'Does anyone have any opinions on wood varnish? I searched the
boards history and one person recomended the stits epoxy varnish.
Any other ideas out there?'
Re: wood varnish
Re: wood varnish
'Any good marine of polyurethane varnish will do. They cost a lot less than
the varnish from aircraft spruce.
Sent: Tuesday, February 08, 2005 2:12 PM
Subject: [fairchildclub] wood varnish
Tom Mueller
Re: wood varnish
'Recently did the inside door posts while the doors were off. I used
straight ole Marine Spar varnish, "Man O' War" was the brand name,
Semi-Gloss, got it at Orchard. Couple of coats was fine with light
sanding between. Also experimented a little with those small one
inch sponge type brushes. They give a fantastic flat hard finish,
and I'm very pleased with results.
Hanford,Ca.'
Hanford,Ca.'
