'I came across this report that NACA published in 1933. They modified a
Fairchild 22 by adding a wing with split flaps that deflected 59
degrees. Sound familiar? Its not quite the system employed later on
the 24: the flaps are nearly full-span, with spoiler-type ailerons
mounted above the flaps. Their tests show that minimum takeoff ground
roll was with flaps 30, where the detent is on the 24 flap system.
http://naca.larc.nasa.gov/reports/1933/naca-tn-475/
:Dan
:NC81323'
Re: NACA report on split flaps
'Dan,
Thanks, I captured that for the Fairchild CD ROM.
Sent: Wednesday, January 12, 2005 12:52 PM
Subject: [fairchildclub] NACA report on split flaps
> :Dan
> :NC81323
Bob and Dot Haas
'Hey Jamie! We all know that the '46 24's land better with full flaps on hard
surface, what is the message we have all missed? Bob.
From: Jamie S. Treat [mailto:jamietreat@direcway.com]
Sent: Wednesday, January 12, 2005 6:54 PM
Subject: Re: [fairchildclub] NACA report on split flaps
Dan,
Dan,
> :Dan
> :NC81323
rangerrobertmn
'Bob Haas,
Note that the NACA Report refers the the negative effect of full
flaps on TAKEOFF, not landing. My Fairchild 24 K does NOT like full
flaps for takeoff, and I avoid using any flaps for takeoff.
Stillwater, MN
Fairchild 24 K
--- In fairchildclub@yahoogroups.com, "Bob and Dot Haas"
Stillwater, MN
Fairchild 24 K
flaps on hard> Hey Jamie! We all know that the '46 24's land better with full
modified a> surface, what is the message we have all missed? Bob.
> From: Jamie S. Treat [mailto:jamietreat@d...]
> Dan,
> Jamie
> From: "danMichael"
later on> > Fairchild 22 by adding a wing with split flaps that deflected 59
ailerons> > the 24: the flaps are nearly full-span, with spoiler-type
ground> > mounted above the flaps. Their tests show that minimum takeoff
system.> > roll was with flaps 30, where the detent is on the 24 flap
> > :Dan
> > :NC81323
> > Yahoo! Groups Links
Bob and Dot Haas
'Me to! But they do work landing. Bob
From: rangerrobertmn [mailto:rangerrobertmn@yahoo.com]
Sent: Thursday, January 13, 2005 6:40 PM
Subject: [fairchildclub] Re: NACA report on split flaps
Bob Haas,
Stillwater, MN
Fairchild 24 K
Bob Haas,
Stillwater, MN
Fairchild 24 K
> Dan,
> Jamie
> From: "danMichael"
Yahoo! Groups Links'> >
> > :Dan
> > :NC81323
> > Yahoo! Groups Links
