to other aircraft I have seen. It
provides enough heat to warm your fingers if you put them directly in
front of the heater outlet, but its hard to reach with your right hand.
Good luck,
:Dan Michael
:NC81323'
I have a 1946 F24R and have also been curious about the stock cabin> Another thing I forgot to mention on our postings yesterday is that
> might be used.
Good luck,
:Dan Michael
:NC81323'
Re: N81271 Heater
'My 24R (81228) has a six cylinder exhaust manifold (actually two threes that
are interconnected) and a single exhaust stack. There is a tube that is
around one inch diameter and I would guess about .125 wall thickness that
goes down the middle of the manifold and comes out at the back of the
manifold. There is flex tubing from that stub to the controller on the
firewall that sends the heat overboard or into the cabin. The front of the
tube is below the oil cooler intake where the manifold is open to the
airstream.
It blows pretty hot, but mainly on your left leg by the outlet. I haven't
flown in cold enough weather with it to see if it really makes a difference.
Bob Webster
airstream.
Bob Webster
Cc: "lenwmiller"
Sent: Friday, March 11, 2005 12:46 PM
Subject: Re: [fairchildclub] N81271 Heater
> Len:
> > might be used.
> Good luck,
> :Dan Michael
> :NC81323
Re: N81271 Heater
'I have one of this type.Condition probaly an 8.
I have no idea what it is worth,I would enertain an
offer.
Harry 904-284 4276
--- Bob Webster wrote:
Phone 904-284-4276
Fax 904-284-3869
Do You Yahoo!?
http://mail.yahoo.com'
offer.
Harry 904-284 4276
Harry Hayman> My 24R (81228) has a six cylinder exhaust manifold
> at the back of the
> airstream.
> Bob Webster
> From: "danMichael"
> Cc: "lenwmiller"
> > Len:
> has a Ranger
> of heat exchanger
> > > might be used.
> the Warner. With
> I have seen. It
> > Good luck,
> > :Dan Michael
> > :NC81323
> > Yahoo! Groups Links
Phone 904-284-4276
Fax 904-284-3869
Do You Yahoo!?
Re: N81271 Heater
'Dan:
I considered a set-up like yours, but found an acceptable
alternative. I purchased a 12 volt electric blanket. I installed a
cigarette lighter outlet, and 'presto' instant warmth. Keeps our
feet from freezing and blocks some of the cold drafts at the same
time. On really cold days, it is still a LOT warmer flying into the
sun. It helps to have a heated hangar.
1939 Fairchild 24 K
Stillwater Minnesota Brrrrrr!
1939 Fairchild 24 K
'--- In fairchildclub@yahoogroups.com, danMichael wrote:
> Len:
that
exchanger
> > might be used.
cabin
the
With
since
scoop
SCAT
if
It
in
hand.
> Good luck,
> :Dan Michael
> :NC81323
