Re: Landing gear universal's
wood glue
'I dont want to start people fighting but I would like to get
anyones opinion about glue for aircraft. Mostly I am looking for
info on any epoxy that you may have used. And if you did a 337 for
it or just kept it quiet. So please anyone have at this subject'
Tom Downey
Re: wood glue
'--- In fairchildclub@yahoogroups.com, "cagog" wrote:
read and follow the AC for the best results.
I have used T-88, and several other marine epoxies, all work well,
when the directions are followed.'
Chaper 1 in the AC 43-13,1b includes EPOXY as an approved adhesive,>
Re: wood glue
'Fairchild owners.
Below is a summary of Glue requirements/specifications. I prepared
this for one of my customers that is rebuilding a 1933 YKC Waco.
SUMMARY:
The only glues that comply with Fed Spec or Mil Spec are:
Weldwood Plastic Resin, Acft Spruce P/N 0203 or P/N 0204 complies
with MMM-A-188B Type II.
Weldwood Resorcinol, Acft Spruce P/N 0227, complies with MIL-A-46051
and Mil-A-22397.
T-88 does not comply, experimental purposes
West System does not comply, experimental Purposes.
The current issue of AC 41.13-1B Chg 1 dictates in Parg 1-4a (4) the
Fed Spec MMM-A-181D and MIL-A-22397.
I called the Aviat (Pitts) factory. They are currently using
Weldwood Plastic Resin.
I called West Systems. They have not tested there adhesives per Fed
Spec or Mil Spec. Have no intention. Support marine use only.
The Waco Factory is currently using West System 105 Resin, 206 Slow
Hardener, and 403 Fiber Filler on a FAA Variance to the approved
engineering. They did there own structural tests to satisfy the FAA.
I spoke with Mary Heilman (New Waco), they have the FAA Type Cert
approval on the New Waco's. They also use it for the restoration
work under Repair Station sign off. They have set the precedence for
West System. They have not heard anything from the FAA about the FAA
restriction of West System (Epoxy)use. This was a rumor going around
a few months ago. I asked if I could get a copy of there FAA
approval paperwork. The FAA will not allow them to distribute the
FAA variance and test results. But we can reference on the FAA 337
that the Waco Factory has been approved to use West Systems. Then
the FAA can get the data from in-house.
My Suggestion is: Use West Systems, 2nd choice would be T-88. I
would have the A&P/IA create a FAA 337 in advance and submit for
Block 3 approval. I have used both products with excellant results.
I also maintain tight tolerances between wood members to reduce the
glue filler. This is a standard for the older type glues. Better
workmanship.
Aircraft Restoration & Repair
Kelly Airpark
HM/Shop 303-648-0130
SUMMARY:
and Mil-A-22397.
workmanship.
Kelly Airpark
for
adhesive,
Tom Downey
Re: wood glue
'Do you know of any epoxy glues that meet Fed
Spec or Mil Spec?'
Spec or Mil Spec?'
Re: wood glue
'Epoxy is an ACCEPTABLE adhesive provided it complies
with the noted MIL SPEC standards listed in the
paragraph. Data supporting your repair must be
provided to your local FSDO inspector for approval
prior to commencing repairs. T-88 meets these
standards.
Mike Denest
--- Tom Downey wrote:
Do you Yahoo!?
Send holiday email and support a worthy cause. Do good.
http://celebrity.mail.yahoo.com'
standards.
Mike Denest
__________________________________>
> would like to get
> am looking for
> you did a 337 for
> this subject
> approved adhesive,
> all work well,
Do you Yahoo!?
Chief Russell
Fairchild wood glue
'Does it necessarily 'have' to meet MIL SPEC since some were UC61 and some
were F24 airplanes-? Use whatever is the advantage I say and you will
probably find little tech support from the local FSDO. From the recent
postings, it seems that folks are on the correct track - whatever works and
can be approved.
One might try White aero for some info in Ohio as I now that he does
Stearman repairs and rebuilds.
fly safe
Dick Russell, N81229
check www.russellaire.com and Fly Safe
Sent: Monday, December 20, 2004 5:54 AM
Subject: Re: [fairchildclub] Re: wood glue
standards.
Mike Denest
Do you Yahoo!?
Yahoo! Groups Sponsor
ADVERTISEMENT
can be approved.
fly safe
standards.
Mike Denest
> would like to get
> am looking for
> you did a 337 for
> this subject
> approved adhesive,
> all work well,
Do you Yahoo!?
ADVERTISEMENT
harry hayman
'Hi Guy's
Some info'please.
I have a set of upper and lower landing gear
universal's.which are bushed for a #6 bolt.They have
FS111 markings.Does anyons know if they comply with
the AD that requires replacement?
Harry
F24R9
Ser.300
20619
--- "Jamie S. Treat" wrote:
Harry Hayman
Phone 904-284-4276
Fax 904-284-3869
Do you Yahoo!?
The all-new My Yahoo! - Get yours free!
http://my.yahoo.com'
Some info'please.
Harry
F24R9
Ser.300
20619
> Fairchild owners.
> 1933 YKC Waco.
> SUMMARY:
> are:
> 0204 complies
> with MIL-A-46051
> and Mil-A-22397.
> Parg 1-4a (4) the
> currently using
> adhesives per Fed
> use only.
> Resin, 206 Slow
> the approved
> satisfy the FAA.
> FAA Type Cert
> restoration
> the precedence for
> FAA about the FAA
> rumor going around
> there FAA
> distribute the
> on the FAA 337
> Systems. Then
> be T-88. I
> and submit for
> excellant results.
> glues. Better
> workmanship.
> Kelly Airpark
> Elbert, CO 80106
> would like to get
> I am looking for
> you did a 337
> for
> at this subject
> approved
> adhesive,
Harry Hayman
Phone 904-284-4276
Fax 904-284-3869
Do you Yahoo!?
'Harry,
The FS111 is the type of material spec called out on the Drawings 3328 and
3330. Compare your unversal's to the drawings on the CD Rom. If they appear
to have the same appearance as the drawing then you have the older style.
The AD note applies. The newer style, and very few are out there, are totaly
differant in appearance. They are much larger in diameter. I have photos of
both, side by side. The photos are on a different PC, will have it back on
line in 24 hours. I can send you photos to your email account.
Kelly Airpark
Kelly Airpark
Sent: Friday, December 24, 2004 1:41 PM
Subject: [fairchildclub] Landing gear universal's
> Hi Guy's
> Some info'please.
> Harry
> F24R9
> Ser.300
> 20619
>> Fairchild owners.
>> 1933 YKC Waco.
>> SUMMARY:
>> are:
>> 0204 complies
>> with MIL-A-46051
>> and Mil-A-22397.
>> Parg 1-4a (4) the
>> currently using
>> adhesives per Fed
>> use only.
>> Resin, 206 Slow
>> the approved
>> satisfy the FAA.
>> FAA Type Cert
>> restoration
>> the precedence for
>> FAA about the FAA
>> rumor going around
>> there FAA
>> distribute the
>> on the FAA 337
>> Systems. Then
>> be T-88. I
>> and submit for
>> excellant results.
>> glues. Better
>> workmanship.
>> Kelly Airpark
>> Elbert, CO 80106
>> would like to get
>> I am looking for
>> you did a 337
>> for
>> at this subject
>> approved
>> adhesive,
> Harry Hayman
> Phone 904-284-4276
> Fax 904-284-3869
> Do you Yahoo!?
> http://my.yahoo.com
'I has the same question about the universals as you, until I was going
through some old parts that came off my 24.
Even after lord know how many annuals, I still has one of the original
universals installed up until the early 70's.
I will lay them side by side and take a couple pictures. The FS111 model is
much heavier.
Send me an E-mail directly to me at rletter@citlink.net , and I should be
able to a "JPG" attachment back to you today. That goes as well for any one
else out that hasn't seen the older version.
Bob'
much heavier.
Bob'
'All,
I can't find the picture Karl Sanger sent me for the universal joints. Still
looking.
looking.
Sent: Saturday, December 25, 2004 11:28 AM
Subject: Re: [fairchildclub] Landing gear universal's
> is
> much heavier.
> one
> Bob
